250 compression - Chevy Nova Forum
Old 4th-July-2008, 07:24 PM   #1
Richardlss
(OP)
Richardlss's Avatar
Nova(s): 1978 Nova
250 compression
with a stock 250 the compression should be 8:1... but im getting the head milled, taking .30" (i think its .30") with that small of a number how much difference does it make in compression?
Old 4th-July-2008, 09:33 PM   #2
Twisted6
Twisted6's Avatar
Nova(s): 64 SS chevyII
that will bring you to ruffly 8.5-1 you gain about 2 points in compression for every .010 off the head.
T6R }[oooooo]
Larry /aka Twisted6
Old 4th-July-2008, 09:56 PM   #3
Richardlss
(OP)
Richardlss's Avatar
Nova(s): 1978 Nova
what is the normal mill thickness people usually get shaved off their heads?
i finally found a calculator for compression ratio's and it said to get 9.1 compression i need to take off 0.048"...
wouldnt that be 8.8-1? unless its just rounded off?
Old 4th-July-2008, 10:59 PM   #4
Nova_Power4
Nova_Power4's Avatar
Nova(s): 77 NOVA,97 F-150 lariat
wow if thats the case, whats my compression then!?!?!?! .100thow off my head block combined
1977 Nova,250-Turbo Inline6
That dont please ya..I'm from
You Hooser
"AS WE SLEEP THEY DIE"
Old 5th-July-2008, 12:02 AM   #5
Richardlss
(OP)
Richardlss's Avatar
Nova(s): 1978 Nova
you had your head milled .100? what is the difference in horsepower do you know? i've been trying to figure out how much horsepower gain i could get out of 8.1 compression to 8.5 compression, if theres a good amount of gain, id probably just step up to 9.1 compression
Old 5th-July-2008, 07:33 AM   #6
Nova_Power4
l had 50thou off the head then 50 off the block when it was getting milled.
power wise l dontr know but l got alot of torque drop it in 2nd gear do donuts alllll day
but l'v worked the motor of just a tad bit more also running 97prem
You Hooser
Old 5th-July-2008, 02:03 PM   #7
Richardlss
(OP)
Richardlss's Avatar
Nova(s): 1978 Nova
hm.... i may try seeing if i can get head milled .40 and block .40 that should get me 9.1 the way it sounds from larry...
Old 5th-July-2008, 06:16 PM   #8
Twisted6
Twisted6's Avatar
It may have just rounded it off,I don't know for sure. I have it in notes somewhere when i was told. and i am pretty sure it was like 2 points for every .010 milled. When I get a half a chance I'll call the guy again just to double check and make sure i am remembering it right. But the call will have to wait till monday.
T6R }[oooooo]
Larry /aka Twisted6
Old 6th-July-2008, 10:16 AM   #9
Richardlss
(OP)
Richardlss's Avatar
Nova(s): 1978 Nova
Hey guys, i cant really find a good compression calculator, so i was wondering if any of you knew a good one to get?
just trying to figure out how much HP gain im getting
block is stock with the 3.875x3.53 bore/stroke
74CC head
not sure gasket thickness
but the head is getting milled probably .030" or .040"
and also the block may be getting milled .030" or .040"
if .010" is 2 points of compression then the total .060" is 9.2-1 and .080" is 9.4-1 right?
just getting excited about more compression for some reason
Cranking Compression Repointer Drivetrain & Performance 7 26th-October-2007 06:41 PM
Compression Ratios and Pump Gas Kurt Drivetrain & Performance 8 26th-October-2007 02:19 AM
Cam and Compression for my 383 Scooter Drivetrain & Performance 12 20th-February-2007 11:44 PM
Tuning problems 63SLEEPER Drivetrain & Performance 53 30th-August-2006 08:44 PM
Compression ratio, DCR and pump gas (merged threads) 69NovaSS Best of Drivetrain & Performance 166 2nd-August-2006 09:07 PM
