How to clean up carbon on heads? - Chevy Nova Forum
Old 16th-January-2008, 11:50 AM   #1
ZNova
ZNova's Avatar
Nova(s): 67 383/200-4R
I need to clean a thin layer of carbon buildup on my AFR heads. I'm thinking carburetor cleaner, but will it be effective? What have you found to work the best for heads and/or pistons? Thanks for the help.
New years resolution: get rid of my spare tire....
Old 16th-January-2008, 01:48 PM   #2
MiniTubbedNova
MiniTubbedNova's Avatar
Nova(s): 70 Tubbed Nova
auto solutions sells this stuff called optimizer. we use it at aur dealership and that stuff will work better then pb blaster on bolts and will remove slugh on engines. The main popuose it ahs is to be sprayed into the cars intake while running at ~2000 rpm to clean the throttle body, intake runners, valves,
I would suggest that if you can find some pick up a couple of bottles. they work great for lossing bolts. They are sold to cusomters at our dealer ship as induction severice. I would call around to dealerships and ask if they carry auto solutions probucts and if they carry optimizer. And it comes with some fuel treat meant that works wonders on injectors and some final cleaning product spray for cleaning intake track.
This stuff works PERIOD.
Old 16th-January-2008, 02:20 PM   #3
theracer
theracer's Avatar
Nova(s): 64ht Pro Street 383,700r
Why not just leave it on the heads ,thus more compression?
THE RACER
Old 16th-January-2008, 02:29 PM   #4
jolietjake
jolietjake's Avatar
Nova(s): 1962 Chevy II 300
I in no way reccomend this, but back in the 60s and 70s guys would idle the engine at 2,000 rpm and trickle water, automatic trans fluid or rice down the carb to clean the carbon from inside of the combustion chamber.
"Build'em, drive'em, break'em."
Old 16th-January-2008, 03:18 PM   #5
The Big Al
The Big Al's Avatar
Title: Supporting Vendor
Nova(s): 68ss,70ss
Use kerosene to loosen it up.
after a little soaking and still wet.
I have used a brass wire coned wire wheel on a drill.
Will not cut the aluminum.
Will make a dam mess, but will clean them very well.
“The bitterness of poor quality & Service remains long after the sweetness of low price is forgotten”
Old 16th-January-2008, 04:54 PM   #6
Real McCoy
Real McCoy's Avatar
Title: Moderator
For a running engine you want to decarb just pour water down the carb while it's running. It still works fine and is often used by most dealers. This has been discussed to death here in the past. If you have the engine apart and want to clean the bowls and valve heads off you can use carb cleaner for light carbon build up if it will clean it up. Or you can use a wire brush and a rotary tool. If I pull the heads off I usually take them apart even if I don't do anything to them but look. RM
God Bless America, land that I love
2010 PRTA 5.30 Index Champion
Old 16th-January-2008, 05:16 PM   #7
Longroofer
Longroofer's Avatar
Nova(s): None - Sold
I assume from your post that the heads are on the work bench. If so, and the coating of carbon is light, you can use good old brake clean and a rag. I do this on heads that are lightly carboned and it works great. Spray it on, leave it sit a minute or two and wipe the carbon off. I did this last August to an engine I put in my Camaro that had approx. 13,000 miles on it. I had the heads off and I cleaned all the carbon off the heads and the tops of the pistons. Good Luck.
Chevy2ladys Hubby
ASE Certified Master Engine Machinist and Assembly Specialist. Building engines for over 30 years.
Old 17th-January-2008, 12:42 AM   #8
ZNova
ZNova's Avatar
Thanks for the ideas. I went with carb cleaner and very fine steel wool. They cleaned real easy, look much better.
finially found my heads but..... '74hatchback Drivetrain & Performance 9 12th-June-2006 06:12 PM
350 Chevy/Vortec Heads - Pushrods Dan_Lebherz Drivetrain & Performance 3 1st-June-2006 08:09 PM
Vortec heads questions 62bandwagon Drivetrain & Performance 5 29th-May-2006 03:07 PM
iron gm heads jlowery78 Drivetrain & Performance 6 25th-April-2006 04:11 PM
283 heads 1963DUCE100 Drivetrain & Performance 3 28th-March-2006 08:21 PM
