I'm in the process of building my '64 moredoor. My goal is to have a pretty sweet sleeper when I am done. She originally had 13" wheels on her when I got her. I am thinking about keeping the 13" profile. When she is done she'll have the 327 backed by a TH400 (maybe) with a posi. I plan on running her mostly street. A buddy had me convinced to go with 355s but people on here suggest 308s if I am going to keep it mostly street. I still have time to make these decisions. I'm currently prepping the front end for a CPP upgrade. Should I keep the 13" setup? Will I need to order anything special with the kit from CPP if I do keep it 13"? Wheels are way down the road right now too, just tossing some ideas around in my head so I can do some research along the way for wheels/tires.
The biggest issue is fitting disc brakes into a 13 inch wheel, I’m 95% sure the caliper will hit the wheel. I had 14’s and they were close. Any kind of spacer that would allow it to clear would push the wheels out too far.
That is the first thing that popped in my head, I dont see any disc working up there
I knew it was probably a crazy idea but I had to ask.
Good luck finding tires in 13" much less wheels. Your 64 already has 5 lug axles so at least look at 14" if not 15" wheels and tires. They are still available and will maintain the sleeper look and still give performance.
