add-a-leafs or helper springs? - Chevy Nova Forum
Old 10th-May-2007, 03:42 PM   #1
Hack Job
(OP)
anyone run these? the back of the wagon is pretty soft and I'd like to add more cargo capacity. I was thinking I could use a helper spring or add-a-leaf. Anyone using these?
I was thinking something like the 550, but I'm not sure if this would add extra stress to the other side of the spring. Could I use the 990 or something similar on a mono-leaf?
thanks.
64 wagon
Old 10th-May-2007, 04:02 PM   #2
davidr5610
davidr5610's Avatar
Nova(s): 1970 Nova, 1971 Nova
I have the 550s on my 70 Nova, it makes the back end stiffer and ride higher, but it looks like mine are on the wrong side on the spring. Oh well, it works fine for me.
70 Nova-355/Th-400/3.73s. 12.35@107
71 Nova-350/Th-350/3.08s. 13.42@104
2016/2013 Sportsman Champion
Old 10th-May-2007, 06:08 PM   #3
Bscman
Bscman's Avatar
Nova(s): '72 2-door
If you're trying to RAISE the rear end, these aren't what you should be looking for. Generally, they will NOT raise the rear...they just keep the springs from excessively sagging under a heavy load.
If I were going to add any type of "helper" spring, it'd be an airbag setup. You can get a pretty decent setup for about $320, with in car adjustability (load leveling).
Something like this:
http://store.summitracing.com/partde...5&autoview=sku
And these:
Obviously, those probably aren't the exact part #'s you would need. But they will offer ADJUSTABLE load leveling from inside the car, and if you really wanted, you could use them to lift the rear slightly above stock ride height.
Have you thought about new springs all-together? You can get some pretty good springs from $200 -- I would bet you could get something a bit stiffer in the aftermarket or custom made.
How old are your current springs?
There's also air shocks, if interested....
Add-a-leafs are a thought, but will generally RAISE your rear end higher than it currently sits. They are, however, cheap ($35 a pair).
lowering springs AND drop spindles? sterho Steering, Suspension, and Chassis 11 13th-June-2006 04:42 PM
1964 Chevy II mono leafs to multi leafs chevyii Steering, Suspension, and Chassis 2 26th-May-2006 09:35 AM
front springs and shocks joey d Steering, Suspension, and Chassis 1 12th-April-2006 11:35 PM
restoring leaf springs? 74customnova Originality 1 3rd-April-2006 10:33 PM
Help me learn about valve springs (long, as usual) patman Drivetrain & Performance 15 28th-March-2006 06:39 PM
