traction bar install - Chevy Nova Forum
Old 27th-October-2006, 11:42 PM   #1
YIK YAKS 67 SS
YIK YAKS 67 SS's Avatar
Nova(s): 1967 SS 327 4 speed
Installed a set of lakewood traction bars on my 67 today. The drivers side fit fine with room for adjustment of the snubber with the square u bolt. On the pass. side the snubber is tight againt the mono leaf spring, no room for adjustment. Both snubbers are in the front hole. These are the bars that replace the bottom spring pad which the shocks bolt to. Any ideas as to why or how to correct. Thanks in advance.
Old 28th-October-2006, 01:29 PM   #2
Custom Jim
Custom Jim's Avatar
Nova(s): 1968,1973,1974,1977
I have a set on my 73 that replace the lower shock/leaf plate and on mine they have the U bolts to go around the axle tubes. By loosening the rear nuts and tightening the fronts I can slightly raise the snubber position. If I do the opposite (loosen the front nuts and tighten the rear nuts) I can slightly lower the snubber.
If something like this doesn't work then moroso used to sell aluminum angle wedges and were made out of aluminum. These are used to adjust the angle that the traction bars sat and would go on the rear axle assembly/leaf spring mounts. I think they were about 3 degree wedge ?.
68 Chevy II, 73 Custom, 74 Spirit of America, 77 Hatchback https://www.youtube.com/user/stlnovas
Old 31st-October-2006, 01:21 AM   #3
Bscman
Bscman's Avatar
Nova(s): '72 2-door
The "square u-bolt" you reference is a safety hoop. It's not really designed to adjust the gap between the bumper and the spring eye.
I wouldn't recommend using it to get the bumper closer to the spring unless it's only a very slight amount (less than 1/4"). Doing so could put an irregular pre-load on the spring and prematurely wear it out, or damage it (or so I'm told).
Lakewood and Moroso both make these shims. They can be purchased in 1* "stackable" shims, or 2, 3, and 4* shims. The can be used to either bring the bumper closer to the spring, or give you more distance.
I had to use a 4* shim for each side with my multi-leafs to get them with 1/4" of the spring eye. I like mine as tight as possible.
Another method would be to trim the bumpers...just don't get too carried away.
Old 31st-October-2006, 02:48 AM   #4
Colin
Colin's Avatar
I always had better luck with slapper bars when the snubber is adjusted to the point where is slightly pressed against the spring eye. Most cars that I see that have slappers have the snubber hanging down like 2+ inches.....that never did anything for me performance wise.
Old 31st-October-2006, 12:47 PM   #5
Bscman
Bscman's Avatar
Nova(s): '72 2-door
+1
My first install w/o the 4* shims had the bumper about 2.5" below the spring eye. I took it for a spin around the block and couldn't really tell they were even there. Thought I would imagine it would make a larger difference with a mono-leaf over my multi's.
Leaf spring install...shackle first or eye bolt first? NovaNate Steering, Suspension, and Chassis 9 19th-August-2008 02:07 AM
Caltrac install help needed...replacement part problem NovatoriusRex Drag Racing Forum 64 24th-June-2006 12:26 PM
Lowering Blocks and Traction Devices Scooter Steering, Suspension, and Chassis 16 27th-April-2006 12:01 PM
any-1 install a tranny from bowtie overdrives? novaBRO Drivetrain & Performance 14 25th-April-2006 01:31 AM
