Rear End Width - 1970 nova - Chevy Nova Forum
Old 28th-May-2008, 12:25 AM   #1
SeventyNova
(OP)
I am in the process of building a 9" for my 70 Nova. I have the rear out of an 1982 F150 that measures 65" axle to axle. Unfortunatly I have sold my old 10 bolt without taking accurate measurements for getting the 9" narrowed. Can anyone tell me the overall width - outside of axle to axle of a 70 nova rear end? thanks in advance.
Old 28th-May-2008, 09:42 AM   #2
veno
veno's Avatar
Nova(s): 72 385, t350, 3.73 4w-dsk
Garage
http://novaresource.org/axle.htm
a nation of free men, shall live forever, or die by suicide
Old 28th-May-2008, 10:36 AM   #3
novamike
novamike's Avatar
Nova(s): 66 ht
9 inch
Be sure to check your pinion offset before you cut.
Mike
406.th400.9 inch,lots of Duct tape.
Superglue is my friend
Home of the famous "Bubba" burger
Old 28th-May-2008, 03:25 PM   #4
vonbondo
vonbondo's Avatar
Nova(s): 64 chevy two,2 door,6 cil
9 inch
Mike
65 inches is too wide, a stock 10 bolt is 60-1/4.have the housing narrowed and buy good axels,moser,mark wiliams,strange.then you need to measure for a drive shaft.make sure the pinion is centered,and gear ratio is right for what you are doing with the car.good luck. vonbondo.
Old 28th-May-2008, 05:21 PM   #5
taz3
taz3's Avatar
Title: Moderator
Nova(s): 2 69 SS BB L78's & 69 4dr
My 12 bolt measures 60" from outside axle to outside axle where the drum would sit.
3 69's, 2 L78's, 51 Fathom & 71 Lemans #'s match both w/4spds & 69, 53 glacier blue 4 door
Old 28th-May-2008, 09:05 PM   #6
SeventyNova
(OP)
Thanks for the info, 60" it is, might go 1/2" less to allow for the extra thickness of discs from drums. Allready have a 31 spline detroit locker, richmond 4.11's, multileaf perches and the install kit for it. Will order the axles (moser) after I get it narrowed, hopefully can find someone to do it in the next week or so.
The Big Al's 1970 Nova SS The Big Al Car Profiles 76 30th-December-2009 09:46 PM
davidr5610's 1970 Chevy Nova davidr5610 Car Profiles 1 26th-February-2008 11:14 PM
70 Nova Rear Axle Shifting...Any ideas? Nova Josh Steering, Suspension, and Chassis 2 8th-September-2006 08:41 AM
87 camaro rear end in 64 Nova SS brianchevy Drivetrain & Performance 5 27th-June-2006 11:26 PM
