Edelbrock Question - Chevy Nova Forum
Old 2nd-October-2019, 06:55 AM   #1
kimrobertson
kimrobertson's Avatar
Nova(s): 79 Phoenix
Edelbrock Question
I have an Edelbrock 1406 with 2 idle mixture screws in the front. When I adjust the idle mixture the idle speed will change when I turn the right screw but nothing happens at all when I turn the left screw. Is this right or does this indicate a problem?
350/Tremec 3650 5 Speed/3.73
Old 2nd-October-2019, 11:54 AM   #2
chevydealer35
Nova(s): 1973 SS HatchBack
Edelbrock Question
I have that carb in a box in my garage. lol Mine was on my Nova when i bought it & someone removed the top to do something & reinstalled it incorrectly bending the hell out of one metering rod. bent so bad it hung up the float on that side. They are a good carb if you know what to do when tuning.
Now your case---1st pull out the idle mixture screws completely & use carb cleaner & compressed air to clean out idle passages.
2nd reinstall & set idle speed no higher than 550--600 rpm to make sure the throttle blades are not in the transfer slots yet.
3rd use a vacuum gauge to adjust mixture screws---this worked well for me . I've done carb work for 40 years so i set float levels ---bought the Edelbrock kit with rods & jets & springs ---had a good time tuning. Mine was a 1406--mechanical secondary--electric choke unit. They work nicely if you use the 1405 chart to tune them with the different rods & jets. Much richer mixture.
Old 2nd-October-2019, 02:52 PM   #3
kimrobertson
Nova(s): 79 Phoenix
Thanks chevydealer35... I had it working very nicely for months till I retarded the timing by 2 degrees...It idles fine but doesn't want to run smoothly with minimal load (I assume too lean). For example at 1900 rpm in 3rd at 25 mph, it lurches back and forth.(looks like I don't know how to drive ) Light throttle to WOT it's fine.
When I read your response I had actually just taken the left adjustment screw out and cleaned it. I shot carb cleaner in too everywhere else I could find a hole. Then I was able to get a response on adjusting the left screw... It is a little better but definitely still there.
Weird how this issue just showed up when I changed timing from 11 degrees advanced to 9 degrees (currently back to 10 degrees) without doing anything else. I did have carb apart 2 years ago--adjusted floats, cleaned real well. I also have the calibration kit and have played with the springs and metering rods and jets too to get it the best overall performance. But the metering rods and springs only impact throttle response and mixture under acceleration I think.
Oh, I also put a bottle of carb cleaner in the gas tank and have mostly pure (non-ethanol) in it now.
Maybe my issue isn't the idle circuit
Old 2nd-October-2019, 05:34 PM   #4
kimrobertson
Nova(s): 79 Phoenix
How much air pressure would you recommend for this?
Also, reading through the Edelbrock owners manual...seems like I need to choose a richer combination metering rod/jet. I will try a combination that will richen it at low to moderate throttle.
Old 3rd-October-2019, 12:50 PM   #5
chevydealer35
Edelbrock Question
I use a rubber tip blow nozzle with my air compressor---the blow gun will limit the pressure for you ---unless you drilled it out .
Use the 1405 chart in the paperwork that came with the tuning kit---the 1406 chart is not rich enough.
Old 3rd-October-2019, 02:39 PM   #6
kimrobertson
Nova(s): 79 Phoenix
ok- Thanks for the tip re the 1405 chart... I can regulate my air pressure so I think I will keep it on the lower side.
Old 9th-October-2019, 11:32 AM   #7
kimrobertson
Nova(s): 79 Phoenix
Found the problem! I had mismatched metering rods. I had mis-read the tiny numbers and had a 7347 and a 7342 in. I switched to both 7342s and that solved the problem. The 7342s being smaller helped richen the mixture which was too lean on light throttle just off cruise.
Thanks chevydealer35 for the help. BTW nice looking engine! Where did you get your alternator bracket?
