350 Lt1 ..lt4 ? - Chevy Nova Forum
Old 31st-March-2008, 12:34 PM   #1
chevydario
(OP)
chevydario's Avatar
Title: Nova Newbie
350 Lt1 ..lt4 ?
Hello as before I counted to my chevy Nova I changed him the motor 6 cylinders 250 by a V8 350 4 bolts. The theme is the following one: I am of Argentina and here there are few chevy 350 and I appeal to your aid to assemble it correctly with the components brought of USES. This it is the photo of my beloved motor one that before was placed in a truck the numbers that can be seen are the following 14093638 5,7 LG SGI:
http://img525.imageshack.us/img525/4...sc09077eq2.jpg
http://img247.imageshack.us/img247/4072/dsc09076dk5.jpg
http://img180.imageshack.us/img180/2905/dsc09004gt5.jpg
http://img247.imageshack.us/img247/5653/dsc09003dk2.jpg
The questions are the following.
_ The block is a gen II? LTI LT4?
_ Originally as many as HP has and that RPM?
_ The covers are of iron but to cheapen the costs I think to use those
_ The idea is to buy some KIT for throw 6500 rpm without problems with carburetor 650 holley
_ I rectify It to 0,30
_ there is a lot of difference between a Fixed and Hydraulic kit…. which is the difference because i would like but with fixed…I listen opinions.
_ TO see that they think of this kit:http://www.crateenginedepot.com/stor...02-P497C0.aspx
_ with the pistons these I can throw 6500 rpm they serve for the previous kit
http://www.crateenginedepot.com/stor...8-P1001C0.aspx
Old 31st-March-2008, 01:47 PM   #2
69LT1Nova
69LT1Nova's Avatar
Nova(s): 1969 Nova, grandma fresh.
Hi, and welcome to Steve's!
I'm putting an LT1 in my Nova, so I know what you're going through. First of all, check the front of your block for a casting number 327 - this will tell you it's a LT1 5.7L. There are other ways to tell, but that's the easiest. You mention that it has steel valve covers, which rules out the LT4 - the LT4 used composite covers to keep noise from the valvetrain quiet.
Going to a carburetor is no problem on a LT1. GM Performance parts sells a carb swap intake, but fuel injection will give you the best horsepower, torque, and fuel mileage. If you're hitting 6500 RPM you're going to want a bigger carb than a 650 CFM Holley, it's too small for high RPM and you'll run lean.
Be sure you find out if you have an LT1 before doing too much shopping!
Build:
LT1 baby!
Old 31st-March-2008, 10:06 PM   #3
69LT1Nova
69LT1Nova's Avatar
Where did you get that casting number from? I'm looking at an LT1 guide book, and they state that all LT1 motors have the same casting code of 10125327. Sounds like you might have something other than an LT1, especially since it came out of a truck. (no LT1s that I'm aware of ever came in trucks) More than likely you have a Gen 1 small block from a 87-91 truck with a 1 piece rear main seal.
Build:
LT1 baby!
Old 1st-April-2008, 09:53 AM   #4
chevydario
(OP)
chevydario's Avatar
Title: Nova Newbie
Hello 69LT1Nova, thanks by helping me. This page which would be my block (Is the number 22? ) . Are you very kind again thanks.
http://www.jimsperformance.com/blocks.html
http://www.cehighperformance.com/c_t...lock_codes.htm
Old 1st-April-2008, 12:37 PM   #5
69LT1Nova
69LT1Nova's Avatar
Yep, thanks for the links!! It confirms that you do not have an LT1 or an LT4, you have a TBI or PFI truck block. It could be 22, 23, or 24 on that first website. The big differences between the LT1 and TBI are as follows:
  1. LT1 has reverse coolant flow - coolant goest to heads first
  2. LT1 uses a front mount distributor
  3. LT1 makes more power!
Good luck with your build, now that you know that you do not have an LT1. My suggestion: put a nice roller cam in the block, get compression up around 9:1, and put a carburetor on it.
Build:
LT1 baby!
Which and why: 350 vs. 383 Bscman Drivetrain & Performance 41 14th-July-2015 11:04 PM
Vacuum Advance 101 the FLYER Best of Drivetrain & Performance 20 1st-October-2008 01:32 AM
Rearends ChevyIINova Drivetrain & Performance 8 8th-September-2007 08:56 PM
Machine work and engine build questions tsimpson Drivetrain & Performance 38 30th-August-2007 03:05 PM
