Painting inside cowl vent - Chevy Nova Forum
Old 18th-July-2008, 08:32 AM   #1
MrDanO
(OP)
Nova(s): 1966 Coupe
Does anybody know how to go about painting inside the cowl vent on a "66" The cowl is not removable so how the hell do you paint inside of it? The only way I can think of is to get some kind of long wand and go in from the sides thru the cowl plugs. Any idea's ? Any help would be great. MrDanO
66 Coupe "337" Th400 10 Bolt 3.73 posi
Old 18th-July-2008, 11:39 AM   #2
Nova 404
Nova 404's Avatar
Title: Supporting Vendor
Nova(s): 1967 Nova SS
I hope some one chimes in here I would like to know as well,the inside of my cowl looks like s**t
Member of the NorCal Brotherhood!
Old 18th-July-2008, 01:04 PM   #3
Novaholic
Novaholic's Avatar
Nova(s): 1965 Nova Wagooon
I've used paint sticks with sandpaper at the ends to clean up and scuff for paint, scotch brite works well also. When it comes to painting your limited to the over spray landing in that area from shooting the exterier of the car. Now if you where a Chevelle owner the cowl vent panel comes right off!
Roy Landgrave
Old 18th-July-2008, 03:39 PM   #4
NIGHTSHADE
NIGHTSHADE's Avatar
Nova(s): NONE! It's a Chevy
Roy Landgrave
Thats what was done on mine Dan, and going from blue to yellow, it looks great.
Old 18th-July-2008, 10:04 PM   #5
Joe Buddy
Joe Buddy's Avatar
I used a cheap sandblaster with worn out sand to clean all the crud out and tried to sand with fine paper. Sanding didn't work too well. I taped the grill bars individually and shot a couple of coats of Urathane primer in as best I could. After that, I shot the color and it came out nice. When I shot the body, I peeled the tape off and cut cardboard to fit under the grill. I shoved it in thru the drivers side vent and pushed bubble wrap under it. I also used welding wire thru the windshield washer holes to help support it. I'm sorry. What was the question? Ha Ha I hope this helps. Joe
Old 8th-April-2019, 02:54 PM   #6
riverboatman
riverboatman's Avatar
Nova(s): 1965 Nova SS
What about using a rust encapsulator type spray wand taped to a dowel rod to reach in from the sides to stop any rust underneath the vent slots themselves? Mine will need something to stop slight rust in that area.
Old 8th-April-2019, 03:26 PM   #7
Duntov
Duntov's Avatar
Nova(s): 62 - 350, 4 spd, 3.73
that's why I decided to NOT change color when I paint my rig. I think that's also how some people go down the path to weld them closed!
My build thread:
Old 21st-April-2019, 01:20 PM   #8
kimmer71
kimmer71's Avatar
Nova(s): 1974 SS
Internal coating rattle can
I bought one of these but have not used it yet...
https://www.eastwood.com/eastwood-in...z-aerosol.html
My build thread:
Old 21st-April-2019, 01:32 PM   #9
snolan
snolan's Avatar
Nova(s): 1967 Sedan LS1/T56
Cowl Prep
Hate to say guys no easy way but to blast and epoxy then tape off the area during other paint prep then shoot paint its hard to look perfect and FYI cover while buffing the car because if compound get in there your not going to get it out.
MY recommendation is to weld it up "PROBLEM GONE"
Happy Easter
Brian the Ranchero cleaned up good i am going to paint it i am too lazy to take my own advice.
DAME THIS IS A OLD THREAD !!!
Steve
1967 Sedan LS1/T56
Old 15th-May-2019, 02:08 PM   #10
Greg Ellis
Greg Ellis's Avatar
Nova(s): 2 63 Hard Tops 1 63 Vert
When it is time for my to paint inside the cowl I will mask the grill then use an air brush to apply the paint. My IWATA air brush sprays a very narrow pattern with ample volume to cover inside the cowl.
Good luck on your project.
Old 15th-May-2019, 09:32 PM   #11
Zonie
Zonie's Avatar
Nova(s): 67 ss
You can't do anything to get the paint down there and make it look good that's the main reason I did this:
Old 15th-May-2019, 09:44 PM   #12
snolan
snolan's Avatar
Cowl
Take the advice you will not be regretting it later.
Steve
1967 Sedan LS1/T56
cowl vent removal 1967 tjplane Body and Interior 4 17th-February-2008 06:44 AM
Surface Rust Inside Air Vent NeoNova Body and Interior 5 27th-November-2007 04:30 PM
painting under cowl vent. damienchock Body and Interior 9 3rd-March-2007 12:28 AM
Dirty Cowl Vent evldoer Body and Interior 10 8th-August-2006 09:46 PM
cowl vent on 63 SS 63SSHT Body and Interior 4 12th-June-2006 08:44 AM
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Lt
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
