Wont Rev. past 4000 rpms in gear!! - Chevy Nova Forum
Old 24th-January-2008, 02:46 AM   #1
1977stroked
(OP)
1977stroked's Avatar
Nova(s): 77' Nova 383" stroker
Ever since I got my auto meter tachometer I have notice that my car will not go past 4000 rpms. It sounds like the motor is at its limits at 4000 rpms and I cant figure it out. I have a Holley 670 street avenger, 454 lift/218 duration cam, offenhauser manifold, Longtube headers with single 2 inch exhaust(part of the problem), timing is at 38 total. It will rev to 5000 easy in neutral it just wont do it in gear floored manual shifting. Any Ideas?!?!?
1977 Nova 383 Stroker
60ft 1.73
1/8 7.94 @ 86.34
Old 24th-January-2008, 02:51 AM   #2
The Big Al
The Big Al's Avatar
Nova(s): 68ss, 70ss (SOLD)
What tach is this? Model?
Does it have a rev limiter?
is it set on the V8 setting?
“The bitterness of poor quality & Service remains long after the sweetness of low price is forgotten”
Old 24th-January-2008, 02:52 AM   #3
1977stroked
(OP)
It is an Auto meter sport comp monster, it does not have a rev limiter and I can not change the setting for 6 or 8 cylinder(doesnt have it)
60ft 1.73
1/8 7.94 @ 86.34
Old 24th-January-2008, 02:57 AM   #4
Mike Goble
Mike Goble's Avatar
Nova(s): 67 wagon project
Is your carburetor opening all the way?
I'm Mike Goble and I approve this message.
Old 24th-January-2008, 02:58 AM   #5
1977stroked
(OP)
Yes, Ill check again tomarrow.
60ft 1.73
1/8 7.94 @ 86.34
Old 24th-January-2008, 03:07 AM   #6
1977stroked
(OP)
Any Ideas will be greatly appreciated. I was actually going to shift it at 6000 at the track but it is hard to get it to go to 4500 rpms let alone 6000
60ft 1.73
1/8 7.94 @ 86.34
Old 24th-January-2008, 08:46 AM   #7
chriss68
chriss68's Avatar
Nova(s): 1968 Nova SS 454
it sounds like to me its your carb. check your throttle linkage to make sure your carb is opening up all the way.
Chris
1968 Nova SS
454, TH350 Turbo, 10-Bolt 3:73
"What doesn't kill me, only makes me stronger!"
Old 24th-January-2008, 08:51 AM   #8
The Big Al
The Big Al's Avatar
Ign timing?
Did this start after tach install?
Did you have a differant tach before?
Old 24th-January-2008, 10:01 AM   #9
Mike Goble
Mike Goble's Avatar
Are you using an HEI ignition with the ballast resistor still in the circuit?
Old 24th-January-2008, 02:43 PM   #10
1977stroked
(OP)
I have had 2 carbs on here and they both do the same thing.
60ft 1.73
1/8 7.94 @ 86.34
Old 24th-January-2008, 02:44 PM   #11
1977stroked
(OP)
Ign timing?
It has always done this even before the tach install. Timing is at 38 total.
60ft 1.73
1/8 7.94 @ 86.34
Old 24th-January-2008, 02:46 PM   #12
1977stroked
(OP)
Yes I am running an HEI ignition with stock wiring(it came stock with HEI)
60ft 1.73
1/8 7.94 @ 86.34
Old 24th-January-2008, 02:58 PM   #13
veno
veno's Avatar
Nova(s): 72 385, t350, 3.73 4w-dsk
Garage
Two things come to mind, first is the HEI module... I have seen this happen before with a failing module... second... Valve springs....Weak?
a nation of free men, shall live forever, or die by suicide
Old 24th-January-2008, 03:06 PM   #14
1977stroked
(OP)
Ill look into the HEI module thing, but it runs so good on up to 4000 than it just wont go past. I dont think my valve springs are week because they are brand new and are made for high revving motors with the dual spring with an inner dampener inside of those. How much are those modules for the HEI?
60ft 1.73
1/8 7.94 @ 86.34
Old 24th-January-2008, 03:27 PM   #15
64PRONOVA
64PRONOVA's Avatar
Nova(s): 64SS & 65SS
I'd check the distributor out more closely. Remove the cap and make sure the mechanical advance flyweights aren't binding-up or being restricted in any way. Another thing to try is to throw another distributor in it and see if it get's any better.
I hate to say it but it sounds like iginition to me. It might be something else though but the most-obvious and easiest thing to eliminate first is the ignition. A stock engine will rev higher then 4,000 RPM.
Questions of efficiency- gear vs rpm davidkontra Drivetrain & Performance 7 14th-June-2006 12:49 AM
Steering Gear Quick Ratio Kit rellum Steering, Suspension, and Chassis 0 13th-June-2006 10:49 PM
Timing Gear Alignment novaracer1 Drivetrain & Performance 8 28th-May-2006 08:50 AM
Damaged ring gear kalle Drivetrain & Performance 4 12th-May-2006 07:46 AM
Need Product review.. Motive Gear ring & Pinion Pro-touring72 Drivetrain & Performance 5 29th-March-2006 08:44 PM
