Is anybody running 15x7 rims on the front of their first generation Nova? If so what are you running for backspace and what size tires? I have a 63 and want to know if I could run these or if I need 15x6's. I know every car is different but wanted to see what people are fitting. :D
Thanks for any info !!!
Vendor
Are you running front disc brakes?If so are they "0" offset type? Or are you running drum brakes?On my lowered 67 with Chevelle style front discs I had to run a 15x5 with a 195-60-15 to not have the tires rub.This brake moves the wheels outward 1/2 inch each side.
I'm runnin' 15x7 mid 80's Camaro Iroc wheels with a 4 1/4 backspacing 195/50/15 tire 2" drop spindle and 4 wheel disc brakes , rear tires are 205/60/15
15x7's with 4.5 backspace will fit the back, and they "should" also fit the front. I think a 15x6 is better suited for the front. This is if you cars suspension is stock. Every car is different, so I suggest a wheelrite.
Discussion Starter · #5 ·
I have the wheelrite tool
and have discovered that it is a P.O.S. This thing is not very accurate with a piece of wire for a tire profile and flimsy plastic.I do have disc front brakes they were already installed when I purchased the car.I already have the rims but was going to purchase some tires for the front I wanted to put 205/60/15's When I measured with the Wheeljunk I mean rite tool it saying they will clear but It seemed to good to be true!:)
I have Greg Weld DragStar 92's 15x7's with F-70x15 Firestone redline bias tires.....they work well for me plus I have CPP front power discs......hope that helps.:D
I had 15x7 ralleys of a monte carlo with 205/60-15 euro T/A's back in the day on my 64. And that was with drums and disc brakes. Front end was lowered 2 inches from stock.
