performance 262, 267, 283, 302, 305, 307: Combined threads - Page 5 - Chevy Nova Forum
Go Back   Chevy Nova Forum > Body, Chassis and Mechanical > Drivetrain & Performance > Best of Drivetrain & Performance
Old 26th-March-2006, 11:10 PM   #61
fixing-gpas ride
Title: Nova Newbie
boy i feel stupid my fingers got a lil carried away while typin. after rereadin his info its supposed to be 1.115 to 1.117 max per cube. sry for the confusion. i jus gotta slow down while typing.
after readin the posts i thought that seemed a lil overborard myself so i rechecked the info. sry guys have one on me
grandpa never had it over 45
what will he think when it does 145
Old 13th-September-2006, 07:31 PM   #62
Kens 67
Kens 67's Avatar
Title: Nova Newbie
Nova(s): 67
performance 262, 267, 283, 305, 307: Combined threads
I have a original 283 with 57,000 miles on it. This is a 195 horse 9.5 compression motor with a 2 barrel carb. I have been thinking about putting on my set of 462 casting 194 heads and a 67 four barrel intake on it until I can properly rebuild a 327. Will this make the performance worse or should I put the original heads back on until I can afford to finish the other motor? Any opinions would be appreciated.
67 Coupe bench seat 4 speed
Old 13th-September-2006, 08:10 PM   #63
Dan_Lebherz
Dan_Lebherz's Avatar
Nova(s): 1964 Chevy II Wagon
At best you will be going from 58cc combustion chambers to 64 cc, and maybe much larger chambers. This will reduce you compression ratio and turn the 283 into a real pig. Been there, Done that. Those powerpak heads are really not that bad for a 283, if they are in good shape. The factory had a couple of combinations using old technology that produced one HP per ci. I'd go with an aluminum intake with a 600 cfm carb, small tube headers, something like a Comp XE 262 cam. maybe even smaller on the cam. It should run very nicely. If you really want to change the heads there are some Edelbrocks made for the 305 that should work.
64 Wagon
383, TH200-4R, 3.73s
11.683 @ 114.70 MPH 1.580 60'
Old 13th-September-2006, 08:39 PM   #64
66marinabluess
66marinabluess's Avatar
Nova(s): '66 Nova SS '65 Nova SS
I've used 305 heads with the 1.94 / 1.5 valves with the 58cc combustion chamber on the 283 engine & they work great. There is also a 1.82/1.5 valve 58 cc head that works good as well. Early-mid 80's 305 with the 4 bbl carb engines used these heads.
Gone,but not forgotten........
1962 Nova 400 Convertible
1967 Nova SS 327
1970 Nova SS 396
Old 13th-September-2006, 10:20 PM   #65
64PRONOVA
64PRONOVA's Avatar
Nova(s): 64SS & 65SS
Your 283 will be a "pooch" with 64 cc heads. If your 283 has the 896 casting heads on it, keep 'em. They flow better than the 305 heads and have more potential. A lot of 305 guys have embraced the old 896 Power Pack heads. I would remove the heads and do some inexpensive rework to them and bolt-on a nice dual-plane 4-bbl intake. Dan has the right idea with the cam. You'll notice a difference.
Old 13th-September-2006, 10:44 PM   #66
Paul Wright
Paul Wright's Avatar
Camquest had the XE262 as 12th choice;
279.7Hp @ 5,000
328.8 lb/ft @ 3,500
In the Extreme Energy line it preferred the XE256H for your 9.5 283 with stock heads and a dual plane intake with a 600 carb..
273 Hp @ 5,000
331 lb/ft @ 3,000
Originally Posted by Paul Wright
Building a small, high rpm engine
with the perfect bore, stroke and rod ratio is very impressive...
like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar.
Cubic inches is like Indiana Jones with a cheap pistol.
Old 14th-September-2006, 12:43 AM   #67
stock z/28
Hi,
Interesting thread. I agree the 283 needs a pretty small chamber head.
Just out of curiosity, what is better about the 896 head, than the 305?
Why are they using those on 305s? I use a lot of the 305 heads, but I have a lot of the 896s and 520s still around. I was always under the impression that the 520s flowed better than the 896s.
Just curious
Jeff
Old 14th-September-2006, 01:04 AM   #68
the FLYER
the FLYER's Avatar
Nova(s): a B Pillar of Society
it's been years and years, my number's prolly off a bit... i had a 283 i slapped on a set of 997 (?) heads (57 Vett w/FI or 2x4's) and it screamed... had an old TRW perf parts cam in it
the Flyer Special
'64 411 377-Tko600-3:73's
Old 14th-September-2006, 01:24 AM   #69
loneagle
loneagle's Avatar
A fellow I know has the 64cc Edelbrock RPM heads on a 283. I've always heard you couldn't run these due to the small bore size. The engine was built by a top engine builder in my area.
'70 Nova 355 cid
Super T-10 4 speed
Old 14th-September-2006, 09:42 AM   #70
stock z/28
Hi,
I don't think its so much a matter of valve size as it is compression ratio. The 64cc heads would probably be kinda marginal if it still has a flat top piston.
Sometimes volume of the heads can become a bit of an issue. I have cced a lot of the 283 heads and don't ever remember finding one that was actually the listed "spec". It usually takes about a .060" angle mill to get them in spec..
Years ago I used to build quite a few .060" over 283s with large valve (2.02-1.60), but these had large dome pistons.
I think the original 1.94 valve first appeared in a 283 in 61. I don't remember for sure but I think a few were built with aluminum heads, but later were recalled and replaced with iron heads.
On the nova 283 stick cars (65-67) I have put 327 cranks and 307 flat top pistons with a double hump head (usually a 1.94). This is about 317 inches and makes a pretty nice street engine.
On the Edelbrocks, I guess you would have know all the details and even then, if the customer is happy I guess all is well.
Sorry to ramble
Jeff
Old 14th-September-2006, 10:22 AM   #71
novaboy009
novaboy009's Avatar
A 283 block with a 327 crank is a 307
Scrappy little motor, that one is.
Kev
78 Nova - autocross/drag/street car with nitrous
Old 14th-September-2006, 12:56 PM   #72
stock z/28
Hi,
Your are right Kev.. I forgot to add that I usually take these .060" over.
I have taken a few .125" over with out any problems (knock on wood). As a matter of fact the motor in my 67 now is a ChevII 283 block bored to 4.000" with a set of std bore L79 style pistons. I really beat this bad back in the early eighties.
Good Luck
Jeff
Old 14th-September-2006, 02:50 PM   #73
stupesnova
stupesnova's Avatar
Title: Moderator
Nova(s): 67 SS 66 HT 62 CDAN
I'v got a 283 in my 66 that has the 305 heads, punched 40 over with a single plane intake and a 350 horse 327 cam in it, and it suprised the hell out of my buddies 350 chevelle.
Old 14th-September-2006, 08:18 PM   #74
Kens 67
Kens 67's Avatar
Title: Nova Newbie
Nova(s): 67
Thanks for the input everyone. I feel a lot more confident about making my next few decisions. I'II be going with the stock heads a mild cam, and 4 barrel intake and carb. I had taken off the timing cover today to see if it had the original nylon timing gears. Well it did but all three bolts on the cam gear were so loose I could take them off with my fingers. Now is that not good timing or what.
Old 14th-September-2006, 09:18 PM   #75
babydeuce
babydeuce's Avatar
I have a 283 30 over with vortec 64CC heads, and the XE256 cam. It runs great on the top end, but is a dog down low, even with a stall converter. If you want to run the XE256, you want the 58CC heads. Mine idles like crap, and does not kick in until about 3k, after that it moves rather well. I am actually going to step down to a XE252.
Jack
Its not a NOVA, its a Chevy II....63 SS 5.3/4L60E powered!
Combined threads on Rotisserie Construction fixing-gpas ride Best of Body and Interior 47 26th-March-2014 10:26 AM
I need a tuning guru (combined threads) chevynuts88 Drivetrain & Performance 64 17th-May-2006 10:04 AM
AN vs. NPT: Understanding port threads, adapter fittings and line sizes. DriveWFO Best of Drivetrain & Performance 0 23rd-March-2006 10:07 PM
Part durabilty and rpm limits Q's (Combined threads) Paul Wright Best of Drivetrain & Performance 45 16th-November-2005 08:44 PM
