Big block power steering pump - Chevy Nova Forum
Old 21st-January-2007, 11:42 PM   #1
1quik69
(OP)
1quik69's Avatar
Title: Moderator
Nova(s): 1972w/408,
What other years and engine combos would use the same power steering pump as a 69 BB car?
Old 22nd-January-2007, 01:29 AM   #2
Bscman
Bscman's Avatar
Nova(s): '72 2-door
Assuming its the traditional saginaw type pump...
The most common ones you'd find in a yard would be anything gm with a V8 (and probably even a v6) from the 70's and 80's...
FWIW, I picked a remanufactured one up for my bro-in-law a few months back for a little over $40 from a local parts store...they're pretty cheap--but you'll still need a pulley.
Old 22nd-January-2007, 02:12 AM   #3
72GreenRally
72GreenRally's Avatar
Nova(s): '72 Green Rally Nova
I could be wrong, but I think the power steering pump for a BBC is different than the pump on a small block.
I'm going to change the title of this thread so it will get the attention of the BBC guys, so you can get a better answer.
randy
Are you pondering what I'm pondering?
Old 22nd-January-2007, 08:08 AM   #4
veno
veno's Avatar
Nova(s): 72 385, t350, 3.73 4w-dsk
Garage
camaro 67/68, corvette 66/72 ( I don't remember if vette switch to the long pump after 68 purdy sure they didn't.), impala, truck don't know the years seen a many short water pump bbc trucks. if your looking for correct then I don't know, fitments?, any of these should do.
a nation of free men, shall live forever, or die by suicide
Old 22nd-January-2007, 01:29 PM   #5
Bscman
Bscman's Avatar
Nova(s): '72 2-door
When I first bought my '68 pickup, it had a 454 from a 70's suburban.
When I later switched it out for a late model small block, I re-used the p/s pump off the big block...
Worked for me, but I guess YMMV.
Old 22nd-January-2007, 05:39 PM   #6
taz3
taz3's Avatar
Title: Moderator
Nova(s): 2 69 SS BB L78's & 69 4dr
My old boss had a 67 Chevelle that we swithed a 396 - 327 back and forth I don't recall any trouble with power pump interchangeabilty.
3 69's, 2 L78's, 51 Fathom & 71 Lemans #'s match both w/4spds & 69, 53 glacier blue 4 door
Old 22nd-January-2007, 05:56 PM   #7
monk
monk's Avatar
The only issue I had with the p/s pump when I did my BB transplant was the small tube coming out the back of the pump (return hose)........I think the correct big block pump should have the tube lower towards bottom of pump.....mine was a a bit higher on the back which didn't give me a lot of room for adjustment (it hits on the block) but it works.
STUGOTS Midwest
Old 4th-March-2007, 03:52 PM   #8
1quik69
(OP)
1quik69's Avatar
Title: Moderator
Nova(s): 1972w/408,
Well, I went and picked up what was supposed to be a BB power steering pump for a 69 yesterday at kragans. I noticed right off that the return line fitting faces to the front. It comes out the back and curves around with the opening at the front. This line also will not let the adjustment bracket bolt to the pump as it interferes with the bracket. Does anybody have pictures of the pump and brackets for a bb that they are using. If you had them off the car and disassembled that would be even better. I can't imagine having the return line facing to the front of the car but who knows. Or even better if someone has a part # from Kragen/autozone that they know works. The part # I got at Kragen was 2-6000.
Old 4th-March-2007, 05:00 PM   #9
nova66mussl
nova66mussl's Avatar
Nova(s): 66 H/T 66 Wagon 1933 Fo
Keep in mind that some mid 60's big blocks had a remote resevoir pump. My buddy has a 67 Chevelle ss 396. It has a factory remote resevoir so the pump will probably be different.
Old 4th-March-2007, 07:30 PM   #10
1quik69
(OP)
1quik69's Avatar
Title: Moderator
Nova(s): 1972w/408,
Well after a trip to Kragen today It looks like what I need is the pump listed for 68 Chevy 2 or 68/69 camaro with 396. Per their picture the return line on this pump is in the middle of the back and points straight down which would work. I will know Tuesday as they had to order it. It's things like this that make you mad and make you think at the same time. That's why I like this hobby. It makes me think.
Old 4th-March-2007, 10:11 PM   #11
taz3
taz3's Avatar
Title: Moderator
If you still need a pic I can try tomorrow I need to dig it out let me know and I will.Other wise I won't.
Paul
Old 4th-March-2007, 10:38 PM   #12
monk
monk's Avatar
Quick.....
Thats the one you need.........on my big block project I found an NOS one,it was the correct style but the return line was higher on pump.......see pics.
It worked but don't have a whole lot of room for adjustment.
STUGOTS Midwest
Old 4th-March-2007, 11:29 PM   #13
1quik69
(OP)
1quik69's Avatar
Title: Moderator
Nova(s): 1972w/408,
Grafitti, your pump looks like the picture we ordered from except on the one I am supposed to be getting the return connection points straight down instead of to the outside like yours does. Thanks for the pics. they help alot.
Old 5th-March-2007, 06:37 AM   #14
monk
monk's Avatar
Quick, glad to help.
You can get the big block brackets at most vendors.
One note on the pump, when I first installed mine I thought it was defective as it steered real hard. Took a few minutes for pump to cycle out the air I guess.
Good Luck
STUGOTS Midwest
Old 5th-March-2007, 07:20 AM   #15
68_RATPOISN
68_RATPOISN's Avatar
Nova(s): '68 with a BB
I have a question to add to this. I am converting from a 6cyl to a BB also and would like to know how you all ran your PS lines with headers (not alot of room). Pics would be great....americangraffiti your pics are good for the pump side but were do they run to get to the box???
Brian
Brian
402 BBC, Edelbrock Torquer intake, Doug Herbert Cam (.553-.571 lift), Solid Lifters, 750 DP Holley, Harland Sharp Roller Rockers (DeskTop Dyno Says 430hp-420ft# T--Hopefully it is close)
Non Nova Power Steering Question 62civa Steering, Suspension, and Chassis 3 18th-June-2006 05:59 AM
Short water pump 68 Big Block low alternator mount ? SyncroMush 3rd Generation Chevy II/Nova's 2 13th-June-2006 05:40 PM
Power Steering Help STREETRODDER037 Drivetrain & Performance 2 14th-May-2006 01:21 PM
Power Steering Greg McMillan Steering, Suspension, and Chassis 2 20th-April-2006 08:37 AM
power steering fluid type? bkhotrod Steering, Suspension, and Chassis 3 9th-April-2006 09:05 PM
