Carb sizes for a 406 - Chevy Nova Forum
Old 29th-August-2007, 03:08 PM   #1
steelrat
steelrat's Avatar
Nova(s): 70 406-488hp/504tq,700R4
Just wondering about peoples experiences with different carb sizes on a 406 would there be a significant difference in performance between a Holley 670 Avengr and a Holley 750 dbl pumper?
Drive break repair repeat
Enough tools, parts & money can repair all but the loose nut behind the wheel
Old 29th-August-2007, 03:16 PM   #2
T. Jerman
T. Jerman's Avatar
Nova(s): 1966 Nova SS
I'm running a 800 Holley on my 408sbc. It was pretty good right out of the box. Changed P.V and jets was all.
1966 Nova SS 4sp.
408 sbc.
420 hp + NOS
Old 29th-August-2007, 03:32 PM   #3
novamike
novamike's Avatar
Nova(s): 66 ht
Carb
I like Holley # 9381-830 cfm or #9380-850 cfm on my 406's. Annular boosters just tune better.
Mike
406.th400.9 inch,lots of Duct tape.
Superglue is my friend
Home of the famous "Bubba" burger
Old 29th-August-2007, 03:35 PM   #4
64PRONOVA
64PRONOVA's Avatar
Nova(s): 64SS & 65SS
I run a modified Holley Pro-Series 750 4150 on my 406.
Old 29th-August-2007, 03:39 PM   #5
Mike Goble
Mike Goble's Avatar
Nova(s): 67 wagon project
800 cfm Q-jet on mine.
I'm Mike Goble and I approve this message.
Old 29th-August-2007, 09:19 PM   #6
1quik69
1quik69's Avatar
Title: Moderator
Nova(s): 1972w/408,
Edelbrock 750 on ours.
Old 29th-August-2007, 11:03 PM   #7
bowtie0069
bowtie0069's Avatar
Nova(s): 69
Dale's (teddisnoke)406 runs a 770 Street Avenger; works pretty damn good--almost in the 11's with 3.08 gears.
69 Nova 410" small block-Driven to track
6.39 E.T./105 MPH--6.11/112.89 w/N2O
Old 29th-August-2007, 11:13 PM   #8
Ryan V64SS
Ryan V64SS's Avatar
Nova(s): 64 SS, 63 Sedan
750 demon double pump on mine. Suspect its too small though.
64 SS Street car. 10.60's on pump gas and 235 radials
Old 30th-August-2007, 12:33 AM   #9
Fatcat
Fatcat's Avatar
Nova(s): 67 100 2dr sedan, 409 sbc
850 DP works for me
67 Chevy II short rod 409 T400
Olds 3:42 posi 11.48 @115 motor
Old 30th-August-2007, 12:46 AM   #10
BadAss70Nova
BadAss70Nova's Avatar
Nova(s): 70 Nova
my brother has a 700 holley dp on his 406
1970 Nova 355 Crane Cam Flat Tappet 300 516/.525 106 LSA, SFC, TB350 PT 3000 Stall, 4.11s, Holley 700 DP
Old 30th-August-2007, 02:09 AM   #11
Pro-touring72
Pro-touring72's Avatar
Nova(s): 72 street fighter Ala Pro-Touring
Ditto. Tryed a 650 and 750 DP and the Q-jet flat out was the best.
A "Fast" Mustang is a Mythical creature. Much like a Quick unicorn
Old 30th-August-2007, 12:44 PM   #12
68SSGrandpa
68SSGrandpa's Avatar
My 406 needed a Holley 950 HP XE built specifically for my engine combinatipn by Patrick James.
Prior I had on a Speed demon 750, no choke, but could not regulate a good fuel curve no matter how much jet we put in it.
There are a number of formula's on the internet to calculate the correct CFM based on engine size Vol Eff % etc.
A simple 2 bbl did a fantastic job pulling school busses around on factory 400's.
Carb should be rated not on cubes alone, but how wild the build is.
Here is a link to Stan Wiess site. he is an old school guy, and only one of 100's of carb sizing resources.
To answer your question if there would be a signifigant difference between a 670 Aven, and a 750 double pumper, it depends on the engine spec, and on a mild build 406, the 750 has more CFM, and tuning potential.
http://users.erols.com/srweiss/calccarb.htm
68SS Nova
SB Dart 440"
Street tune 640HP 600TQ
TKO-600 Moser 4:11
Old 30th-August-2007, 12:54 PM   #13
Mike Goble
Mike Goble's Avatar
One thing to remember when using these carb calculators is that peak VE and peak rpm don't occur at the same point. You may have a 100% VE motor at 5500 rpm, but at 7000 rpm the VE is down to 90%. Which do you enter in the calculator?
Another pet peeve of mine is the nitpicking over 50cfm of carb potential, as in "should I use a 650 cfm or a 700 cfm carb"? The carb setup is as important as the size, the ability of it to get the right mix of fuel and air into the intake in a timely manner overshadows other considerations.
Old 30th-August-2007, 01:23 PM   #14
68SSGrandpa
Mike,
I agree, Carb sizing is pretty complicated for the novice guy if they don't know even ruff numbers of thier Vol Eff %.
There is no argument the tuning of any carb is where lots of power potential is unleashed, not just the CFM size.
SteelRat I belive has more potential with the 750 Holley. I hate buying parts twice, so if I know I am going to put heads, or a cam in an engine later, I would buy the right size carb now. A 670 Aven will limit a 406 depending on its spec's faster than the 750 will.
With induction on my 406, I kept reminding myself that a 406 is 10 cubes bigger than a 396BB, and just 20 cubes short of a 426 Hemi.
A 750 works fantastic on a GM Crate 454, or even a Crate 502.
Put a cam, and heads on those, and they would suck the metal off the inside of that 750 trying to get air.
Carb sizing is relative to not just cubes, Vol Eff, but most important how hairy the build is.
As I mentioned 2bbl 400's pulled 50 passanger school buses around for years.
68SS Nova
SB Dart 440"
TKO-600 Moser 4:11
Old 30th-August-2007, 01:34 PM   #15
Mike Goble
Mike Goble's Avatar
Originally Posted by 68SSGrandpa View Post
Mike,
What is "hairy" and how does the "hairiness" of the build effect the selection of a carburetor? Do NASCAR engines make the power they do because they're "hairy" or because they have a high VE at a high rpm?
Flooded Carb, any suggestions? paco Drivetrain & Performance 3 14th-April-2008 04:10 AM
Carb question Bamma Drivetrain & Performance 5 28th-January-2008 09:32 PM
Why does a car using VS carb not run as fast as one using a DP? NovatoriusRex Drivetrain & Performance 23 25th-January-2008 12:23 AM
283 carb issues? Mike Hall Drivetrain & Performance 0 31st-March-2006 01:24 AM
AN vs. NPT: Understanding port threads, adapter fittings and line sizes. DriveWFO Best of Drivetrain & Performance 0 23rd-March-2006 10:07 PM
