Total timing and timing curve recommendation - Chevy Nova Forum
Old 3rd-May-2008, 12:28 PM   #1
supr78nova
(OP)
Nova(s): '78 & '79
Looking for a total timing recommendation for my combo. Also what would be a good timing curve for this combo?
Approx 9.4:1 CR, ~15" vacuum @ idle
350 goodwrench short block
Vortec heads modified for increased lift
comp cams XE268 cam .477/.480 lift
holley 650 vac secondary
stock HEI distributor
2 5/8 full length headers w/2 1/2 exhaust
TH350 trans
3.42 gears
I recently purchased a piston stop to first verify true TDC, a degreed balancer cover, adjustable pointer, and an HEI recurve kit.
Any help would be appreciated,
Dan
It's easy when you know how.
Old 3rd-May-2008, 12:47 PM   #2
Shuboxchevy
Shuboxchevy's Avatar
Dan,
I have a similar setup as you. L31 block with vortec heads. XE270 hyd roller cam. 9.4:1 CR. I was having pretty good luck with 10* initial w/ a 24* curve that was all in at 3000 rpm for a total mechanical timing of 34* advanced. I was also running a 18* vacuum curve that was all in at 8 in HG. I had pretty good luck with it and it may be a good starting point for you.
If anything, you may need a couple degrees less timing then what I was running since I was running the wrong length spark plugs previously.
Hope that helps.
Ryan
66 Chevy II Sedan 100
L31 350 / Iron Vortec heads
Comp XE270HR cam
Old 3rd-May-2008, 01:20 PM   #3
Seattle_Mike
Seattle_Mike's Avatar
Title: Moderator
Above sounds about right for your combo. Read the plugs too...the best indicator of what's going on overall.
33 Ford 3 Window 468ci BBC
68 Camaro ProMod 848ci Buck Racing Engines Nitrous
Old 3rd-May-2008, 08:48 PM   #4
kane
just experiment, don't be afraid of more initial. My car is the same except I have more compression and it runs best with 18 initial and 32 total. I suggest you return the recurve kit, and buy the crane adjustable vacuum advance kit. It comes with the vacuum canister, and springs the recurve the mechanical advance.
Old 3rd-May-2008, 10:09 PM   #5
supr78nova
(OP)
Nova(s): '78 & '79
Kane,
I forgot to mention that I do already have an adjustable vacuum advance canister installed.
As a general rule what would be the max total timing for my vortec headed combo? I know that vortecs require less total timing than older heads because of their more efficient chamber design amongst other variables, I'm just not sure how much total timing would be too much.
Dan
Old 4th-May-2008, 12:22 AM   #6
kane
I don't have track times where I've played with the timing, but from reading I just heard they run good around 32-33. Maybe drivewfo will chime in. But I will say, my car runs better with 18 initial. The idle is better, it's more responsive, starts right up, and runs cooler.
Old 5th-May-2008, 12:54 AM   #7
Shuboxchevy
Originally Posted by supr78nova View Post
Kane,
Dan
If it detonates... that's too much timing.
52 total timing (initial + mechanical + vacuum) is ballpark for a SBC. Subtract a few degrees and that's about max for your vortec.
Ryan
Comp XE270HR cam
Distributor install thread 66deuce Best of Drivetrain & Performance 22 23rd-April-2009 11:14 AM
Total Timing Indicators and timing tape tricks batman09 Drivetrain & Performance 46 9th-April-2008 10:34 PM
More on timing......any comments Mikel72 Drivetrain & Performance 1 21st-December-2007 07:01 AM
No acceleration from stand-still, Missing on acceleration. Comicazy Drivetrain & Performance 20 18th-October-2007 07:41 PM
Matt's HUGE PROBLEM with video voodoochikin04 Drivetrain & Performance 284 5th-February-2007 06:41 AM
