Your car looks really sharp great stance. I have 17 x 7 on my car . The tires have less sidewall height.
The wheels will very much fit stock and will get you a few benefits, besides a fresh look -Morning everyone. A few questions on 17” wheel fitment. Love the look of them, looking to understand the benefits of them in case I make a change to them.
I recently saw Church Boys listed a set of American Racing Salt Flats 17x7 rims for sale and it got me thinking.... My wife says that usually cost $$![]()
Current setup: 63 SS with 15” wheels, running 235/60 on rear and 195/60 on front.
Appreciate your help.
- Beside the look of the wheel/tire in the wheel well is there any benefit to a 17"?
- I assume a 17" has a larger inside diameter, does this allow the wheel to tuck in more?
- Is a 17" beneficial in clearing the front brakes, control arms, steering linkage?
- While running a 17” rim are you using tires that are the same height as a 15” (if I stood the mounted tires next to each other would they match up)?
- Assuming stock spring locations in a non mini tub car and stock suspension up front (except for zero offset disc brakes) what are the biggest size rims/tires you guys are running?
Thanks.
Not to highjack thread but I have the same size tires that Brooksey listed in his response on my 67. They are Hankook (tires on the rims when bought). They are pretty rough. Is there another brand that might be softer?If you're going to go to bigger diameter wheels, other positives for the 17's is there are a lot of options available for that size. And, there's still enough sidewall on the tires that they aren't as rough riding as the larger ones.
JMTCW
*Sweet car btw
1. The main performance benefit of 17" wheels over 15" wheels is the availability of many choices in modern tires and tire compounds. This is diminishing somewhat as 18"+ wheels are taking over, but still the tire selection for 17" offers many performance benefits if you are doing autocross or track. On the street they will improve braking and steering performance too due to added traction; this will usually not be noticeable, but will make a difference in an emergency braking or steering maneuver. On the other hand, if you are drag racing, there are better tires on 15" wheels for that application. Also, compared to 15s, 17s will often have an increase in noise and ride harshness due to the shorter tire sidewall. With 17" wheels, the lower profile tires will have a small improvement in gas mileage over the energy-sapping taller sidewalls on 15s.
You might want to try some other tires. We’ve been running a set of Dunlop tires on our WRX in a handful of autocross events and went to a new set of Michelin Pilot Sport All Season tires. The ride and handling characteristics are significantly better from the Dunlops. We’ve run them both at the same pressure and the Michelins are smother running and hold better in the corners..Not to highjack thread but I have the same size tires that Brooksey listed in his response on my 67. They are Hankook (tires on the rims when bought). They are pretty rough. Is there another brand that might be softer?
Softer ride? Or softer compound?Not to highjack thread but I have the same size tires that Brooksey listed in his response on my 67. They are Hankook (tires on the rims when bought). They are pretty rough. Is there another brand that might be softer?
