Carb Spacer Question... - Chevy Nova Forum
Old 23rd-June-2008, 04:26 PM   #1
62bandwagon
(OP)
62bandwagon's Avatar
I have a 750 square bore Holley carb & a Performer RPM Air-gap intake. I am considering trying out some carb spacers, do I want to use the 4 hole style or the open center type with this intake?
1962 Chevy II wagon
383 w/RHS Vortec 1.94/1.50
EdelRPM Airgap w/750 Holley
Old 23rd-June-2008, 04:55 PM   #2
D-Man
D-Man's Avatar
Talk to a couple friends and see who has what that you can borrow. Then go to the track and see what works best for your car.
EVERY motor is different and will even act different at different elevations. There is absolutely NO way to say what motor will respond to any kind of spacer.
An unarmed man can only flee from evil, and evil is not overcome by fleeing from it.
Lt.Col. Jeff Cooper
Old 23rd-June-2008, 04:55 PM   #3
Gota66
Gota66's Avatar
Nova(s): 1966 2DR HT
I just finished installing the RPM Air-Gap intake on my 355 yesterday. I am running a BG Road Demon 625cfm square bore carb. I used the 1" phenolic spacer for square bore.
http://www.jegs.com/i/Mr.%20Gasket/720/3404/10002/-1
I am very pleased with the results!
"Yer thinkin with your dipstick, Jimma!"
Old 23rd-June-2008, 05:00 PM   #4
1977stroked
1977stroked's Avatar
Nova(s): 77' Nova 383" stroker
Ill be ordering this soon!!
1977 Nova 383 Stroker
60ft 1.73
1/8 7.94 @ 86.34
Old 23rd-June-2008, 05:21 PM   #5
62bandwagon
(OP)
I guess what I was really wondering was if either a 4 hole or open center spacer is recommended on my dual plane intake. Sounds like I can use either, is that correct? I plan on trying some different heights of spacers.
1962 Chevy II wagon
Old 23rd-June-2008, 05:58 PM   #6
danthegeek
danthegeek's Avatar
Nova(s): Red 71
I have a 4 hole spacer on mine now.
This pdf seems to have some good info. http://www.gnetworks.com/v4files/bar...h%20images.pdf
71 Nova
"Freakin Hybrids man. They just dont do the trick anymore..."
Old 23rd-June-2008, 06:07 PM   #7
wht73
wht73's Avatar
Nova(s): 73 nova custom
What he said !
That said.
Mine liked it on the open on the Hurricane and the Air Gap .
3515#,all steel,406ci N/A,10.6/122.38, short shifting, N/A
Old 23rd-June-2008, 06:20 PM   #8
jason snyder
I thiink if you need a few more upper RPM go with a 1 inch open and see if it likes it ? But you can run any type spacer ,its your choice !
Old 23rd-June-2008, 06:31 PM   #9
62bandwagon
(OP)
Plastic , aluminum or phenolic for street use?
1962 Chevy II wagon
Old 23rd-June-2008, 07:04 PM   #10
wht73
wht73's Avatar
They say aluminum for the street... but I've been using phenolic for years now with no problems.
Old 23rd-June-2008, 07:50 PM   #11
danthegeek
danthegeek's Avatar
Nova(s): Red 71
Ive been using a plastic spacer. I dont have any problems with leaks or cracks. It also keeps the carb away from the manifold to keep it cool.
-dan
71 Nova
Old 23rd-June-2008, 09:34 PM   #12
62bandwagon
(OP)
Thanks for the info guys!!
1962 Chevy II wagon
Old 23rd-June-2008, 10:59 PM   #13
Greg_R_63
Greg_R_63's Avatar
Nova(s): 1963 2-dr hardtop
Are the HVH spacers worth the money? ~100 vs. the 30 for the plastic spacers?
1963 400 Series Hardtop
Rochester 1bbl carb question Bamma Drivetrain & Performance 3 7th-February-2010 09:09 PM
POS carb spacer!!!! danthegeek Drivetrain & Performance 23 27th-December-2007 11:48 AM
NOS - above or under carb spacer? lior_baruch Drivetrain & Performance 6 6th-November-2007 06:11 PM
carb spacer whistle? Novamike67chevy Drivetrain & Performance 3 31st-October-2007 12:59 AM
Pro-Systems carb question JTW Drivetrain & Performance 21 20th-April-2006 09:45 AM
