rear end gears - Chevy Nova Forum
Go Back   Chevy Nova Forum > General > Drag Racing Forum
Old 4th-March-2007, 07:26 PM   #1
youngin69nova
(OP)
youngin69nova's Avatar
Nova(s): 69
rear end gears
how big of a difference do gears make? is there a general rule? would there be a noticable difference in the 1/4 between 3:73's and 3:55
Old 4th-March-2007, 07:34 PM   #2
bowtie0069
bowtie0069's Avatar
Nova(s): 69
I doubt you'd notice a thing.
69 Nova 410" small block-Driven to track
6.39 E.T./105 MPH--6.11/112.89 w/N2O
Old 4th-March-2007, 07:40 PM   #3
youngin69nova
(OP)
Nova(s): 69
so why would someone choose the 3:73's over the 3:55's
Old 4th-March-2007, 08:14 PM   #4
rjy
Nova(s): 1964 nova
You may not notice a 3.55 change to a 3.73, I sure you would notice a 3.08 to a 3.73 or 411. On a street car I would not want to go larger then a 3.73 because unless you had a 700R4 trans the Hi/Way speeds of 60 MPH and higher would keep the RPM of the motor to high. I run a 3.36 gear on mine and can go anywhere I want without fear of this happening. Now if my car spent more time at the strip then it did on the road I would want a 4.11 ring gear so when running the 1/4 mile track I would enter the end of my run in 4th gear at max RPM.
Old 4th-March-2007, 10:19 PM   #5
74 hatchback
74 hatchback's Avatar
Nova(s): 74 NOVA HATCHBACK
not much diff, but i wouldnt go deeper than 3.73 if you like to drive it on the street, run the 3.55 for BBC and 3.73 for a sbc, on the strip i would go 3.73 for BBC and 4.11 for a sbc.
Old school means real!
Old 4th-March-2007, 10:33 PM   #6
MuscleDreams
MuscleDreams's Avatar
I run 4.11's on the street with a 26" tire. I run about 3000 rpm at 55mph.
My trips are short though cruise through town a few times and thats about it.
Ted Nugent '08!
Best time 7.14 @ 98 1/8th 9.19 @ 110 1000' 1.58 60' Car Weighs 3320 without driver, 3570 with
Old 5th-March-2007, 11:48 AM   #7
jcs
jcs's Avatar
Nova(s): 67 SS 4 speed
On my Nova I went from 308 to 373, very noticable difference. Could tell big difference from a dead stop, from 20 mph up and at cruising speed on highway. I have 355 on my Mopar and it is what I consider a perfect gear if you are going to be driving it mostly on the street. Not bad at all on the highway and good everywhere else.
67 Nova HT, 4 Speed
70 Duster-340
2006 Custom Bike
Old 5th-March-2007, 01:36 PM   #8
NovatoriusRex
NovatoriusRex's Avatar
Nova(s): 67 Chevy II Nova Hardtop
Try this calculator. http://www.chevellestuff.com/generic/rpm_calculator.htm
It'll let you know what RPM you'll be running at in any gear at a specific speed. I played with it and changed the rear gear ration from 3.55 to 3.73 and got these results (using a 235/60-15 tire):
3:55 gear final RPM at the trans' 1:1 3rd gear ratio:
75MPH = 3428RPM
3:73 gear final RPM at the trans' 1:1 3rd gear ratio:
75MPH = 3602RPM
As you see, it's not a ton of difference between 3.73 and 3.55. At the track that 174RPM difference could alter ET/MPH at the traps slightly though and help keep you in your power band more easily.
I used 3.55 gears in my car and it's great for cruising around town. On the highway it's a bit much, but that's the price we pay for quick acceleration.
-Brent
I want a new duck. One that won't steal my beer... - Weird Al
Rear Window Defog Idea tpinovaII Body and Interior 16 7th-October-2006 08:05 PM
Rear end swap Soonerfan41 Drivetrain & Performance 3 25th-May-2006 07:46 PM
Set up new rear end 1963DUCE100 Steering, Suspension, and Chassis 0 8th-May-2006 12:58 PM
Rear Gears Whining Rice Killer Drivetrain & Performance 4 15th-April-2006 07:28 PM
Rear end Questions... 68Nova2 Drivetrain & Performance 12 14th-April-2006 06:41 PM
