1 - 3 of 3 Posts
Hi guys I am doing the following: replace leaky oil pan gasket , replace brake pads all the way around , replace u joints I work on the car an hour here and there , when ever I get a chance (If the grand kids show up all bets are off so no hurry ) . What is the best locations for the jack stands the car is a ‘63 convertible. ( The car will probably be sitting on jack stands for about 10 days or so .)
Under the rear axle tubes near the spring perches, and under the front lower control arm near the ball joints. this makes everyting nearly the same as sitting on the ground on all 4 tires, the suspension is loading the body the same way.
thank you very much for your reply, I tried this out and my doors open and close perfectly no binding !
1 - 3 of 3 Posts
