Setting timing with a Vacuum gauge..by Ear? Bad Idea. - Chevy Nova Forum
Go Back   Chevy Nova Forum > Body, Chassis and Mechanical > Drivetrain & Performance > Best of Drivetrain & Performance
Closed Thread
Old 5th-September-2006, 10:32 PM   #1
Jason628
(OP)
Jason628's Avatar
Nova(s): '73 Nova Custom Hatchback
Greetings,
I learned a new tuning technique over the weekend...Get a vacuum tester and put it inline with manifold vacuum. Advance the distributor until you get the maximum amount of vacuum reading on the gauge. Then turn the distributor back exactly 1 degree on the vacuum gauge. Tighten everything down and adjust your idle if necessary. For grins I did it on mine, and I must admit it does run a little bit better than doing the traditional advanced timing!
You learn something new every day,
Jason
1973 Nova hatchback 350,TH350, 3500 stall converter, with the obnoxious 6 inch bolt on fiberglass hood.
Old 5th-September-2006, 10:37 PM   #2
DANNO
DANNO's Avatar
Nova(s): 72 Sedan
My vacuum gauge doesn't read in degrees.
My pics:
Old 5th-September-2006, 10:39 PM   #3
Jason628
(OP)
Jason628's Avatar
Greetings,
One mark in Hg...LMAO
Jason
Old 5th-September-2006, 10:48 PM   #4
Paul Wright
Paul Wright's Avatar
This one floats around the internet but it's not a good trick.
Use a vacuum gauge to adjust idle mixture and use a timing light to adjust timing.
Originally Posted by Paul Wright
Building a small, high rpm engine
with the perfect bore, stroke and rod ratio is very impressive...
like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar.
Cubic inches is like Indiana Jones with a cheap pistol.
Old 5th-September-2006, 10:51 PM   #5
DriveWFO
DriveWFO's Avatar
Nova(s): 74 Nova...R.I.P
Sure, but can you adjust your idle mixture with a timing light???
Don't worship false idles
Old 5th-September-2006, 10:53 PM   #6
Tom Griffin
Tom Griffin's Avatar
Title: Moderator
Now that was funny
Tg
Old 6th-September-2006, 01:10 AM   #7
IgnitionMan
Title: Guest
Posts: n/a
This "method" just plain doesn't work, didn't work in the first years of the gasoline engine, and it doesn't work on today's engines, or anywhere in between.
Set paramters are the ONLY way to do timing correctly, and not with a vacuum guage.
Man, I am tired to the max hearing this one, over and over again.
Old 6th-September-2006, 01:16 AM   #8
Paul Wright
So am I. Unfortunately the Internet easily perpetuates urban myths like these.
At least in this small corner of the virtual world we try to keep the information accurate.
Jason, where did you hear or read this? Another web site? If so, please let them know it's false.
Old 6th-September-2006, 09:44 AM   #9
Jason628
(OP)
Jason628's Avatar
Greetings,
No, not another website...a 60 year old friend of the family told me this who's being doing Corvette restorations for about 30 years. So tell me this: What damage am I doing by having my engine set up this way?
Jason
Old 6th-September-2006, 10:40 AM   #10
Paul Wright
Jason, this is just another variation on the "turn the distributor until it pings and then back it off". Don't these people own a timing light?
The trick is:
First set your base timing with a timing light, then tune the idle mixture with a vacuum gauge to get the highest reading at the lowest steady idle.
Somehow your friend got the timing light part mixed up with the idle mixture. If you advance the base timing "by ear" or with a vacuum gauge you'll over advance the total timing. This is not good for an engine. The pressure before TDC is like hitting the rising pistons with a hammer.
I know a lot of old timers that do it by ear. I've posted this before but a friend of mine who did it that way wound up with trashed main bearings from the detonation.
Old 6th-September-2006, 10:52 AM   #11
novaboy009
novaboy009's Avatar
Even if it doesn't detonate, most SBCs don't like 43 or 44 degrees of total timing, which is quite possible if you tuned it by the vacuum gauge. I'd stick a light on it and find out what it's actually doing. Tune for 38 degrees total at first and then get the idle to work from there.
Kev
78 Nova - autocross/drag/street car with nitrous
Old 6th-September-2006, 11:21 AM   #12
Paul Wright
Most engines idle smoother with advanced base timing, but at some point they make less power when the total advance is too much.
Most people assume that as long as they can't hear "pinging" then it's ok to keep adding advance but that's not always true. Over advanced timing can cause excessive combustion pressure before TDC (which the piston has to fight) which isn't always audible. A modern knock sensor can detect inaudible detonation that the human ear can't.
The piston is still rising when the spark plug fires and the air fuel mixture begins to burn. Combustion pressure is building at the same time it's being compressed by the piston. This BTDC pressure is negative crankshaft energy until the piston goes past TDC and it becomes positive.
Use the least amount of total advance that gets best power and no more.
A SBC engine that makes best power with 34 degrees of total advance is more efficient than one that requires 40.
Old 6th-September-2006, 12:48 PM   #13
Purple72
Purple72's Avatar
So is there anything inherently wrong with running 40 degrees total timing? Seems like there are a lot of guys doing just that around here. I had my total dialed to 34 degrees and was about to try bumping it up some. Should I not be doing that? Or are we just discussion theory here?
I suppose ideally I should put the car on a dyno and get the facts on the changes rather than guessing or using the seat of the pants method. That of course is a hassle for some of us, I have an hour and half drive to the nearest shop with a dyno.
Since the posted tuning suggestion turned out to be bunk, do you guys have any other tips or tricks to share regarding getting timing and idle mixtures set as close to optimum without dyno time?
1972 Nova, 383, 10.5:1, cam 304* .525, Sportsman II heads, rpm air gap intake, full msd, 870 Street Avenger, TH350, 10 bolt 4.10 posi, 11" 2500 stall
1971 GS455, 464, 525hp, switchpitch TH400, 12 bolt 3.42 posi, AC
Old 6th-September-2006, 01:08 PM   #14
Paul Wright
Every engine is different so don't assume that what one guy runs is what you should run.
Most, but not allhot rod small block Chevy's run best with 36-38 degrees of total timing unless they have fast burn or Vortec style heads. They like around 32-34 degrees.
the only way I know of to determine what timing is best for a particular combination is to test.
In lieu of dyno testing there's always the drag strip dyno. Try averaging the MPH for 3 runs each for 2 degree timing increments 36, 38 & 40.
Then maybe try 37 and 39 on the way back down.
You could even graph the results in Excel to show how the MPH curve goes up and then back down. Your best total timing is at the peak of the curve.
You could even experiment with octane vs timing the same way.
Here's a sample to show what a timing test might look like. Advancing the timing helps up to a point.
See how over advancing the timing causes the MPH (power) to drop off then plummet?
Every engine is different, but if your buddies didn't test, then they may just be "guy thinking" that if 38 is good then 40 must be better. Think for yourself and test.
Old 6th-September-2006, 01:16 PM   #15
DriveWFO
DriveWFO's Avatar
Also make sure to use the same fuel. Changing fuels/octane will have an effect on how much timing your motor wants. In other words, don't introduce two variables at once.
Dave:
I was building a graph when you posted that clarification but you are correct.
There will be different results when you change variables such as octane.
This is why I keep a log book when testing and tuning. Change one thing at a time. ~Paul
Closed Thread
More on timing......any comments Mikel72 Drivetrain & Performance 1 21st-December-2007 08:01 AM
750 dp tuning 71nova Drivetrain & Performance 9 30th-January-2007 12:04 AM
Holley idle mixture question Dnova Drivetrain & Performance 16 7th-January-2007 11:06 PM
Lumpy under light throttle Purple72 Drivetrain & Performance 20 7th-September-2006 10:02 PM
