Problems With Mini Starter - Chevy Nova Forum
Old 21st-July-2008, 02:11 PM   #1
MR G
(OP)
Nova(s): 1962 WITH 383 STROKER, 1969 FIREBIRD 3
I Have 62 Nova With 383 Stroker. I Just Got The Car Running. About 3 Months Ago. And So Far The Engine Has Broken 2 Starters. Firts From The Hausing Were Bolts Go And The Second One . From The Gear That Grabs On To The Flywheel. I Think Its Beacause Of The High Compression. Anybody Knows Whats A Good Starter For High Compression. Or What Are You Guys Using For Your 383. Help
Old 21st-July-2008, 02:51 PM   #2
kilowatt
kilowatt's Avatar
Nova(s): 67 hdtp
Sounds to me like it needs to be shimmed away from the block some. The drive gear is probably smashing into the flexplate when you hit the key. You can buy shims at any parts store. KW
'67 hdtp all steel body full interior 3000lbs 440 sbc 8.81 @ 151 N/A
Old 21st-July-2008, 02:59 PM   #3
MR G
(OP)
Shimed It But It Just Got Worst So I Took All The Shims Out And It Work For A Little Bit But It Then Broke.
Old 21st-July-2008, 03:29 PM   #4
jason snyder
i have good luck with the denso style starters, gear reducted. you probably have another problem ? if its a compression type problem try a start retard .
Old 21st-July-2008, 03:36 PM   #5
MR G
(OP)
Not Sure What You Mean By Start Retard.
Old 21st-July-2008, 03:47 PM   #6
Nova_Guy
Nova_Guy's Avatar
Nova(s): 68 Chevy II SS
Did you shim the starter closer or farther away? You can move the starter closeror farther away by the placement of the shims. You need to check the gap between the bendix and flywheels gears. A paper clip is about the right amount of clearance between the gears.
http://www.cvrproducts.com/starter_tech.html
Shimming Procedure:
Important: Most GM pad-mounted starters prematurely fail as a result of improper shimming, regardless of whether the old starter had shims or not, you must inspect the clearance of the new unit as it may or may not require shimming.
Before Installation: You must understand the need for proper starter to flywheel clearance. This “clearance” is critical to avoid damage to Flywheel, Starter Drive and Battery.
Why Shimming Varies:
1. Mounting pad tolerances and hole locations vary from block to block, this moves the starter drive gear away from the flywheel varying distances.
2. The mounting pad on the engine block dimensions vary. This also moves the starter drive gear away from the flywheel varying distances.
Step1 - Inspection: Remove lower flywheel housing cover and examine the entire flywheel for visual problems. (Worn, chipped or broken teeth; bent flywheel and/or incorrectly cut teeth)
Step 2 - Check Clearance: Insert a screwdriver behind the starter drive. Move starter drive assembly out toward flywheel so that starter pinion and ring gear teeth mesh.
Step 3 - Measure Clearance: Center the pinion tooth. Check clearance (looking for .025” - .060”). A convenient plug gauge is a common paper clip, which typically measures approximately .035”. Important - Check at least 3 ring gear locations 120o apart for proper clearance. Shim as required
at minimum clearance location. After measuring clearance, push starter drive back into original position.
Step 4 - Proper Shimming: To increase clearance: Use entire shim across both holes. .015” shim increases clearance approximately .0075”. This moves the starter down and out, away from the flywheel (use no more than 6 shims). To decrease clearance: Use 1/2 shim only on the outer mounting bolt hole from oil pan. This moves the starter in and toward the flywheel. .015” shim decreases clearance approximately .010”
James
1968 Chevy II National Nostalgic Nova Member
Old 21st-July-2008, 03:56 PM   #7
MR G
(OP)
Hey Thanks For All The Info. I Shimed It But The Starter Got Further Away From The Flywheel So I Took The Shims Out And It Got Closer And It Work For A Little Bit But Then Broke The Gear On The Starter. So You Guys Dont Thinks Its Caused By Hi Compression.
Old 21st-July-2008, 04:14 PM   #8
kilowatt
kilowatt's Avatar
Nova(s): 67 hdtp
I've never seen a broken gear from high compression. Pick yourself up a starter for a 95-98 1/2 ton truck. They work very good and you can usually find one for about $90.00 KW
Old 21st-July-2008, 04:33 PM   #9
MR G
(OP)
Thats What I Have Right Now. From A 1996 Chevy Tahoe. How Can Tell The Diffrence From 168 Tooth Flex Plate To 153 Flex Plate.
Old 21st-July-2008, 04:50 PM   #10
veno
veno's Avatar
Nova(s): 72 385, t350, 3.73 4w-dsk
Garage
If you get the 168 tooth... starter it will work with both.
a nation of free men, shall live forever, or die by suicide
Old 21st-July-2008, 04:57 PM   #11
MR G
(OP)
O Ok. Im Thinking That Maybe The Flexplate Is Worn Out Or Maybe Need A Stronger Better Quality Starter.
Old 21st-July-2008, 05:08 PM   #12
SlickVic107
SlickVic107's Avatar
Nova(s): 72 Nova 355 9.91@134
383 w/ 13.5:1 I use a summit high torque w/ no problem and i have a locked distributor at 36 degs of timing. Sounds like you have a mis alignment issue. The only issue i have ever have is the spring eventually weakens in the pinion gear and you must replace it but they sell a kit to do that. Its basically the same setup as a tilton just cheaper in price.
Parts listed in For Sale/Misc section!
87 Cavalier, 383 9.27@142
Old 21st-July-2008, 05:20 PM   #13
MR G
(OP)
So Tilton Is A Good Brand For High Compression. Does Any Body Have The Specs On The 168 Flex Plate Tooth.
Old 21st-July-2008, 05:25 PM   #14
SlickVic107
http://store.summitracing.com/partde...I&autoview=sku
Old 21st-July-2008, 05:54 PM   #15
Nova_Guy
Nova_Guy's Avatar
Does the newer style starter require the brace on the front? They really help with the older style starter.
James
Mini Starter lisandon95386 Drivetrain & Performance 0 9th-January-2008 12:18 AM
mini starter mounting a69nova Drivetrain & Performance 3 15th-November-2007 10:08 PM
mini starter problem MR G Drivetrain & Performance 16 31st-October-2007 11:10 AM
Starter Problems 65NovaSSman Electrical 1 19th-July-2007 10:38 PM
Starter Problems??? fast63 Drag Racing Forum 13 8th-March-2007 04:50 PM
