Inline 6 Cam Selection - Chevy Nova Forum
Old 17th-July-2008, 03:28 AM   #1
Nova1963
Nova1963's Avatar
Nova(s): 1963 Nova 1968 El Camino
What type of aftermarket cams are you Inline 6 guys running? It seems that Comp Cams makes single pattern cams while Crane offers dual pattern. What do the experts recommend?
Old 17th-July-2008, 03:45 AM   #2
N and OVA
Nova(s): 72' Coupe
In my 72' (250cid) My total engine package is as follows:
Numbers matching block and head
Block bored .30 over
Head fully ported and polished
1.94 intake valves
1.84 stainless exhaust valves
Completely new valve train with double springs
Comp Cam's 252H
Flat-top pistons
Offenhauser triple-one barrel intake
Langdon's Dual exhaust manifolds
+TH350 trans & shift kit
As far as the cam goes, I have had great results with the Comp 252H
It isnt realllly aggressive but it gives a nice small lope at idle, and better-than-stock bottom end power, with a HUGE gain in top end acceleration. (60-80 pretty quick)
Old 17th-July-2008, 05:09 AM   #3
Richardlss
Richardlss's Avatar
Nova(s): 1978 Nova
1.94 intake valves
Comp Cam's 252H
Flat-top pistons
HP rating?
Old 17th-July-2008, 12:31 PM   #4
N and OVA
Nova(s): 72' Coupe
As far as my HP rating, I haven't any clue yet.
The book shows 105hp as the stock number.
I'm estimating that I doubled it, just by feel.
But as we all know, that's not necessarily an
accurate way to tell. It will be dyno'd soon.
Old 17th-July-2008, 05:23 PM   #5
Bruce
Bruce's Avatar
Nova(s): 6 cylindersssssss
Clifford Research is another source for inline cams. The on-line catalog is lacking details. They used to have from 250 up to 280 duration hydraulic and mechanical versions, but you may need to call them to see what is actually available.
Old 17th-July-2008, 06:09 PM   #6
65Nova4door
65Nova4door's Avatar
Nova(s): 1963 hardtop 1965 4door(
This is where I got mine:
http://www.schneidercams.com/cams/46.htm
264-H 264 duration 214 @ .050" .498" lift 110 lobe center $150.00 + shipping ( This was a 292" Chevy 6 cyl.)
Old 18th-July-2008, 12:56 AM   #7
Nova1963
Nova1963's Avatar
65Nova4door,
How do you like the cam? What is the idle quality/speed like? Did this cam help low end, mid range, high end? Thanks for your time!
Old 18th-July-2008, 01:49 AM   #8
N and OVA
Nova(s): 72' Coupe
Two other things to keep in mind when running the L6
If you are running an automatic trans, your cam needs to be a little less agressive than if you are running a manual.
Also, one should keep their cam selection semi-proportional to the engine's displacement. A 292 can run a lumpier cam than a 250 can, and so on.
wondering about inline 6 matt's77nova 4th Generation Nova's 8 22nd-January-2010 04:18 AM
Inline 6 Fuel injection Fredsgarage Drivetrain & Performance 15 18th-December-2007 08:08 AM
v8 th350 or inline KEITH'S75CUSTOM Drivetrain & Performance 10 17th-May-2007 08:02 PM
Help I have some Inline Ugliness simmondj Drivetrain & Performance 9 18th-July-2006 12:44 PM
inline 6 to v8? dinnut 3rd Generation Chevy II/Nova's 3 12th-June-2006 08:19 PM
