'67 Steering Column Bearing - Chevy Nova Forum
Old 22nd-June-2007, 01:18 PM   #1
bfields
(OP)
Title: Nova Newbie
I just removed the front clip from my '67 for a TCI frame and found out the end of the steering column flops around. There is evidently a bearing that is missing.
Can anyone provide me insight on this bearing, like how do I replace it and where do I get one?
Thanks,
Brian
KC Nova Club
Old 22nd-June-2007, 01:37 PM   #2
Joe Nova
Joe Nova's Avatar
Nova(s): 66 hardtop
Brian,
I got mine from Heights
66 Nova LS1 6 speed Height front clip
Old 23rd-June-2007, 09:28 PM   #3
1BluII
1BluII's Avatar
Nova(s): 67 Nantucket Blue hardtop
By "the end of the steering column flops around", do you mean the shaft inside the column tube is loose, or is the entire column flopping around?
If the latter, it means you are missing the lower column mount (as was I when I bought my car, previous owner apparently felt it unnecessary) which you definitely will need with an aftermarket front clip. It's a one year only item unique to 67's, as in the years prior to that the steering shaft was a one-piece unit all the way up to the wheel, with the column going over it. I found one on Steve's site - I'm sure one of the guys on here has one, if that's what you need.
If it really is the bearing, I could be wrong, but I think you can still get the lower bearing from GM - not sure. I wimped out and bought an Ididit column...which is really nice
67 Nova Hardtop
Old 23rd-June-2007, 10:43 PM   #4
bfields
(OP)
Title: Nova Newbie
It is the shaft that's flopping around, not the full column. Looks like I will be picking up the bearing.
But, now that you mention that, I have been wondering where this lower column mounting bracket is installed. Is it inside or outside? It came with the Heidt's adapter kit for stock '67 column to the rack-n-pinion setup. Oddest looking thing and was wondering why I needed it. Now that you mention the 'floppy column' I know why
Old 23rd-June-2007, 10:50 PM   #5
67 Red SS
67 Red SS's Avatar
Thanks,
Brian
KC Nova Club[/QUOTE]
I ran into the same problem.i could not find one and had to go to the local bike shop to get the small ball bearings to rebuild it.
67 Nova SS 11837
Old 23rd-June-2007, 11:47 PM   #6
NovatoriusRex
NovatoriusRex's Avatar
Nova(s): 67 Chevy II Nova Hardtop
Here's a pic of the 67 lower column bearing. It's held in place by a spring clip on the end of the steering shaft. It's got a slight interference fit into that plastic housing on the bottom of the column. After removing the plastic column bearing housing, just a couple of whacks with a small punch & hammer after removing the spring clip, and the bearing will drop right out.
I bought my replacement bearing from Chevy2Only (part#38009-1). Others may have them available, but I had trouble finding listings, so I just bought it from them. It fit perfectly.
-Brent
I want a new duck. One that won't steal my beer... - Weird Al
Old 24th-June-2007, 10:11 AM   #7
1BluII
1BluII's Avatar
I've never seen the Heidts bracket, so I'm not sure on that one - the factory lower column mount goes on the inside - There are 3 (I think, maybe 4) captive nuts on the firewall to which to bolt it.
67 Nova Hardtop
Old 26th-June-2007, 08:54 AM   #8
bfields
(OP)
Title: Nova Newbie
Thanks for your help!!
Thanks to everyone who helped me out. I did end up ordering the bearing from Chevy II Only, and there is a lower column mount already on the column, so I won't need the one from Heidt's.
Again, Thanks!!!!!
Old 15th-March-2016, 03:47 AM   #9
orange_roc
orange_roc's Avatar
Nova(s): 1967 Nova SS
I too see I am in need of this lower column bearing for my 67. I looked it up on chevy2only, and it was $69. Has anyone for it cheaper, or made another bearing work? Thanks.
Sent from AutoGuide.com Free App
12.06@112mph
NA 406 TH350 3.08
Old 15th-March-2016, 03:48 AM   #10
orange_roc
orange_roc's Avatar
Has anyone found one cheaper*
12.06@112mph
NA 406 TH350 3.08
Old 15th-March-2016, 08:44 PM   #11
jr1967
jr1967's Avatar
Title: Nova Newbie
Nova(s): 1967 chevy 2
Go to your local gm dealer and the lower bearing for the steering colum for 95 s10 will work if you have trouble I have the part # some where
Old 15th-March-2016, 09:14 PM   #12
orange_roc
orange_roc's Avatar
Awesome. Thanks!
12.06@112mph
NA 406 TH350 3.08
Steering Column Removal Tman1800 Steering, Suspension, and Chassis 6 29th-January-2017 07:47 AM
How do you replace the upper steering column bearing? ToocoolSS Steering, Suspension, and Chassis 8 14th-March-2008 01:36 PM
1969 nova steering column issue bigvan98 Steering, Suspension, and Chassis 1 17th-January-2008 07:31 PM
burnt steering column white2doorPST408 Steering, Suspension, and Chassis 2 25th-May-2006 11:22 PM
Steering column woes MELUVNOVA Steering, Suspension, and Chassis 5 5th-April-2006 12:00 PM
