harmonic balancer bolt 327 - Chevy Nova Forum
Old 15th-April-2007, 05:11 PM   #1
RICKSNOVA
(OP)
Title: Nova Newbie
Nova(s): 74 ss
I've got a 1962 model 327 and I noticed that the harmonic balancer will just slip right off of the crank. I know this is a problem. What is the best way to fix this? I've been told that it needs a bolt to hold it on, but how do you do this on a built engine. Its on an engine stand right now. Can a person drill and tap the crank? Thanks for any help.
Old 15th-April-2007, 05:19 PM   #2
the FLYER
the FLYER's Avatar
Nova(s): The Pillars of Society
i'd be first concerned if it's the dampner or if the crank snout is off... dampner too big, snout too small.
i've seen where some guys have the dampner honed for a slip fit but i'd really doubt that's the case in your situation...
check the size/thread pitch of a C/S bolt and YES the snout can be drilled and tapped... make sure it's very straight though. the job IS much easier to do with crank out of engine but it can still be done... don't get any debris in through the timing cover seal area... that'd be a bad situation for sure
the Flyer Special
'64 411 377-Tko600-3:73's
Old 15th-April-2007, 05:29 PM   #3
RICKSNOVA
(OP)
Title: Nova Newbie
Nova(s): 74 ss
thanks for the info
Me and my father rebuilt this engine probably 10-15 years ago. It was the orig. balancer that came off of the motor. I know it definately didn't slide back on when we put it on then. It is still fairly tight now but will just slide off without alot of effort. Probably lucky it didn't come off when it was in the car. Thanks
Old 15th-April-2007, 05:33 PM   #4
the FLYER
the FLYER's Avatar
i've always liked the comfort of knowing there's a bolt there... a little insurance, ya know ???
ya might wanna drill & tap it... but be carefull to D&T straight and correct size (which i ferget right now)
the Flyer Special
Old 13th-February-2008, 11:45 PM   #5
76SleeperSS
76SleeperSS's Avatar
Title: Nova Newbie
I already played that game once. If the motor is still out of the car, pull the crank and take it to the machine shop. Let them do it up or get another crank. Shortcuts are usually an inexpensive way to spend a lot of money at the worst possible time, causing the most amount of inconvenience possible. Bolting the balancer and the extra effort gave me a warm fuzzy after we launched one. An expensive lesson and very inconvenient. Would have been way cheaper to go with my gut instinct. Usually, if I ask myself the question, I need to do it. Can't be much help other than some experience brother.
'76 SS 350 4 speed Nova
'69 427 El Camino
'75 Silverado Step Side
'28 Model A
'50 F1
Old 14th-February-2008, 12:42 AM   #6
The Big Al
The Big Al's Avatar
Nova(s): 68ss, 70ss (SOLD)
this thread is old!
“The bitterness of poor quality & Service remains long after the sweetness of low price is forgotten”
Old 14th-February-2008, 12:53 AM   #7
76SleeperSS
Title: Nova Newbie
Sorry Al, didn't see the dates. Just running through the site having a good look about.
'69 427 El Camino
'28 Model A
'50 F1
Old 14th-February-2008, 11:59 AM   #8
Paul Wright
Paul Wright's Avatar
the Best of Tech archive has more on the subject. And yes, they are "old" threads.
Originally Posted by Paul Wright
Building a small, high rpm engine
with the perfect bore, stroke and rod ratio is very impressive...
like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar.
Cubic inches is like Indiana Jones with a cheap pistol.
Old 14th-February-2008, 12:45 PM   #9
The Big Al
The Big Al's Avatar
HA HA, don't feel bad, I had a big old spill going when a post caught my eye from a member no longer with us.
Al
8.5 = 8.78 or how to turn a 10 bolt 8.5 in to a 12 bolt! well almost. veno Drivetrain & Performance 15 24th-March-2010 02:16 PM
All 2 bolt, 4 bolt, 4 splayed cap, studs, align boring Q's (Merged) Ed's68 Best of Drivetrain & Performance 126 23rd-May-2009 10:20 PM
Harmonic Damper / Balancer Q&A (combined) 73SSHatchMan Best of Drivetrain & Performance 123 14th-February-2008 12:49 AM
Broken Bolt In Alum Head Steves 70SS Drivetrain & Performance 14 22nd-May-2006 01:30 PM
Moser's Camaro 12 bolt Steelghost Drivetrain & Performance 3 5th-April-2006 07:16 AM
