Turn Signal Switch Removal - Chevy Nova Forum
Go Back   Chevy Nova Forum > Body, Chassis and Mechanical > Electrical
Old 17th-February-2007, 01:31 AM   #1
papasnova
(OP)
papasnova's Avatar
What is the best way to remove the switch and the wiring from the steering column once the switch is disconnected? How do you get the wiring harness and connector out of the column?
Larry at Papas Nova
Old 17th-February-2007, 01:46 AM   #2
the FLYER
the FLYER's Avatar
Nova(s): The Pillars of Society
Larry, i'm not sure of your year but it pulls out the top. slide the wire connector up inside the steering column and pull it out. last one i did was on a '55 and when i pulled out the old i pulled a wire (fishtape) with it and pulled the new one in for reinstall...
hope i helped in some small way
the Flyer Special
'64 411 377-Tko600-3:73's
Old 17th-February-2007, 08:36 AM   #3
papasnova
(OP)
papasnova's Avatar
I am wondering how one gets a hole big enough to slide the connector through. I must have to unbolt the column support and drop it down a bit.
Thanks for the comments
Larry a Papas Nova
Old 17th-February-2007, 02:20 PM   #4
papasnova
(OP)
papasnova's Avatar
Larry at Papas Nova
I got the switch installed and all the lights work perfect. So my Ron Francis harness installation from front to rear is complete...
Thank you...thank you very much..
Larry at Papas Nova
Old 17th-February-2007, 02:22 PM   #5
wskaiser
wskaiser's Avatar
You do have to drop the column support and let the column drop down and the you can snake the plug and wiring out through the column. At least that is the way mine comes out of my 65.
Looks like I was a couple of minutes late with my post. Glad you got it working.
65 SS L30 327, M21 Muncie, 331ratio 12 bolt rear, factory air
NNN member since 1986
"You can't cure stupid"
Old 17th-February-2007, 04:27 PM   #6
papasnova
(OP)
papasnova's Avatar
Thanks for the input anyway. I did just as you said...
Larry at Papas Nova
71 Ignition switch removal help super_davecars Body and Interior 3 20th-December-2007 02:48 PM
front turn signal lights Novachef Electrical 3 14th-June-2006 11:52 PM
Amber Or Clear Front Turn Signal For a 70 green72 3rd Generation Chevy II/Nova's 8 18th-May-2006 04:26 PM
72 nova turn signal switch Real McCoy Electrical 1 4th-May-2006 02:27 PM
Turn signal switch kceb10 Electrical 1 3rd-April-2006 01:03 AM
