1 - 20 of 28 Posts
1963 II - 1963 Nova
Year: 1963
Model: Chevy II / Nova
Engine: 383c.i.
Body/Exterior: Stock except 4" steel Cowl, Color Black Cherry metallic with ghost flames
Front End: Moroso springs, lakewood 90/10 shocks
Transmission: 350 turbo, 2800 stall, shift kit
Rear End: 10 bolt, 3:50 gears, mini spool
Exhaust: Hooker Super Comp headers, 2 1/2 full with crossover, 40 series Flowmasters
Wheels/Tires: Jegs Sport Mag. Rear 15x7 with 215/70x15, front 15x4 with 165x15..
Interior: Custom cloth two tone seats and door panels, Monte Carlo front buckets, stock rear seat. Grant steering wheel, B&M shifter, Radio delete
Electrical: 2000 cfm Flexalite eletric fan, One wire alternator, Mallory and MSD ignition
Accessories/Options: Competition Engineeering J-bars, tied frame, Lakewood shocks, Gilmer alternator drive kit, heat sinc trans cooler
Sound system: See Exhaust above.
Additional Comments: still working on it but I'm enjoying it as I go.​
I would like to do somthing simular with my 63 ss as far as your rims/tires set-up... 15x4 in the front and 15x7 in the rear. Do you happen to know what the Vintiques rims off set is on yours??
The 15X7 are a 4" bs, and the 15X4 are a 2" bs.
Thanks ,
forgot to ask....I have a 2" drop front and rear and I have Wilwood disks all around which only pushed things out by a mere 3/16" front and rear. I also have a 10 bolt rear-end and stock Front end with CCP control A-arms upgrade kit. My question is do you think your tires would rub if it dropped 2" ? ...any recomdation on the offset??
Discussion Starter · #12 ·
Thanks ,
I'm not too sure about the 2" drop, my rears are real close now (can't get my fingers between tires and fender) and the fronts would be no problem if I was running a shorter tire.
Thanks - I guess that is where offset comes into play for the rear if I'm understanding things correctly...I can probably do the same tires but have a more offset rim inward?? On the front when you say shorter tire do you mean the overall dia profile. from the pictures it looks like they would work fine.
Discussion Starter · #14 ·
Yes over all diameter for the front , they are fairly close to the leading edge of the fenderwell.
O-yes I see it would rub in the front inside fender if it dropped down 2 inches. How does the car handle with skinny tires up front and fat tires in back? straight line around corners etc..
Discussion Starter · #16 ·
So far it handles pretty good, it tracks strait and rides good. I don't drive it in adverse weather and I haven't taken any hard curves without slowing down. The tires are ok for what I wanted to with the car and get the look I was after.
this things badass. i dig the SO-CAL covers.
1 - 20 of 28 Posts
