LED's don't work - Page 2 - Chevy Nova Forum
Go Back   Chevy Nova Forum > Body, Chassis and Mechanical > Electrical
Old 6th-September-2019, 04:40 PM   #16
laser-red-nova
(OP)
laser-red-nova's Avatar
Nova(s): 67 SEDAN
Well I got my 7 ohm resistors. No luck. Still can't get the LED's to light . If I hook up my test light to ground and the pointer to the hot wire on the LED then the LED blinks. I measured the resistance in the test light 7 ohms just like my resistor. I wired the resistor in line with the hot wire for the blinker. I can't figure out why it won't work with my resistor. You can't ground the LED housing it is plastic. I'm lost
Old 6th-September-2019, 05:32 PM   #17
laser-red-nova
(OP)
Nova(s): 67 SEDAN
Update: After some more searching on google I found out that when you wire in the resistor you don't wire it inline with the blinker side , you connect the resistor between the ground and hot wire. Wow it works. Thank you Mr. Google.
Old 6th-September-2019, 05:55 PM   #18
Mike Goble
Mike Goble's Avatar
Nova(s): 67 wagon project
Originally Posted by Mike Goble View Post
The LED's probably don't draw enough current to operate the flasher. Try putting the LED's in parallel with the original bulb. Many LED turn signal kits come with ballast resistors.
As I said a few days ago - put them in parallel...
I'm Mike Goble and I approve this message.
Old 6th-September-2019, 06:38 PM   #19
laser-red-nova
(OP)
Nova(s): 67 SEDAN
I guess I didn't realize that was parallel. Sorry
Old 10th-September-2019, 08:19 PM   #20
laser-red-nova
(OP)
Nova(s): 67 SEDAN
Update picture of LED's in my turn signals. Took them out of the bumpers
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Lt
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
