Update on the budget Street Fighter - Chevy Nova Forum
Go Back   Chevy Nova Forum > Non-Technical > 1st & 2nd Generation Chevy II/Nova's
Old 29th-October-2006, 10:28 AM   #1
slow4dr
slow4dr's Avatar
I haven't really officially introduced myself here yet. My name is Jason and I have a 1st gen II(that feels like the introduction to an addiction meeting). I originally planned on building a drag car but have since decided I want to go road racing.
I spent some time yesterday setting up the rear suspension. Nothing is welded in yet and I need to fab some brackets for the lower links to connect at the cross member. I am mainly waiting on my bushings to do this.
Here are the brackets for the axle housing. All I needed was the lower portion so I cut the tops off. I am going 3-link with a watts link.
Here is the CE front ladder bar style cross member.
Here is what the frame looked like before. (notice the new CE rear frame rails already in place). I moved these rails inboard of the stock rails to gain wheel clearance. I am hoping to run 12" wide wheels with a 335 tire.
Here the crossmember and CE subframe connectors are in place. I had to cut the floor slightly to fit the subframe connectors in this position. I switched the connectors from side to side so they would go inboard of the frame rails instead of to the bucket.
Here you can see where I had to drill a hole in the subframe connector to slide the cross member into. Also notice the brackets just hanging there. These will be changed in time I just needed something to hook the links to for moch up.
Last but not least the rearend in place and the lower links jurry rigged to the front brackets.
-Jason
Old 29th-October-2006, 10:34 AM   #2
slow4dr
slow4dr's Avatar
Just for giggles I mounted my dads drag wheels up front to see if they would clear the Corvette brakes. It looks like I might need to keep an extra set of wheels around for drag days.
-Jason
Last edited by DANNO; 29th-October-2006 at 01:22 PM. Reason: bypassing profanity filter
Old 29th-October-2006, 11:08 AM   #3
novaBRO
novaBRO's Avatar
Nova(s): LS 64 wagon & LS 67 coupe
did you make that front clip? if so nice work dude.
RIGHT ON BRO!
MY RIDE
photo album
THE LONGROOF SOCIETY
NorCal Novas Proverbs 13:3
Old 29th-October-2006, 11:21 AM   #4
62SportCoupe
62SportCoupe's Avatar
Jason
Looks like things are coming together quite nicely! Keep us updated on your progress.
It's not a Chevy II... It's a Nova
Old 29th-October-2006, 11:58 AM   #5
slow4dr
slow4dr's Avatar
Yes, the cross member & suspension is from an 85 Vette and I just used 2X3 boxed frame to connect it. Here are some pics from a few months back. I will need to run a very big backspace wheel(similar to the new C6 vette rears) to clear the fenders.
-Jason
Old 29th-October-2006, 01:18 PM   #6
DANNO
DANNO's Avatar
Nova(s): 72 Sedan and 63 Wagon
Looking good! Welcome to the site!
My pics: DANS72
Old 29th-October-2006, 06:32 PM   #7
novaBRO
novaBRO's Avatar
looks good dude!
RIGHT ON BRO!
MY RIDE
photo album
Old 30th-October-2006, 10:55 PM   #8
Lil'Deuce II
Lil'Deuce II's Avatar
Nova(s): 63 SS
nice job! Did youhave to narrow the Vette crossmember?
Old 30th-October-2006, 11:35 PM   #9
slow4dr
slow4dr's Avatar
Thanks for all the kind words.
No, I didn't narrow it. It is 59" wide and will require a very deep back space wheel to make it work. I am planning on running these wheels in either a 19X10(79+mm offset) or a 18X9.5(65mm offset).
-Jason
Old 30th-October-2006, 11:44 PM   #10
novanutcase
novanutcase's Avatar
Title: Moderator
Nice Wheels!
Build Pics(No Comments)
http://www.stevesnovasite.com/forums...ad.php?t=78088
Old 31st-October-2006, 10:48 AM   #11
MY67
MY67's Avatar
Thumbs up
That looks very sharp!!!!
Old 31st-October-2006, 06:34 PM   #12
Lil'Deuce II
Nova(s): 63 SS
Keeps the pics coming! How will the rad support fit? Also, what about the wheels scrubbing the fender. I like what your doing and I'm really curious to see how it comes along.
Old 31st-October-2006, 06:48 PM   #13
slow4dr
slow4dr's Avatar
The car isn't superlow so they actually clear fairly well. The 16" saw blade vette wheels you see in the pics above were an 1" to wide. The skinnies in the later pics gained about 2" per side but the ZO6 wheel will gain even more room. Worst case scenario is I will have to make a bit of a wide body set-up. I am going to a 1 piece front end so I don't mind "massaging" it if needed.
-Jason
Old 31st-October-2006, 07:06 PM   #14
gg64ss
gg64ss's Avatar
Nova(s): Sold my 64' and I miss it
I would say it is nice for all of us to have you aboard. I wish I could do that kind of work. Everything looks really good. I don't know that I have seen a road racing 1st gen duece.
Sheldon <><
02' Camaro SS still in the works. 381ci 18*SBC BW S500X 88mm turbo
Old 31st-October-2006, 10:52 PM   #15
NIGHTSHADE
NIGHTSHADE's Avatar
Title: Moderator
Nova(s): NONE! It's a Chevy
Don't get me wrong, but this picture has been buggin me. Maybe it is just the pic, but it looks "twisted" and not in a good sense of the word.
Follow the lines of the roof, lower control arm mounts, lower points of the crossmember and the sub frame ends. It just looks "off", but like I said, it could be just the picture. Or maybe just how the rearend is blocked up???
Will it be safe to drive, especially in a road race?
