71 Nova 10 bolt rear end 8.2 or 8.5? - Chevy Nova Forum
Old 26th-November-2006, 10:54 PM   #1
57 BelAir
(OP)
Title: Nova Newbie
I'm still trying to determine what rear end I have in my Nova. I've taken it down and found it has a 30 spline pinion and the square notches on the carrier as indicated in Nova Resources site for an 8.5 carrier. I'll try to insert a few pics I've taken. Also, the ring gear maesures 8.5 inches. I guess this is an 8.5 rear but, the ring and pinion indicates 71 as the year. I'm just not sure?
I guess I can't post images? Thanks Mac
Old 27th-November-2006, 12:25 AM   #2
Bscman
Bscman's Avatar
Nova(s): '72 2-door
All the 71's I've come across had 8.2's...but withouth knowing the full history of the car, it could easily be an 8.5" (it's not like they're rare).
Old 27th-November-2006, 12:32 AM   #3
74nova350ss
74nova350ss's Avatar
try this:
http://www.novaresource.org/axle.htm
it should help you out.
Eric
1975 Nova--1974 Nova Pro Street--1974 Nova Hatchback--1974 Nova SS--1973 Nova--1973 Nova Pro-Street. . . . . . . . I'm a Nova-Nut
Old 27th-November-2006, 09:44 AM   #4
photoman
photoman's Avatar
If it has 30 spline axles, it's not original. All of the 1971's (AFAIK) got the 28 spline 8.2" rear axle.
What is the date code on the passenger side tube?
1969 Nova
350
TH400
8.5" 10 Bolt
Old 27th-November-2006, 10:48 AM   #5
57 BelAir
(OP)
Title: Nova Newbie
1971 Nova rear end code
The passengers side axle tube has these letters and numbers: JD G340 2.
Tha axles are 28 spline, the pinion is 30 spline. The Nova Resource differential page shows a carrier housing with 2 pronounced square lugs or blocks on the bottom indicating it's an 8.5 rear, my carrier has these lugs. The open carrier has a GM6 and 495N opposite the ring gear mounting flange. There is also an L 2 1 on the carrier housing which if I'm right, mean the housing was manufactured December 2nd 1971. The numbers on the ring gear are: 2 GM 3984828 13 40 71 2 the pinion numbers are: 71 3984829 13 40 GM
Thanks for the help guy's
Mac
Old 27th-November-2006, 11:36 AM   #6
photoman
photoman's Avatar
The 13 and 40 indicates a 3.08 ring and pinion ratio. I think those 71 numbers on the gears are date codes. The "340" is the housing date code which is December 6. You may have one of the last 1971's made and GM used a new for 1972 "JB" 2.73 ratio 8.5" ten bolt rear axle with 3.08 gears. Who knows? Stranger things have happened at GM.
What engine/trans combo did the car have from GM?
1969 Nova
350
TH400
8.5" 10 Bolt
Old 27th-November-2006, 11:56 AM   #7
cadanova
http://i21.photobucket.com/albums/b2...10BOLTID-1.jpg
check this one out
Old 27th-November-2006, 01:05 PM   #8
GuySmiley
GuySmiley's Avatar
[QUOTE=57 BelAir;400380]The passengers side axle tube has these letters and numbers: JD G340 2.
That looks very simular to mine. Its a 71 with a JD G096 2 code and 90 degree tabs. Everyone says 71's usally did not come with 8.5 but I'm sure mine is (have not had it apart yet)
Later
Michael
71 Nova
Old 27th-November-2006, 01:05 PM   #9
JBimmolate
JBimmolate's Avatar
Title: Moderator
Nova(s): To be determined...
You have to copy the link off the actual page. It gets shortened on here when copied and pasted.
Miles
" The Resident Differential Guy, Have A Question? Just Ask! "
11/2016 FastEddie, he will be missed
71SS....Came with either bench or buckets ?? John'sCustoms Body and Interior 16 2nd-September-2015 05:20 PM
8.5 = 8.78 or how to turn a 10 bolt 8.5 in to a 12 bolt! well almost. veno Drivetrain & Performance 15 24th-March-2010 03:16 PM
74 Nova with 73 442 Olds rear end 2novacars Drivetrain & Performance 6 12th-March-2008 12:34 PM
rear window clips 62/65 Nova Acdaian Acadian_Nova 1st & 2nd Generation Chevy II/Nova's 2 1st-April-2006 11:39 AM
1970 nova 12 bolt housing measurement papa70nova Steering, Suspension, and Chassis 0 30th-March-2006 07:58 PM
