Fireball Crane Cams HI-6 Ignition System - Chevy Nova Forum
Go Back   Chevy Nova Forum > Body, Chassis and Mechanical > Electrical
Old 1st-November-2007, 12:39 PM   #1
steelrat
steelrat's Avatar
Nova(s): 70 406-488hp/504tq,700R4
While investigating the compadability of the Crane Cams HI-6 Ignition System with a HEI distributor I see that a coil is used in the set up http://www.cranecams.com/pdf/90006462b.pdf
Not being too savy on the elec config of a motor I am confused. I thought the HEI distributor did not use a coil. If I am correct does this mean I need to add a coil to use the HI-6 Ignition System? pic of my motor attatched.
The HI-6 Ignition System lists for 219.00 -224.00. I can get a used one for less than half of that, so am interested in its compadability with my 406.
Drive break repair repeat
Enough tools, parts & money can repair all but the loose nut behind the wheel
Old 1st-November-2007, 01:02 PM   #2
Bscman
Bscman's Avatar
Nova(s): '72 2-door
Your picture shows a large cap/coil-in-cap HEI distributor.
Yes, you will need a coil.
Here's a like to the installation instructions for the "summit" brand ignition box.
Scroll down to page 8 to see install instructions for the coil-in-cap distributors.
http://static.summitracing.com/globa...sum-850600.pdf
You should find everything you need to know in the above link.
-Brett
Hope that helps!
Old 1st-November-2007, 01:23 PM   #3
steelrat
steelrat's Avatar
Thanks Brett, just what I needed.
