Rear lift shackles - Chevy Nova Forum
Old 2nd-January-2007, 11:23 AM   #1
TNshadetree
(OP)
TNshadetree's Avatar
Nova(s): 76
Rear lift shackles
I just installed some rear springs on my 76 Nova Hatchback. The old stockers had been sagged out for a long time and I'd used some cheap shackles to keep it at a respectable ride height. I got the 5 leaf springs from Classic industries. But when I finshed and dropped the car down I was shocked to see the rear sitting way low. My bumper is only about 10 inces off the ground.
I'd replaced the front springs about a year ago and was looking forward to having new springs all around, but now my car sits like it's got a load of gravel in the back. Changing out rear springs isn't a lot of fun, so I'm hoping someone out there supplies some shackles that a couple of inches taller so I can just change them out and be happy.
The old shackles I mentioned before aren't worth using as they are just a thin bar about an inch wide and they aren't wide enough to stablize the side forces.
Anybody know of a source for some good lift shackles?
Old 2nd-January-2007, 11:35 AM   #2
Real McCoy
Real McCoy's Avatar
Title: Moderator
In my opinion long shackles do nothing but create other problems. Stability being the biggest issue and usually creating other problems. Can't say why your car sits low but shackles isn't the reason. I suggest you try and find out why it sags not how can I doctor up new stuff to make it work right. It should be right when installed. Just my thoughts. RM
God Bless America, land that I love
2010 PRTA 5.30 Index Champion
Old 2nd-January-2007, 11:57 AM   #3
ktownkid
Wow.....You're the first person that used the 5 leaf set up ...and ended up lower. About every post that I've read said they raised the car up more than stock height.
You could have your springs re-arched. I think a couple guys on this forum have done that.
ktownkid
ASPCA....and then some
Old 2nd-January-2007, 12:05 PM   #4
Jason628
Jason628's Avatar
Nova(s): '73 Nova Custom Hatchback
Greetings,
When you installed the springs did you make sure you didn't put any preload on them? Did you set it on the ground then tighten things up? I've had friends put on springs and start tightening things while on jackstands and come up with the spring setting lower than it should because of preload.
Jason
1973 Nova hatchback 350,TH350, 3500 stall converter, with the obnoxious 6 inch bolt on fiberglass hood.
Old 2nd-January-2007, 12:08 PM   #5
USMCNOVA
USMCNOVA's Avatar
Nova(s): 1963, 1971
I would suggest staying away from the longer shackles. I used a cheep set of the "adjustable" ones from Pep Boys on my 71 and they made the rear end real unstable. Also used a set on my current build (63) one side of the original shackles was bent and the car sat real low in the rear with mono leafs. I put the new rear end in with the original monoleafs and new shocks. The adjustable shackles even in the lowest position made it sit a little higher than I wanted, so I am going back to the stock shackles. Might want to look into that idea of having the springs re-arched to achieve the ride hieght you are looking for.
Old 2nd-January-2007, 01:37 PM   #6
Bscman
Bscman's Avatar
Nova(s): '72 2-door
If they're new springs and they aren't sitting at the proper height, why not complain to Classic?
Maybe they sent the wrong springs?
Old 2nd-January-2007, 03:44 PM   #7
Seattle_Mike
Seattle_Mike's Avatar
Title: Moderator
Agree with the rest...DON'T bandaid it, fix it right. I don't know what the ride height should be, but I'm sure others here with stock ride height cars should be able to give you a ballpark number. They manufacture de-arched springs since most guys want their car to sit low unless it's a resto or whatever...maybe these were made for a lowered application. Either way, I'd find out what the OEM spec ride height is, if that's what you are going for.
33 Ford 3 Window 468ci BBC
68 Camaro ProMod 848ci Buck Racing Engines Nitrous
Old 2nd-January-2007, 03:55 PM   #8
bowtie0069
bowtie0069's Avatar
Nova(s): 69
That's the opposite of what will happen if you tighten things up while jacked up. When mine would start to sag, I would jack it up, loosen the spring clamps on my multi-leafs, let everything hang, then re-tighten the clamps, and let it down. I could pick up nearly 2" in ride height until it settled down a few weeks later. I was using the clamps to stiffen the front half of the spring ala Mopar Super Stock springs.
As for the new Classic springs sitting too low-Call them and tell them you are mad as hell, don't try and fix someone else's screw-up! When I first put multi-leaf replacements on mine, it was about 4" too HIGH! I'd have to say they sent you the wrong parts.
69 Nova 410" small block-Driven to track
6.39 E.T./105 MPH--6.11/112.89 w/N2O
Rear Window Defog Idea tpinovaII Body and Interior 16 7th-October-2006 07:05 PM
rear sway bar with high lift springs jetblack73nova Steering, Suspension, and Chassis 2 8th-June-2006 07:33 PM
Rear end swap Soonerfan41 Drivetrain & Performance 3 25th-May-2006 06:46 PM
Rear end Questions... 68Nova2 Drivetrain & Performance 12 14th-April-2006 05:41 PM
Any rear shocks that provide lift? kidsjustine Steering, Suspension, and Chassis 3 29th-March-2006 05:48 PM
