.l-79 transmission vin stamping - Chevy Nova Forum
Go Back   Chevy Nova Forum > General > Originality
Old 29th-August-2007, 06:08 AM   #1
fastfred67
(OP)
Title: Nova Newbie
Question .l-79 transmission vin stamping
where on the case were the 1966 muncie transmissions for l-79 cars stamped with the VIN number. also-were they stamped with the same characters as the engine stamp.
Thanx
Old 29th-August-2007, 04:08 PM   #2
CdnL79 Registry
CdnL79 Registry's Avatar
Title: Moderator
Nova(s): See my signature.
L79 or not, Muncie's usually had the VIN code stamped on the top or side of the main case. They are frequently found near the date code stamping. As usual in those days, there was great inconsistency from plant to plant in how this was done, so there is no norm.
Bob
62 Acadian cvt sold
63 Nova SS cvt sold
66 Cdn. Nova SS L79 sold
70 Nova SS L78 sold
Old 30th-August-2007, 12:37 AM   #3
1963wagonman
1963wagonman's Avatar
Nova(s): alot
the vin # on the engine and muncie trannies were stamped with the same gang holder.at the same time.
the following picture shows my z/28 muncie trans stamp. this location and style is typical throughout the 60's.unfortunately re-stamping is becoming very popular in our hobby.therefore i have collected an extensive database on both authentic and reproduction engine and muncie stampings.
Old 6th-September-2007, 09:57 AM   #4
bartsl79
bartsl79's Avatar
Here's my M21 out of my L79
Old 2nd-November-2007, 04:26 PM   #5
fastfred67
(OP)
Title: Nova Newbie
trans vin
my engine vin was not stamped with a gang holder and I assume the trans was vin stamped at the same time as the engine by the same person. My question is-were the two numbers the same? I have heard that sometimes the transmission only used the vin# without the year and plant suffix i.e. 6N for example. Any input??
Old 7th-November-2007, 06:31 PM   #6
Aztec Bronze L79
Nova(s): '66 CHEVY II SS L79 factory A/C Aztec
L79 trans vin
I wrote down my vin # the way it appears on the trans,sequence number is all they used.
Old 7th-November-2007, 08:15 PM   #7
Mike McKown
Nova(s): 1965 Nova SS FI 1970 Nova SS 375
The assembly plants used a gang holder to stamp both the engine and transmission with the same VIN #.
I have a '66 L-79 factory engine that has no VIN # on it. Just the engine plant assy date and engine code.
I didn't think Chevy II's got the VIN stamped on the engine/transmission until '67 or '68?
Old 7th-November-2007, 10:31 PM   #8
Aztec Bronze L79
Vin # on engine & trans
Chevrolet by the numbers,page 39, 1966
all final assembly plants stamped the plant designation and continous sequence number portion of the VIN on all 327,396 AND 427 cubic inch engines except for corvette.
Old 8th-November-2007, 11:39 AM   #9
bartsl79
bartsl79's Avatar
66 Chevy II's did have the last 6 numbers of the vin
stamped on the block and the transmissions.
Tom
Old 8th-November-2007, 07:55 PM   #10
Mike McKown
All I said here was that I had an L-79 factory engine that was in a factory built car that had no VIN # stamped on the block. Oddball? I don't know. I didn't have the transmission.
Corvette's have had the VIN # stamped on the block since January of 1960.
Old 8th-November-2007, 08:09 PM   #11
fastfred67
(OP)
Title: Nova Newbie
clarification
as I said before-my block is stamped with the year -(6) and the assembly plant (N) and the sequence #. Again-it was not stamped using a gang holder-it is obvious that each number and letter was stamped individually because they are not perfectly straight. I have seen other blocks which are stamped exactly like mine. I agree that corvette blocks were gang stamped but I don't think that nova blocks were. I also believe that only the hipo engines were serial # stamped. My question concerns the transmission stamping. My transmission only has the sequence number stamped on it-not the year and assembly plant stamps. again-they are not gang stamped. My question is this-- is my car an abberation or is this the norm for 66 L-79 cars?
Old 8th-November-2007, 09:50 PM   #12
Aztec Bronze L79
[QUOTE=Aztec Bronze L79;680747]
"Chevrolet by the numbers,page 39, 1966
all final assembly plants stamped the plant designation and continous sequence number portion of the VIN on all 327,396 AND 427 cubic inch engines except for corvette.On Corvettes only the continuous sequence number was stamped."
Old 8th-November-2007, 10:11 PM   #13
Aztec Bronze L79
Fastfred67,It looks like yours and mine are stamped the same way,I think the engine I.D. may be gang stamped,different size character also.Mine is F0217ZJ factory A/C.
Old 9th-November-2007, 05:39 AM   #14
fastfred67
(OP)
Title: Nova Newbie
trans vin
Aztec-
I agree-the engine code was stamped at the foundry after final assembly with a gang holder.
And you are right that the serial number characters are smaller than the engine id #'s-probably 1/8". Are you saying that your trans is also stamped with only the sequence # like mine? Thanx for the quote from the chevy by the numbers book-that verifys that only the hipo engines (327's) in 66 novas were serial numbered
Transmission help standpiper77 Drivetrain & Performance 1 9th-June-2006 10:01 AM
Transmission Bellhousing/torque converter torque settings malcom2073 Drivetrain & Performance 1 25th-May-2006 12:39 PM
transmission leak - kickdown cable bandit610 Drivetrain & Performance 1 13th-May-2006 06:54 PM
Blew my first transmission, 2 months after buying the car! malcom2073 4th Generation Nova's 1 10th-May-2006 02:18 PM
Transmission adapter plate question 66novaHT Drivetrain & Performance 5 31st-March-2006 10:32 AM
