These 4 brackets are for a V8 1964 to 1967 Nova Chevy II - 2 are NOS spark plug wire holder brackets , 1 is refurbished spark plug wire holder bracket and 1 is an original used spark plug wire holder bracket. The bracket on the far right is for a manual transmission set up, the other 3 brackets can be used with either auto or manual transmission set ups.
The first bracket is an original and refurbished, it mounts to the left side of the rear block and is correct for a Nova/Chevy II.
The second bracket is an original and used, it mounts to the right side of the rear block and is correct for a Nova/Chevy II.
The third bracket is NOS, it is for the left-hand side and bolts to the rocker cover. The GM part number is 3814499. It has some surface rust and should be repainted.
The fourth bracket is NOS, it is for the right-hand side and bolts to the rear of the intake. The GM part number is 3744404. It has some very light surface rust areas, I have not attempted to see if they will clean up.
$160.00 plus shipping.
Let me know if you have any questions.
Thanks,
Frank
Thanks,
Thanks,
Frank
