Home Made Paint Booth - Chevy Nova Forum
Old 8th-January-2008, 11:09 AM   #1
tnblkc230wz
(OP)
tnblkc230wz's Avatar
Nova(s): 1971 Nova
I'm trying to get the outside of the car primed this Saturday. I plan to frame a booth in my garage and cover it with plastic. I purchased a furnace fan on eBay that moves about 1600 CFM of air, so I should be able to keep it vented.
Should I push air into the booth or suck air out of the booth? I will have filters on the intake and exhaust side. Just not sure which way is best. Looking for any advice
71 Nova, Pro-Touring/Autocross
LS3 eRod, 6 speed.
Old 8th-January-2008, 12:25 PM   #2
Seattle_Mike
Seattle_Mike's Avatar
Title: Moderator
You want to pull air out...I hope you live out in the country or your neighbors probably won't be too happy with the toxic fumes etc., let alone Johnny Law. It's bigtime fines up here if you get caught spraying without a proper setup.
68 Camaro Nitrous ProMod 848ci Buck Racing Engines
Old 8th-January-2008, 12:32 PM   #3
63 Chevy II
63 Chevy II's Avatar
Nova(s): 63 Chevy II Nova 4-door.
x2 on the legal side of things. Definetly suck air out.
Old 8th-January-2008, 12:36 PM   #4
tnblkc230wz
(OP)
Nova(s): 1971 Nova
Thanks for the advice. People are pretty cool where I'm at. I will have a filter and can put a carbon filter on my fan. It will definitely help with the overspray and some with the fumes.
LS3 eRod, 6 speed.
Old 8th-January-2008, 03:48 PM   #5
tnblkc230wz
(OP)
Nova(s): 1971 Nova
Does anyone know of a good filter to put on my fan? I have a 20 X20 inch opening.
LS3 eRod, 6 speed.
Old 8th-January-2008, 07:56 PM   #6
1971novaSS
1971novaSS's Avatar
One recomendation, I wouldn't use the plastic sheeting to make the booth out of.
Ive tried this, and the results are not so good.
What happens with the plastic is that it creates a light static charge and collects dust like crazy! Then if you so much as fart in the booth it will project dust into the air and onto your paint.
Primer might not be that big of an isue, but when you go to lay down the good stuff i wouldn't recomend it.
If you are going to be painting in the garage, then clean the floor and lay old sheets over everything that is surrounding the area, Tool boxes.... work benches... ect.
Just my .02 $
Old 8th-January-2008, 08:07 PM   #7
tsimpson
tsimpson's Avatar
Title: Moderator
Nova(s): 73 SS 74
Just my .02 $
And wet the floor down. That will keep the dirt and dust down.
Tim
Little house, BIG SHOP!
Northstar Novas Club President
Old 8th-January-2008, 08:15 PM   #8
71SS454
71SS454's Avatar
Nova(s): 71 Nova 427 72 Ventura
Also, that fan, is it belt driven? You don't want to be pulling flamable solvent fumes thru an electric motor, it's like a homemade bomb waiting to go off.
Good rock and roll music should corrupt the young, it should corrupt them enough to think for themselves.
Old 8th-January-2008, 11:48 PM   #9
tnblkc230wz
(OP)
Nova(s): 1971 Nova
The fan is not belt driven. I will put a good filter and a carbon filter on it. I was thinking that would be sufficient to reduce the fumes before they get to the motor. Also, I'm moving enough air through the booth, I don't think the fumes will get that concentrated. A belt drive fan would still have its motor exposed to the fumes. There would have to be holes for the belt which expose the motor to fumes.
For plastic, I plan to use 3M masking plastic. That's suppose to be anti-static. Do you think that will work? I don't have that many old sheets.
LS3 eRod, 6 speed.
Old 9th-January-2008, 07:53 AM   #10
Novajay
Novajay's Avatar
Here are some older threads about garage painting:
http://www.stevesnovasite.com/forums...ht=paint+booth
This guy did his paint under one of those temporary garage thingies. Looks like the car was parked on concrete.
Start at page 3 of this thread and you can see how he set up his garage...
There was yet another thread that had a photo where someone set up electric box fans (2 or 3 IIRC) in a partially opened garage door. The guy even discussed the paint fume volatility. Can't find the thread...
I want to paint in my 1 car garage but it's attached to the house, so paint fumes getting inside is a major concern. May end up going to a shop.
Hope this trip down memory lane helps everyone.
Old 12th-January-2008, 01:27 AM   #11
Seattle_Mike
Title: Moderator
A lot of body shops will rent out their spray booths on weekends etc. It would save a lot of work and mess, and probably provide a much cleaner environment for painting. You will need to ensure you have a very clean air system as well that removes all moisture from the compressor air or it will make a mess of your paint.
Old 12th-January-2008, 11:13 AM   #12
tnblkc230wz
(OP)
Nova(s): 1971 Nova
Any recommendations on line dryers? I have a water separator on my tank, but I do get occassional moisture in my sander. I plan to buy a new air hose as the one I'm using is 17 years old. I've also bought plastic water filters from Sharpe that attach to the input of the spray gun.
LS3 eRod, 6 speed.
Old 12th-January-2008, 07:47 PM   #13
71SS454
71SS454's Avatar
Get a desacent hose, They attach to your compressor, then your air hose connects to it. They work pretty well, and much better than cheap water traps from hardware stores.
Old 13th-January-2008, 02:32 AM   #14
gfercaks33
gfercaks33's Avatar
Nova(s): 1973, 2 door coupe,350,350th tranny
novajay thank you i have been looking for that 3 thread you posted for a cool min
Old 13th-January-2008, 03:02 AM   #15
tnblkc230wz
(OP)
Nova(s): 1971 Nova
I did my garage like Argranda did his except I was able to pull the garage door down and run my fan. I only need the door open about 10 inches for the fan to blow out and I block the rest of the opening. I was pulling air from an open window in third bay. Finally primed! Well the body is anyway. Waiting on the frenders, doors and trunk to come back from being soda blasted.
LS3 eRod, 6 speed.
BPS Enamel Paint (Best Paint Sold) 69NovaSS Body and Interior 11 10th-September-2009 08:15 AM
3rd Gen dash paint taz3 Body and Interior 34 23rd-January-2009 06:22 PM
my little bundle of joy made it home!! strtlegal Show and Shine 11 18th-May-2006 10:11 PM
paint scheme...i want YOUR opinion new2novas Body and Interior 9 30th-April-2006 12:52 PM
Rattlecan Paint and pre-primer before paint shop Kev1 Body and Interior 10 26th-April-2006 08:45 PM
