How to: Bumper Tuck - Chevy Nova Forum
Go Back   Chevy Nova Forum > Non-Technical > 4th Generation Nova's
Old 12th-November-2010, 02:20 PM   #1
lil Scriv
(OP)
lil Scriv's Avatar
Nova(s): 1976 Nova 350
How to: Bumper Tuck
Well there was a Post awhile back about How to Tuck the a Bumper on a 4th Gen so I figured I would give it a go and post up the Results and also maybe help Someone else along the way. It's really easy. took me about 45 Mins and Basic Tools.
To start off I Pulled the Bumper off. there are 8 11/16th Nuts on the inside. be careful taking the last on off as the bumper could fall on you and it's Very Heavy. I would Recommend having someone there to hold it on.
Sit the Bumper aside ad get Yous drill out. I used a 1/8th inch Drill bit for this. I drilled the Hole on the Lip of where the Shock is Mounted to the Frame, That way I could run a Screw into the Hole when I was done to hold it in Place. Here is a Picture to help you get a Better idea, if you do drill the Hole there you will have to go Through Two Layer of Metal. There should be a Puff of Air when you get all the way Through.
Note: The Picture was Taken after I Compressed the Shock.
After I Drilled the Hole I took a 2x4 and a Big Hammer and Compressed the Shock
Then I Welded the Shocks in place. Note: You don't have to weld it. You Could just use a Screw if it's Easier for You.
To still be able to use the Bumper filler panels I had to Slightly Trim Them.
Then you just have to Reinstall the Bumper and Your Done!
Hope this Helps out Someone that is looking for a Easy way to Tuck there Bumper.
Sometime if I can find a Extra Bumper I'm going to look into cutting up the Bracing inside the Bumper to Lighten it up. If i had to guess Right now it's sitting at every bit of 60 Ibs and I bet I could knock about half that off.
-Robert
Hugger Orange 76 Chevy Nova 383 Stroker th350 3.42 Posi Track
351 HP 412 TQ, Weighing in at 3280Ibs
Old 12th-November-2010, 02:27 PM   #2
Philip
Philip's Avatar
Title: Moderator
Did you have to trim the center filler too? How far in did it move?
63 Nova Wagon
64 Nova 400 series 4 door
SOLD 01/15
Old 12th-November-2010, 02:56 PM   #3
lil Scriv
(OP)
lil Scriv's Avatar
No I didn't have to Trim the center Filler at all. Just the outers. The Bumper moved in 2 1/4 inchs. I just pushed the Shocks all the way in. Also I need to add if I had a Stock a Hood I don't think I could use the Hood latch. Because the bumper is now almost Touching the Latch handle.
-Robert
Old 12th-November-2010, 05:14 PM   #4
Philip
Philip's Avatar
Title: Moderator
It looks real good moved in. The bracing on the back is over kill. Most of that chunk of steel behind the bumper can be removed just leaving enough to mount the mount bumper. I weighed the complete assembly with the shocks and it is 80 lbs.
63 Nova Wagon
SOLD 01/15
Old 12th-November-2010, 05:39 PM   #5
lil Scriv
(OP)
lil Scriv's Avatar
Wow! 80 Pounds. I knew it was Heavy but Dang! And Like I said I bet at least Half of that is is The Bracing inside it. I want to remove A lot of the Bracing and I'm worried about taking to much off and then not having a Bumper. that's why I'm going to wait till I have a Extra.
-Robert
Old 12th-November-2010, 06:07 PM   #6
Philip
Philip's Avatar
Title: Moderator
Remember there is one in the back that weighs the same . I have been wanting to move my front one in, but the back I am going to leave as is.
63 Nova Wagon
SOLD 01/15
Old 12th-November-2010, 06:38 PM   #7
lil Scriv
(OP)
lil Scriv's Avatar
Same here on Not Tucking Back, I don't think I could make the Filler Panels look good. But if I cut out the Bracing on the Front I'm going to do the Back as well. Double the Weight Saving.
-Robert
Old 12th-November-2010, 07:59 PM   #8
Philip
Philip's Avatar
Title: Moderator
Well you are also getting ready to add about 20 pounds to the front
63 Nova Wagon
SOLD 01/15
Old 12th-November-2010, 08:37 PM   #9
elvera
Cool, I wanted to try it, but now am worried I wont be able to pop my hood.
Old 12th-November-2010, 09:00 PM   #10
Philip
Philip's Avatar
Title: Moderator
Might not be an issue. The latch can be reconfigured to work. I have at least one extra laying around and planned on looking into possible mods on that one.
63 Nova Wagon
SOLD 01/15
Old 12th-November-2010, 09:24 PM   #11
ProNova
ProNova's Avatar
Nova(s): 1976 Pro Street SS clone
When I compressed my shocks All I did was put a metal screw in it to keep it from going back out, No welder to use when I did it, Has worked just fine, Second on mine I cut the plastic like he did but I removed the metal filler in bewteen bumper and grill, Also i cut off the hood Release just above the bracing in back side of bumper and drilled a hole in it and attached a cable with a loop in it, It isn't seen and all I do is I made a handle that slipd into loop and I pull it and hood pops, A friend of mine attached a piece of metal on his and it hangs out on his bumper I didn't want that,I had looked at so many tucked bumpers and could never decide to do it or not, But now that I have done it I am so glad I did it,I love the look
Bruce NNN Member #41221 Prostreet Fraternity
Old 12th-November-2010, 10:09 PM   #12
lil Scriv
(OP)
lil Scriv's Avatar
Like I said above you can use Screws too. It's just that I had a welder handy so I figured I would make good use of it. Yeah that Sway bar is Heavy. I just Finished Painting it and it's sitting in My room waiting for the Morning to be put on the Car. Too bad we just cold front in suppose to get down to like 40 Tonight I would think there would be a good way to work around the Hood latch. It's just I figured I would put that up there so nobody would have a Nasty Surprise when they Finished tucking the Bumper on there own Car.
-Robert
Old 12th-November-2010, 10:32 PM   #13
edrednova
edrednova's Avatar
Nova(s): 1977 chevy nova
Garage
-Robert[/QUOTE]
im glad you did cause that could have been me. thanks!! good job by the way. did you drill the side or the top of the shock? maybe you could bend back the hood latch?
Old 13th-November-2010, 12:49 AM   #14
Novajay
Novajay's Avatar
Great thread! Bruce, do you have a close-up of the bumper filler panel and the hood latch mechanism you've created?
I like the look of how the bumper filler panel blends upward into the grille. But if the bumper gets tucked then the curved portion of the panel will be hidden behind the grille. The only solution that comes to mind is to section the panel from side to side and make it smaller, but it's small to begin with.
Old 13th-November-2010, 10:46 AM   #15
ChevyBelly
ChevyBelly's Avatar
Nova(s): 1978
Finally!! thank you lilscriv!
Front Bumper Tuck on a 74 fonecop1 Body and Interior 5 10th-September-2017 10:01 PM
74 Front Bumper Tuck Fasazu2 3rd Generation Chevy II/Nova's 11 19th-February-2011 01:34 PM
bumper tuck dws909 4th Generation Nova's 7 7th-June-2010 11:21 PM
Bumper Tuck Tack 1st & 2nd Generation Chevy II/Nova's 9 14th-March-2010 05:00 PM
Front bumper tuck Jake2 3rd Generation Chevy II/Nova's 2 10th-January-2009 11:49 PM
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Lt
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
