Differential Fluid - Chevy Nova Forum
Old 9th-February-2008, 09:20 AM   #1
barnibe
barnibe's Avatar
Title: Nova Newbie
Nova(s): '70 Coupe.
Differential Fluid
Im attempting to tune up my Nova from "head to toe". How often does differential fluid need to be changed? How do you know? Does my vehicle even have this fluid?
Old 9th-February-2008, 02:13 PM   #2
supernovanator
supernovanator's Avatar
Nova(s): Wrecked 4dr '69
you should probably change it, not knowing how old it is... you will need to loosen up all the bolts on the rear end to get the fluid out. you may want to get a new gasket for the rear too.
To fill it up, there is a plug in the case towards the front of the axle on the passenger side. put oil in until you can see it barely coming out. hope I helped
"Your hopes have become my burden. I will find my own liberation." -- RWBY.
Old 9th-February-2008, 04:15 PM   #3
supr78nova
Nova(s): '78 & '79
just make sure that you can get the plug out before you take the cover off and drain the fluid. Also, if you have a posi rear you will need limited slip additive.
Dan
It's easy when you know how.
Old 9th-February-2008, 05:13 PM   #4
veno
veno's Avatar
Nova(s): 72 385, t350, 3.73 4w-dsk
If you do as the service manual recommends.... every 20k miles....
most never got changed for 80,000 miles or more.
a nation of free men, shall live forever, or die by suicide
4-lug rear end fluid Blurr Drivetrain & Performance 2 16th-July-2007 07:09 PM
2004 Grand Am Trans fluid check Nova_Guy Drivetrain & Performance 5 19th-June-2006 11:16 AM
Advice for changing rear end fluid? NovaNate Drivetrain & Performance 6 15th-June-2006 08:52 AM
brake fluid sthole Steering, Suspension, and Chassis 4 17th-April-2006 08:34 AM
power steering fluid type? bkhotrod Steering, Suspension, and Chassis 3 9th-April-2006 09:05 PM
