rockers for 406 sbc 1.5 1.6 or both - Chevy Nova Forum
Old 21st-May-2007, 08:51 PM   #1
aero993
(OP)
Title: Nova Newbie
I was on the phone today with Crower. I asked what rockers they recommended? I was told to use 1.5 and 1.6 rockers. I'm just curious as to how many out there split the rockers on there sbc 400. Is there a preference or a least favorable brand of rocker?
TIA
Old 21st-May-2007, 08:54 PM   #2
DriveWFO
DriveWFO's Avatar
Nova(s): 74 Nova...R.I.P
Every engine combo is unique. You can experiment with 1.5 and 1.6 rockers on the intake & exhaust and see what your engine likes. You might only see a difference on the engine dyno though. Remember to check for adequate pushrod hole clearance in the heads before swapping on the 1.6 rockers.
Don't worship false idles
Old 21st-May-2007, 09:43 PM   #3
Fast Eddie
Fast Eddie's Avatar
Nova(s): 1966 Nova
I use 1.6 on a Lunati roller with .550 lift, the final lift is .570.
Fast Eddie
1966 Nova
408 cu in SBC
Aqua
Old 21st-May-2007, 10:00 PM   #4
novamike
novamike's Avatar
Nova(s): 66 ht
rockers
Make sure that you use a long enough rocker stud so that your rocker is located on the stud and not on the threads, and has enough length to get good thread engagement for your poly-locks.
Installing roller rockers can create there own problems if you don't check the details.
Mike
406.th400.9 inch,lots of Duct tape.
Superglue is my friend
Home of the famous "Bubba" burger
Old 21st-May-2007, 11:22 PM   #5
agpd45
I'm probably just doing the math wrong... but with a camshaft with .550 lift with a 1.5 rocker, I get 586 lift with a 1.6 rocker.
Math: .550 divided by 1.5 and then take the number and multiply it by the new 1.6 rocker???
I'm probably doing a newbie mistake.
Artie
Old 22nd-May-2007, 12:00 AM   #6
Mike Goble
Mike Goble's Avatar
Nova(s): 67 wagon project
.550/1.5 = .3667
.3667 x 1.6 = .5867
I'm Mike Goble and I approve this message.
Old 22nd-May-2007, 08:10 AM   #7
rhorne12
Nova(s): 1962 Nova
I like the 1.5 exhaust and the 1.6 intake. There is more to it than just the difference in lift. The entire lift curve is changed by the rocker ratio. Most intakes need the quick lift to get the valve open and the flow started, most exhaust (except turbo) do not need that.
If the cam is not already too big, the intake 1.6 usually helps. One the exhaust, esp. automatic, the 1.6 doesn't seem to help or may even hurt performance a little.
Old 22nd-May-2007, 09:37 AM   #8
Paul Wright
Paul Wright's Avatar
Originally Posted by Mike Goble View Post
.550/1.5 = .3667
.3667 x 1.6 = .5867
Ah,yah got me. That's what I get for using the adding machine (accidentally set to "cut") by my desk instead of the calculator
Originally Posted by Paul Wright
Building a small, high rpm engine
with the perfect bore, stroke and rod ratio is very impressive...
like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar.
Cubic inches is like Indiana Jones with a cheap pistol.
Old 22nd-May-2007, 10:01 AM   #9
SeventyNova
You were probably thinking that it was a solid cam with lash of 0.016", this would make the lift at the valve (0.586 - 0.016 = 0.570") Right??
Old 23rd-May-2007, 10:23 AM   #10
Pwrtrip75
Pwrtrip75's Avatar
get the right cam you want and dont screw the geometry of the valvetrain up trying to get more lift. I had nothing but problems with 1.6s.
Bent pushrods, broken studs....
72 Nova- LS 370 88mm turbo 4 link
99 Transam-LS 370 76mm turbo
71 Chevelle slow 350 building a LS 5.3
Old 23rd-May-2007, 10:53 AM   #11
aero993
(OP)
Title: Nova Newbie
The cam is made by Crower, the tech guy at Crower recommended splitting the rockers.
Old 23rd-May-2007, 05:16 PM   #12
DriveWFO
DriveWFO's Avatar
If the geometry is correct, it won't "screw" anything up. A lot of guys try different rocker combos out. Changing the rocker ratio effects more than lift.
Old 23rd-May-2007, 05:21 PM   #13
69NovaSS
69NovaSS's Avatar
Yes it effects duration slightly too....and I think it opens and closes the valves faster if you increase rocker arm ratio..
NPHNP
Do you recognize this vin:114279W458662
Roller Rockers/1.6 Rockers/Roller tip rockers Repointer Best of Drivetrain & Performance 101 26th-February-2007 10:36 AM
350-400 SBC Flywheel ? novaracer1 Drivetrain & Performance 2 12th-June-2006 04:08 PM
dual quad sbc build up sYc_12B Drivetrain & Performance 9 16th-May-2006 10:19 AM
sbc cyl-heads? Nova Bob Drag Racing Forum 18 2nd-April-2006 01:52 AM
longshot...Id rockers? Gates72ss Drivetrain & Performance 3 27th-March-2006 12:53 PM
