There is no reproduction trim for the '64, but some vendors say the 62-63 trim fits the '64, anyone have experience with this and can verify? There is a set of '64 trim on ebay for $500!
thanks,
The 1964 rocker moldings are one-year only trim pieces and are VHTF!
The 62-63 rocker moldings will fit but they do not have the openings at the back for the rear wheel trim to fit in. But you can modify them to make it fit.
64 Nova guys will know that you are using the wrong year trim but depending on how original your car is it might not matter.
The 62/63 rocker molding can be made to fit the '64 Nova SS. However it has a different rib profile. It will also require some work to integrate with the '64 Nova 400 rear wheel/lower quarter trim to look right.
Bob
PS: Sorry 64PRONOVA. We must have posted almost at the same time.
B.
64NovaPro and CdnL79, thank you!
Separately, is the '64 rear wheel trim available as a reproduction? I see listings, but it doesn't look like the original piece...
