1/8 & 1/4 mile times - Page 2 - Chevy Nova Forum
Go Back   Chevy Nova Forum > General > Drag Racing Forum
Old 14th-January-2005, 11:39 PM   #16
Don Johnson
Originally Posted by Fast72buick
GM did have some very good Cyl. head castings That Many believe don't perform as good as aftermarket
here is my old 468 B.B. Combo. that i ran in my Old Tubbed out 71 Chevelle at 2,960lbs. with me aboard.,
.060 over 454
GM 454 Steel Crank,
GM Re-sized 3/8th's rods,
12.5to1 TRW's
Block Decked to achieve .004 Piston outa-deck (Above deck)
990 Cast Iron heads Decked .050 (Un-ported runners,Bowl blend)Stock Size 2.190-1.880 Stainless valves with a 11/32th'ds Valve stem,
Luntai Flat tappet Part# 40216
Outa-box Holley Strip Dominator 4150 Intake with 1 inch open spacer
APD Alky 800 with 850 Base-plate
5,300 Convertor
1.76 Powerglide with Brake
4.56 Gears (9 Inch Ford)
Goodyr. 33x15x15 Inch Slicks
Launch Rpm off Brake at 4,300
shifted at 6,500 seeing 6,700 through traps.
1.36 60 Footers
6.teens at 111-112 mph eighth Mile
Low 9.70's at 136-137 mph>> Natuarrly aspirated
Same Chevelle at 2,880 lbs. with 1 of my 406 S.B.'s
.030 over Half-filled 400
14.3to1 compression
JE Ultralight Custom Pistons
6 Inch Carrillo Rods
Eagle 4340 Internally Balanced Crank
Pro-Action Iron-Lightning 235's fitted with 2.080-1.600 Valves (Minor Bowl blend) Decked .025 to Achieve a 60 CC Chamber,
Lunati Solid roller Part # 50110 280-284 @ .050 .640-.645 Valve Lift with 1.5's
I Used Crower Stainless steel 1.6 rockers on Intake/Exhaust Generating a theoretical valve lift of .683-.688
CFM Performance Prepped # 2925 Edelbrock Intake/1 Inch Open spacer
1120 CFM APD Alky Dominator
Same 5,300 Convertor
Same 1.76 Glide with brake
5.14's out back
Same goodyear 33x15x15 Inch Goodyear Slicks
Launch Rpm off Brake 4,300
Shifted at 7,000 seeing 7,100 through traps
60 Footers Mid 1.32's
Eighth Mile Mid 6.teens at 110-111mph
High 9.60's at 134-135mph>> Natuarrly aspirated
Yes The S.B. WAS Faster than the B.B. at 80 Lbs. less
BUT,
The S.B. Cost more to build.
Another GM Headed Combo. used in my old 69 Camaro
HEAVILY PORTED GM Iron Bowtie Heads 034 Castings Decked .060 to Achieve a 54 CC Chamber
Manley Gas-port Pistons 13.5to1
Manley 6.00 in. Aluminum rods
GM # 1182 Steel Crank (Lightened up),
.030 over Unfilled 350 4 bolter
Lunati # 50140 Solid roller 276-284 @ .050 .640-.645 Lift
Crane Gold Aluminum 1.5 Rockers
Ported Super-Vic Intake 2 Inch open spacer
APD Alky 750 CFM Carb
5,800 Convertor
Turbo 350
4.88 Gears stuffed in a narowed 57-64 Olds Rear
32x14.5x15's Goodyr. slicks
Footbraked Car (No Transbrake)
1.38-1.39 60 Footers
Shifted at 7,200 seeing 7,400 through traps
Mid 6.50's at 106-107mph
Mid 10.20's at 129-130 mph>> Natuarrly aspirated
Can go on and on about the Drag cars/Combos I've ran/used
Only engine ever dynoed out of ALL of them above was the 406 that i ran for 4 Yrs.
It made 643 hp at 6,900 along with 576 ft. lbs. of torque at 5,300
It does'nt Take 750+ hp to go 9.'s at 135 mph like post above stated,
Nor will a set of Dart 23* Heads Flow in the 360 Range
320-330 TOPS and thats after they receive some hand Porting After they've already been CNC Ported.
If you need a Engine built,Powerglide Built,Etc.
Drop me a E-Mail at [email protected]
Also Please check out my Friend John Kyle's Business at www.apdracing.com
Nice Little Tube Chassis Corvette on there Driven by Barry Ballard
Powered by APD Built 632 Cu. Incher Utilizing a set of 14.5* Pontiac (Sonny Leonard Ported) Cyl. Heads
This Little Ol' 632 Cu. Makes 1360+ hp>> Natuarrly aspirated at 8,300 on Superflo
Sony Leonard Sheetmetal Intake
Twin APD 1250 CFM Gas Dominators
APD Built Powerglide
Race ready at 2,550 (with driver)
Has been 6.92 at 203 mph with a 175 Shot
7.20's >>Natuarrly aspirated
I do a tad bit of posting on DRR,
I Go by the Name of RICKp
www.dragraceresults.com
Talk soon.,
Rick
Rick, it does take that kind of HP when you are pushing a car that weighs 3,250 lbs without me in it. As for the heads there was extensive hand work done on these heads to include filling on the intake side.
Old 15th-January-2005, 11:26 AM   #17
badass70_nova
badass70_nova's Avatar
Nova(s): 1970 "NastyNova" 10.5" Car 1970 Pro
Rick I disagree! I have a 70 Nova that tips the scales around 3190# with me in it and I ran 9.90's and I have right at 750HP give or take a few. Now keep in mind if you have a 2200# full blown drag car then NO it will not take 750HP to run 9's @ 135....that's common sense! I'd like to see you prove how a 3200 or 3250# car can run 9's without 700 or 750HP.....I'll be waiting for your reply......
Old 15th-January-2005, 04:24 PM   #18
Fast72buick
Here's my reply These ARE Specs. on a 441 B.B. Chevy.,
This engine was dynoed on a Super-Flo engine Dyno. at Gressman Powersports here in Fremont Oh. (Not a desk top dyno figure),
.060 over 427
Huggings solid roller 268-276 @ .050 .687-.693 Lift
12.7 to 1 compression
GM Square-port cyl. heads,
Dart 4150 Intake
APD Alky 750
GM 3/8th's In. rods fitted with ARP Bolts
GM Steel Crank
This Simple little 427 B.B. Chevy Runs 10.40's at 127mph in a 3,600lb. (With driver) Natuarrly aspirated Tubbed out using 32x14.5x15 inch goodyear slicks, Stock front Suspension sitting in-between the Frame-rails of a 1984 Chevy C-10 Shortbed Pickup Truck,
Now cut 400 Lbs. from this truck/and say put it in your Lighter 3,200 lb. Car and you'll see the 3-4 tenths Faster ET. With a MPH Increase in the neighborhood of 4-5 mph IN Short generating 9.90's to low 10.0s at 134-135 mph in a 3,200 lb. Car.,
MPH IS The factor of How much HP your engine is Producing/at the weight.
Truth is,
This engine only Made 637 hp at 6,800 along with 581 Ft. Lbs. of torque at 5,500 on the Super-Flo Dyno.,
Using the Correct Barometric Pressures Logged in from the Fremont Airport/Along with the Correct Altitude Entered in from Same Airport.,
UNLESS this Correct Info. IS Logged in the computer/Dyno. upon making a Pull.,
You CAN Simply enter in ANY Mis-leading Info. and Make a True 500 HP engine Look to produce 700 Mis-leading Horsepower if you'd like it to/But it does look good on paper.,
The 3,600 Lb.+ C-10 Pick-up truck Truck Uses a>>
Coan 5,500 Convertor
Coan Turbo 400
9 Inch ford with 4.56 gears
Is launched off Footbrake,Shifted at 6,500 and sees 6,700 through traps in quarter Mile.,
60 Foot Times are Mid 1.44's,6.50's in Eight Mile at 107-108 Mph along with the Low 10.40's at 126-127 mph.,
This is my old 540 B.B. Combo. it produced a TRUE 813 hp at 7,200 with Torque in the 670 range at 5,900. on Same super-flo engine dyno. used to dyno. My Old 406 in first reply,along with the .060 over 427 mentioned above.
GenVI 502 Block .030 over for a 4.500 inch bore
Eagle Internally balanced 4.250 Stroker Crank
Outa-box Dart Pro 1 345's 2.300-1.900
Eagle 6.385 Length rods
Off the shelf JE/SRP Pistons at 12.5 to1 Compression
Outa-box Dart 4500 Intake/2 In. open spacer
Reed Solid Roller 278-284 at .050 .779-.787 Lift
APD 1250 CFM Alky Dominator.,
This engine when ran in a 2,001 225 WB Spitzer Chassis dragster ran Deadly Consistent Round winning 7.82-7.84's at 168-169 mph.,(This 540 was replaced with a 1,250 TRUE HP 632 Cu. Incher as shown on APD's Web-site,and now is runing in the 6.80's at 201-202 mph),
The 540 was placed in my OLD 72 Buick Skylark Tube Chassis Dragcar at 2,610lbs. (with me aboard) and ran Mid 8.60's at 156-157 mph with 60 Footers in the Mid 1.22-low 1.23 range off transbrake at 4,800 with 5,500 convertor and a BTE Equipped 1.80 Straight cut equipped Powerglide Trans.,
Now,
Say you add say 600 lbs. to the Buick/Or put it in your 3,200 Lb. Nova you'd still be going High 9.teens to Very Low 9.20's in the High 146+ MPH Range with the Same 540 Making 813 hp.,
In short explaining the Not having to have 750+ Hp at 3,200+ Lbs. to produce 9.90's at 135 mph.,
Not at all busting your Guy's Combo's/Cars.,
Just showing you a Couple engines that WERE Actually placed on a engine dyno.,
Along with the CORRECT Info. logged in,And the Times/MPH these engines run at a given weight.
Old 15th-January-2005, 10:52 PM   #19
badass70_nova
Thats just way to much rambling for me to read all the way through....so you win on account of me forfeiting the post........
Old 15th-January-2005, 11:11 PM   #20
DriveWFO
DriveWFO's Avatar
Nova(s): 74 Nova...R.I.P
LMAO! It's nice to see ya back on the board
Never pay again for live sex! | Hot girls doing naughty stuff for free! | Chat for free!
Don't worship false idles
Old 16th-January-2005, 06:03 PM   #21
badass70_nova
Yeah I was off for a while to just to many things going on, but I'm back for about 2 weeks and then I won't be on here much at all until the all the racing is done
Old 19th-January-2005, 08:57 PM   #22
Stan D.
Stan D.'s Avatar
Nova(s): 1976 Nova
1976 Nova full interior, 8 pt roll bar, stock fuel tank total weight w/driver 3590 lbs.
327 chevy
.100 dome KB pistions
eagle H-beam 5.7 rods
forged steal crank ground to small journal
decked at 9.005
balanced
Edlebrock: rpm perfromer heads 64 cc
rpm perfromer intake
rpm performer cam .488/.510 lift hydraulic
Hp 750 4150 carb
moroso water pump drive kit
edlebrock victor jr alum. water pump
electric fan
Msd 6al ingition
Msd distributor, locked out at 38 deg.
T-350 tranny
3500 custom stall
full manual valve body
4.88 gears
ford 9"
26"x9" Hoosier quick time pro street slicks
At firebird in boise, ID
1.701 60'
12.45 1/4
107.54 mph
At Mission Canada
1.670 60'
12.154 1/4
109.93 mph
Nova Row Racing
I feel the need for speed
1976 Nova 406 ci 10.250 131.02 mph 1.420 60'
Old 19th-January-2005, 09:13 PM   #23
DriveWFO
DriveWFO's Avatar
What tire pressure you running, Stan?
Old 20th-January-2005, 12:10 AM   #24
Qwk
Qwk's Avatar
408 SB
"509" block, filled, Milodon Splayed caps
Lunati Pro Series Crank
Eagle H beam Rods
Ross 13+ to 1 compression pistons
Dart 220 Raised Runner Alum Heads, ported
Jesel 1.7 & 1.6 rockers
Comp Roller, Lifters, Valve train
Comp Belt drive
Dart intake
Holley 950 HP
N.O.S Pro Shot Fogger
Small 1 3/4 Coated Headers
3" Exhaust Borla mufflers
Backed with a PG
8" converter
Ford 9" 35 spline 4.3 gears
All Steel 66 (67 front end)
Custom Audio 10 disc changer
Corbeau Seats
Cert 10 point (Blue Tag)
Drove to the Track and Home...36miles on the Highway, mostly.
[email protected] NA
[email protected] w/36 jets in the Nozzles
Old 20th-January-2005, 01:58 AM   #25
Green Machine
66 nova 3110 with driver
355sb N/A
afr 210heads flow 300cfm
14.2compression
276/[email protected] .660lift
1 7/8headers fender wells 950hp
manley pistons eagle h-beam rods gm crank
28x9 slick
powerglide 5200stall no trans brake
4.56 8.2 10 bolt stock axles auburn posi
[email protected]
first and only time at the track
1.50 60 foot
1/8 [email protected]
1/4 [email protected]
car was under geared and under stalled I think it will go 10.30's set up right
with trans brake. estimated 600hp
im shooting for the 9.9's with a stroker crank windage tray 15 to 1 compression and 1000cfm carb and a set of 1.7 ratio rocker arms also im putting a 12 bolt in.The 385 should like 4:56gears and 5200 converter
Old 20th-January-2005, 12:53 PM   #26
Fast72buick
Originally Posted by Qwk
408 SB
Eagle H beam Rods
Comp Belt drive
Dart intake
Holley 950 HP
Backed with a PG
8" converter
Corbeau Seats
NICE!!.,
You Familiar with the Lil Gold Deuce from Port Clinton Ohio?,
Got best Editors award at the 2,002 Super Chevy Show at Norwalk Raceway Park in Norwalk Ohio.,
66 Deuce (Daily Driver)
3.5 Inch Full Exhaust
9 Inch Ford 3.90 Gears
MT ET Streets 9.5 wide
10 Point Cage
Full Interior
OEM Gas Tank (Un-Hooked),Fuel Cell in Trunk
Slapper Bar Rear suspension
421 Cu. Inch S.B.
Brodix 23* M2 Track 1's
Callies 3.875 Stroker
5.7 Eagles with L-19's
Half-filled OEM 509 2 bolt Main/Splayed Caps
Crower Flat tappet Cam
JE 12to1's
APD 950 HP Gas Carb
NOS Fogger
Powerglide leaving off Transbrake in High Gear Only (For Traction issues),
3,320 with driver
Nice Lil Sleeper
10.teens at 132-133
Last season Best with the Juice (Still Tuning Suspension) 8.93 at 156mph
Mini Tubbed in the Making
Ladder bar along with a True 10 Inch Tire/ET. Street's for some Improved traction for some mid 8.70's through the Muff's
Beings your From Ohio.,
May know of this 1 as well ,
It's from Castalia Ohio
Lil Black/Purple Pearl 65 Mustang
Un-Tubbed 10 Inch MT ET Streets
3.5 Inch Full exhaust Dynomax Bullet Muff's
Dana 60/4.33 Gear
3,510 with driver
10 Point Cage,
Cell in Trunk/Gas Tank still under Car un-hooked
Full Interior
347 Ford Combo. (NOT Like Most 347's)
SVO Ford Block 4.155 Bore 3.25 Bryant Crank
6.125 Length BME Aluminum Rods Rods with Chevy Pin
5 Speed Liberty Manual Trans.
NOS Fogger
Best of 8.83 at 157mph at Dragway 42 pushing the head gaskets out
This Lil Ford has Never been ran off the bottle at the track,
Gets driven on the street (Very limited)
and now that the receiver grooves in Heads have been welded up and cut correctly It'll now get a Full pass Not pushing the O-Rings out of the Head causing water to get in oil and make a Good Clean Run,
8.70's this season
The Lil OL Ford leaves the line dumping the clutch at 6,000
pulling 2-5th gear at 8,500 seeing 8,800 through traps in Quarter Mile for the Past 3 Yrs. with this Lil Girl.,
Neither Or will pass down a Nice Little wager on the street/strip
asd that was what they were built for "Sleepers"
Old 20th-January-2005, 02:06 PM   #27
Stan D.
Stan D.'s Avatar
Nova(s): 1976 Nova
Drive wfo
I run 14lbs, I have tried more and less but 14 works the best.
Nova Row Racing
Old 20th-January-2005, 10:04 PM   #28
Qwk
Qwk's Avatar
NICE!!.,
10 Point Cage
Full Interior
421 Cu. Inch S.B.
JE 12to1's
APD 950 HP Gas Carb
NOS Fogger
3,320 with driver
Nice Lil Sleeper
10.teens at 132-133
Dana 60/4.33 Gear
3,510 with driver
10 Point Cage,
Full Interior
NOS Fogger
8.70's this season
156mph?? Damn Looks like I need to do some tuning on my II.
Kick *** for you though
You have any pictures??
As for those other guys, sounds like they are up north, Im down here in Cincinnati.
Old 22nd-January-2005, 01:32 AM   #29
Fast72buick
Qwk.,
Port Clinton is approx. 12-15 Miles from Fremont (30-35 Miles from NRP)
Castalia is around 15-20 Miles from Fremont (25-30 Miles from NRP),
I'm located exactly 38 Miles from NRP (Norwalk Raceway Park),
148 MPH is a very good MPH for a 9.18 ET.,
These Guy's are Spaying a 400 Shot of the Go Fast Juice ,
The Lil Deuce Has'nt been hurt in 2 Yrs./And Does get driven Quite often on the Street,
After it received Norwalks Super Chevy Show Best Editors award in 2,002,
Fuel cell in Trunk was Re-filled,and the Lil Deuce was On It's way into the City of Downtown Norwalk for Ice-Cream Cones for the Kids
The Ford IS Constantly apart for the Head Gasket Failures,
Has Had NO Success Using Fel-Pro Full Race Series head Gaskets,The High $ 3 Piece Cometics Head gaskets,Nor Copper Head Gaskets with Sealant along with the O-Rings.,
The Ford Has NO Issues when spraying 300-325
After looking at the receiver grooves in the Cyl. Heads,
It was very evident of the Receivers being cut to deep in the heads from a shop in Tiffin Ohio (I Don't mention any names,as Not intented to give anybody a bad name),
Heads Are Now Welded back up,Re-decked,and are in the process of getting sent to Fast Times to have the receiver grooves cut in heads again (Properly),
He says He'll be happy with the Current times (A Tad faster with Cyl's sealing up properly),along with it being Maintenace Free like the Lil Deuce is.,
But i woud'nt be afarid to bet He'll then just add a Plate and Further push the envelope again.,
As He said Once he Got His 8.8 Sec. ET. Car would go back down to a 300 Shot
Not sure How to Post Pics. on Here,
Have Pics. of the Mustang/along with the Engine,Etc.
The Deuce keeps a Low Profile to keep it's "Sleeper" Attitude for the Street,
As He does alot of High $ Street Racin',
He Usually Keeps a 275 Shot when at the track to Slow Car down to throw off Any "Takers" watching Him Run then throws the "Smack" Down with the 400 Shot
You'd More than Likely see a Gain in Performance by Having your Current Carb set up by my Buddy John at>> www.apdracing.com
The Mustang Gained a Full Tenth and 3 MPH,
More than Likely get you a 9.0 Pass at 150+ by a Simple Carb swap
If you Click on this Link and View this Corvette You'll see It's Ran Using a Natuarlly aspirated APD Built 632 Cu. Incher with a APD Built Powerglide and Twin APD 1250 Built Dominators.,
This Corvette Goes LOW 7.20's on engine alone (Car weight is a Tad over 2,500 with Barry Strapped in),
Makes 1,360+ hp at 8,600 on Superflo using a set of Sonny Leonard 14.5* Pontiac heads (Ex-Pro Stock Technology),
This Corvette goes Mid 6.90's at 202-203 mph with a 200 Shot.,
If you Strapped this 632 and Placed it on the Juice in a Dragster Look out
http://www.apdracing.com/news.asp?ID=27
If you Know how to Post the Pics. here,
I Can send them to you By way of E-Mail for them to be posted if you'd care to post them?
[email protected]
Talk soon.,
Rick
Old 22nd-January-2005, 02:40 AM   #30
Qwk
Qwk's Avatar
Norwalk is one of the BEST Tracks!!
Here is where I host my pictures at......
www.picturetrail.com
Pretty good site, not too expensive and I have never had any problems with it. Sign up on there and get those pictures up.
I have some videos of my Nova running a couple years ago.
HERE
Just click one the Videos section and scroll down.
The Nova had Fiberglass Deck lid and Hood on it back then nad a N.O.S Double Cross plate on it.
Craig
1/4 times 68_RATPOISN Best of 3rd Generation 124 12th-September-2012 03:57 AM
Post your 1st/2nd Gen Chevy II/Nova 1/4 times! new2novas Drag Racing Forum 75 5th-April-2010 10:57 PM
irwindale times 71nova Drag Racing Forum 18 13th-May-2006 02:53 PM
1/8 th mile drag racing WOW mike b Drag Racing Forum 4 16th-April-2006 04:10 PM
[email protected] mph New 1/8 mile times.. stricknine Drag Racing Forum 6 31st-March-2006 01:21 AM
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Lt
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
