6.0 or 5.3 LSX? - Chevy Nova Forum
Old 14th-March-2008, 05:54 PM   #1
aron69nova
(OP)
aron69nova's Avatar
Nova(s): 69 Race Car, 66 Longroof
6.0 or 5.3 LSX?
I found a place where the price difference on the 6.0 and 5.3 LSX motors (with trans) are pretty much a non issue. I'm assuming that they both come with the 4L60E (or 65?) transmissions. This is going into my 67 wagon. Yes, I was asking about a 2004R in earlier threads, but I've been reading on these motors and it's almost a no-brainer on price. I want to fit these engines under a STOCK hood. I will most likely start out N/A then go turbo later on. Will both of these motors fit under my hood? And if the price is about the same, which is a smarter buy? I am looking for something slightly more peppy than my 250 inline 6...
1969 Nova
383/TKO/12 bolt
6.620 at 109.42mph (1.61 60'...)
"Because Three Pedals are Better Than Two!"
Old 14th-March-2008, 06:13 PM   #2
Rage KG
Nova(s): 1968 Nova
6.0 is rated at 300 and the 5.3 is rated at 285. In your car they'll probably get the same Milage. They both have the same block (i think) so they'll fit fine under a stock hood. Just out of curiousity how much are you finding them for?
Edit: Saw it was for a '67. May have slight fitment issues with the tunnel and the accesories (a/c, etc) I'm not sure if they make adapter mounts but i'd imagine so...
Old 14th-March-2008, 06:24 PM   #3
aron69nova
(OP)
aron69nova's Avatar
i found a complete (trans and computer) 6.0 for $2500 and a 5.3 for 1750. do these have a separate oil cooler? i'm learning about this stuff and want to do a swap like this badly. i'd use a gto pan which makes room for my steering linkage. i think the trans would fit fine. as for motor mounts i can use one of the conversions from trans-dapt, no? i'd like as much info as i can. this place is a few miles from my house and i'd like to get everything set up so that in july or so i can just plug the motor in and go. probably a week or two of work and i'd like to be using the car.
1969 Nova
383/TKO/12 bolt
Old 14th-March-2008, 09:04 PM   #4
Pwrtrip75
Pwrtrip75's Avatar
Both engines are identical dimension wise. I think the stroke in them is the same too. The bore is the difference. Not aware of any external oil coolers, maybe aftermarket.
Theres 2 different 6.0's the LQ4 and the LQ9 one has lower compression and less HP. If your going turbo and dont want to rebuild I would go with the 5.3L You can bolt the 6.0L heads right on it and drop the compression down to 8.6:1 which is perfect for a turbo. It will hold 15psi all day and swap in like an LS6 cam and 600rwhp is a walk in the park...with all factory parts. You cant beat that in my book.
72 Nova- LS 370 88mm turbo 4 link
99 Transam-LS 370 76mm turbo
71 Chevelle slow 350 building a LS 5.3
Old 15th-March-2008, 01:37 AM   #5
62deuce
62deuce's Avatar
Nova(s): 1962 Nova 400
Go with the 4.8 vortec i have one in my 2000 single cab silverado i beliecve its the 294 V8 and that thing just surprises the hell outta me ......i bought it used, but i sware theres something done to it (checked found nothing) lol i even thought of putting it in a 65 chevelle or some type of shoreline cruiser its weird, my 4.8 is dead even with my buddies 6.0 liter 2000 silverado single cab anyway i guess i just want to see wat that 4.8 would do in a light car instead of a truck -BB
62 Deuce 400
Hoping for 500 h.p.
(498 hp @ 7000)
4.33's
4-speed
Old 15th-March-2008, 01:53 AM   #6
Ryan V64SS
Ryan V64SS's Avatar
Nova(s): 64 SS, 63 Sedan
I have a 2004 3500 van with the 6.0, my co-worker has a 2007 3500 van with the 4.8, my van absolutely trashes the 4.8. Same van same weight work vans. In a van the 4.8 is totally gutless compared to the 6.0.
64 SS Street car. 10.60's on pump gas and 235 radials
Old 15th-March-2008, 02:06 AM   #7
62deuce
62deuce's Avatar
Im telling you ... i seriously cant believe my truck...i dont think its fast by any means, but for what it is itll hang right there exact same with his 6.0 liter I did run it at sacramento, and it pulled a 16.01 hahaha i still have the time slip in my glove box....i believe its stock
62 Deuce 400
Hoping for 500 h.p.
(498 hp @ 7000)
4.33's
4-speed
Old 15th-March-2008, 11:41 AM   #8
Rage KG
Nova(s): 1968 Nova
You'll have to get the PCM reflashed, Hook up New fuel delivery, New cooling and fans (I would go full electric), engine mounts, and tranny crossmember, new or resized drive shaft. Those are the basics. Then you have random stuff like Relays for all the new electric stuff you'll be running. I would definately upgrade brakes cause you're gonna love that gas pedal!
Go to LS1tech.com and check out the swaps section. Tons of information!
I also agree with the 5.3 if you plan on going turbo. Holy cheese and rice that thing will move!
Old 15th-March-2008, 12:36 PM   #9
bowtie0069
bowtie0069's Avatar
Nova(s): 69
My 2000 Suburban 5.3 ran 10.20's in the 1/8, and I've driven around big blocks and deisels when towing my Nova. They are amazing little engines. I've talked to guys that went from 5.3 trucks to 6.0's(first couple years)and were very disappointed-no more power and way worse mileage. The newer 6.0's are supposed to be better.
I've gotten 19+mpg going to the river empty, and 14 towing the car.
With 142,000+ on the clock it still runs great-same belts, hoses,......I had to change a TPS once, but no maintenance other than that.
I'm looking for a cheap one myself--anybody got one?
69 Nova 410" small block-Driven to track
6.39 E.T./105 MPH--6.11/112.89 w/N2O
Old 15th-March-2008, 12:40 PM   #10
Nova_Guy
Nova_Guy's Avatar
Nova(s): 68 Chevy II SS
My coworker has an 2002 Heavy Duty 1/2 Chevy with the 6.0. He claims it doesn't run as well as the 5.3 in my 04 GMC. He just sold a 98 Chevy with a 5.7. He claims it ran better than his 6.0. I just figure GM detuned the 6.0 so they wouldn't break parts under warrenty.
James
1968 Chevy II National Nostalgic Nova Member
Old 15th-March-2008, 01:15 PM   #11
Pwrtrip75
Pwrtrip75's Avatar
the disappointing 6.0L you guys speak of is probably the lower compression one. LQ4 or LQ9, there is 2 different 6 liters.
Old 15th-March-2008, 01:15 PM   #12
babydeuce
babydeuce's Avatar
This is not a drop and go type of installation! Exhaust has to be custom built for the stock frontend, mounts differ the location by manufacturer. I have probably close to 2500 bucks in my conversion so far, and that includes the cost of the 5.3 w/trans and PCM. I paid 1400 for the engine and trans. I dont know for sure that the stock truck manifold will fit under a stock hood, it would be close. I swapped over to the LS6 intake, which requires a new water pump, pullies and mounts.
Things to consider:
Throttle pedal
Throttle cable (not needed if DBW)
Electronics
Driveshaft
Fuel pump
Tank modification
Radiator
Cooling fan
Mounts
Exhaust(stock manifolds dont fit factory clip)
PCM programming
cost of oil pan
Trans cross member
Engine mounts
Conversion from cable speedo to Electronic VSS
Fuel lines
There are a lot of things that will nickle and dime you to death when converting. If you shop around, parts can be had at a good price, but it is by no means cheap to make the conversion.
Is it worth the effort....I believe so
Jack
Its not a NOVA, its a Chevy II....63 SS 5.3/4L60E powered!
Old 15th-March-2008, 01:28 PM   #13
Pwrtrip75
Pwrtrip75's Avatar
Things to consider:
Throttle pedal Used my stock one
Throttle cable (not needed if DBW) Used F-body one
Electronics What? use factory harness...nothing else.
Driveshaft
Fuel pump used the one I had A1000
Tank modification N/A
Radiator Same one I had, why change it?
Cooling fan Same one I had
Mounts
Exhaust(stock manifolds dont fit factory clip) That is all custom
PCM programming $400-$500 for software. I suggest learn it and do it yourself.
cost of oil pan I cut and welded truck pan
Trans cross member Stock...slide forward and re drill holes
Engine mounts home made
Conversion from cable speedo to Electronic VSS You mean convert VSS to speedo cable? VSS is not needed on an old car.
Fuel lines same as any other project you do
Jack
I thought mine was rather cheap to build. Theres nothing really to it. Not any different than swapping any engine.
Old 15th-March-2008, 01:56 PM   #14
KoTToN
KoTToN's Avatar
Nova(s): 1976 Concourse
i had a chevy with the LQ4 in 02 and it had a ton of power but wasnt very quick.
Now i have the LQ9 and the difference in night and day.
If i was gona go the 6.0l route i would def get the LQ9
Old 15th-March-2008, 10:09 PM   #15
aron69nova
(OP)
aron69nova's Avatar
thanks for all the replies. i've been evaluating my budget and next summer i'll have cash to do it. which means i just get to do a lot of research for the next year and acquire parts so that it goes together smoothly. i do understand this isn't just a regular swap. what i like is that it's all GM stuff and should be a decent project. my major concerns now are the throttle linkage, cooling system and speedo hookup. i am looking forward to this swap. sounds like i'll spend about 3K$ on it?
1969 Nova
383/TKO/12 bolt
LSx Engine Rally Point kdawgmfic LSx Forum 594 6th-December-2015 03:17 PM
Pwrtrip's 1972 Turbo LSX Nova Pwrtrip75 Car Profiles 26 3rd-December-2008 08:56 PM
Front end question for LSx conversion Chevy Boy Drivetrain & Performance 3 28th-May-2007 12:29 PM
The Future SBC - LSX Fast65 Drivetrain & Performance 49 7th-April-2007 06:09 AM
