A quick slick question - Chevy Nova Forum
Go Back   Chevy Nova Forum > General > Drag Racing Forum
Old 25th-August-2011, 02:06 PM   #1
Pandora's Box
(OP)
Pandora's Box's Avatar
Nova(s): 67 Nova Wagon 408"/700R4
Garage
What do some of you think about rotating your slicks (swapping from side to side)???
Good idea... bad idea???
Do you do it???
I've been asked if I do this, well I don't.
Somewhere in life I've been told that this is not a safe thing to do. Because once used the cords are trained in one direction they could come apart if made to go in the opposite direction.
True???.... Untrue???.... Old wives tail???.... What???
On the first day God created Hot Rods and Harleys-then came the Demo Derby to get rid of all the rest!
Old 25th-August-2011, 02:13 PM   #2
tannerman
tannerman's Avatar
Nova(s): '64 Sedan '66 Sedan
I actually rotated my slicks for the first time this year and have been keeping an eye on them very carefully. They seem to be just fine, getting great wear.
I have read on many forums that guys rotate them every 25 runs or so with absolutely no problem.
Old 25th-August-2011, 03:31 PM   #3
Fast Eddie
Fast Eddie's Avatar
Nova(s): 1966 Nova
I look for scuffing than rotate.
Fast Eddie
1966 Nova
408 cu in SBC
Aqua
Old 25th-August-2011, 04:30 PM   #4
tbills66
tbills66's Avatar
Nova(s): 66 SS
We rotated ours after years of not doing it. Not really sure it made any difference or not.
Old 25th-August-2011, 04:58 PM   #5
Real McCoy
Real McCoy's Avatar
Title: Moderator
I started rotating mine a couple years ago. It has definitley given me better life and tire usage. The sidewalls break down on mine. I roate about every 10 passes but MT says they would like me to do it every race.
God Bless America, land that I love
T/S 67 Nova 6.0 certified chassis, Aluminum 655 BBC, 4.50 ET
Old 25th-August-2011, 06:04 PM   #6
1320quick
Nova(s): 1971 Nova 1968 Chevy II
When I run the 28x10.5 MT Drags on my car, I rotate them every 3 passes. If I rotate them, I get about 20 passes per set. If I don't rotate them, I only get 12 passes.
Old 25th-August-2011, 07:30 PM   #7
aggravation
aggravation's Avatar
Nova(s): 1965 nova 4 door 331 ci
slicks
Well, I never rotate my slicks.. But after reading what all you guys are doing, sounds like I'am old school, I think I'll try rotating them.. Good post Pandora's Box...
Old 26th-August-2011, 01:29 AM   #8
Seattle_Mike
Seattle_Mike's Avatar
Title: Moderator
Absolutely rotate them, usually at least a couple times a race and always if we get tire shake. I was told to do this by some very respected chassis tuners who know a lot more about this stuff than me. I'm sure the type of car and power level have a lot to do with it as well.
68 Camaro Nitrous ProMod 848ci Buck Racing Engines
Old 26th-August-2011, 08:46 AM   #9
mikeorwan
mikeorwan's Avatar
Nova(s): Boring 11 sec. 350
huh?
12-20 passes a set of tires?
Seriously that seems crazy low to wipe out a set. My Hoosier bias slicks had 50 passes when I sold them to another guy and they appeared to have a lot of life left. Weren't even close to the bottom of the wear indicator holes.
My current MT drag radials had around 1500-2000 street miles, 103 passes and now have cords showing.
Admittedly I only really heat them up the 1st pass of the day with much smaller burn outs after that.
I reject your reality and substitute my own!
1.587 60', 11.615 1/4
Old 26th-August-2011, 12:56 PM   #10
1320quick
yep.... The car weights 3450lbs and runs 8.70's at 165mph with 60's in the low 1.30's on a 28x10.5 ET drag. That car just wrecks the sidewalls. We don't wear out the tread. I sell them to guys with 11-13 second bracket cars that run 1.50 and slower 60's and they run them for another 100+ passes.
Old 26th-August-2011, 01:01 PM   #11
Pandora's Box
(OP)
Garage
Yep!
Same here!
I'm going out to the shop to flip them right now and then onto the trailer for this weekends "Gold Cup" 2 day event.
Old 26th-August-2011, 02:00 PM   #12
Ricky B
Ricky B's Avatar
Nova(s): ~'63 wagon~
Originally Posted by Pandora's Box View Post
Yep!
Same here!
Good luck Bro !!!
Bajito y Suavecito.....Longroof Soc.....
Norcal Novas
Mark 10:27 !
Old 26th-August-2011, 03:08 PM   #13
Seattle_Mike
Title: Moderator
Good luck this weekend to all who are racing. We're headed up to Canada for the final of two Bad Dog Shootout races which is being held in conjunction with the big Night of Fire event this weekend. We won the first race, so looking to repeat if all goes well.
http://www.speedzonemagazine.com/zon...tout_index.htm
Old 26th-August-2011, 06:16 PM   #14
77xbody
77xbody's Avatar
Nova(s): 77 nova
do run the stiff side wall ? well any way i rotate side to side every time i go out
[email protected] 1.37 60'
[email protected]
433 BBC @ 3600lbs
Old 26th-August-2011, 06:28 PM   #15
1320quick
The current set is a stiff sidewall tire. In the past, we used the standard sidewall slick as we struggled to get the car to hook for some reason on the stiff sidewalls. We found a major problem (twisted spring perches) so we shall see if the stiff walls work now. We have changed a lot and hope to be more successful with our new setup. Regardless, not trying to hi-jack the OP thread. Just saying my experience is that we get better life out of our slicks by rotating them....
Slick Question Novaman1973 Drag Racing Forum 3 27th-June-2011 11:47 AM
Phoenix racing slick advertisement question thetpro1 Drag Racing Forum 9 2nd-July-2009 10:24 PM
Quick Question Hairball II Body and Interior 0 4th-May-2008 12:19 PM
street slick size question bdog Drag Racing Forum 4 28th-August-2007 12:00 AM
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Lt
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
