I had gone through 3 rebuilt carbs for my 63 also. Still runs rich at first. I finally got it right and also got the choke adjusted right as they run super rich and rough until properly warmed up. make sure the fuel line is good and has a good normal in line filter before it enters the fuel pump. Sometimes the float in the carb is not right and lets it flood. Also, make sure that you have a brand new harmonic balancer as you have a nice engine. I had the original one from 1963 on it and never once glanced at it. Finally I saw some rubber extruding out of it and replaced it with a brand new one. The difference was amazing as the car runs so much better and now I can actually time it right. One learns as time goes by. Also never buy the cheapest carb you can find. Ask around and get a reliable one. Holley used to have rebuilt ones so check around.
G-man
Did you buy a new balancer ? Would you still have a Part # and vendor name ... (for a 194 ci) ... just asking. Thanks
Thanks guys for your input. I am not a mechanic, so 6 yrs ago when I paid for a rebuilt engine and tranny, I expected all work to be good. This is in fact my second rebuilt carb in the last 6 yrs. Each year I end up with new plugs, points and condenser, which is cheap, but should not be frequired for driving it less than 1000 miles per year. The car gets stored from Nov - March, and so it does not run those months. I actually run high test gas all the time. I have brought this car to three different mechanics trying to get it to run right.
billb
would you think that you could have a vacuum leak .. the sixes are kinda known for maybe loose bolts around the intake/exh manifolds.
Cheap check --- spray some 'brake-cleaner' (I use starting fluid, but that's just me ... either way BE Careful). Also, spray (brake cleaner) around the connection at the "joint" where the intake / exhaust manifold bolt together. With the engine warmed-up & running ... listen to your motor --- any change in RPM's ?
I also, up-graded to the "PETRONIX Ignitor" igintion (PNX-11262A) system ... like 23 years ago (and, basicly have never touched it, since). ..... Great up-grade (for me anyway).
You said "to remove your air - cleaner (or get bigger air cleaner) , Does that DO ANY Thing ? ? (run better with the air-cleaner removed ?).
Hey ... I'm just asking ...
Then, the 'exhaust Flap' in your exh manifold .... is it working -- opening / moving / stuck ?
------- jim
