3.73 rear end vs. 3.42 rear end? - Chevy Nova Forum
Old 30th-August-2006, 09:56 PM   #1
Jason628
(OP)
Jason628's Avatar
Nova(s): '73 Nova Custom Hatchback
Greetings,
I've got a 3.42 ring and pinion in my Nova now and debating on putting in a 3.73 ring and pinion. I want to feel a bit more torque off of the line and I would think this would help, plus I think it'll match my cam (292H Comp Cams) and converter better (TCI Break-A-Way). Other than a drop in gas mileage and the need for another speedometer gear, what other negatives are there to this swap?
Jason
1973 Nova hatchback 350,TH350, 3500 stall converter, with the obnoxious 6 inch bolt on fiberglass hood.
Old 30th-August-2006, 10:27 PM   #2
Steves 70SS
Steves 70SS's Avatar
Nova(s): 1970 SS Crate ZZ430 Munci
gears
Jason, I have 373's in mine with a super t-10. I'm not sure what the gear ratio in the tranny is but I was thinking of going down some in the rear end. When I drive down the highway in the slow lane it seems like everybody else is going 100 miles an hour by me and I'm tacking 3000 rpm. What type of driving will the car see???
Steve W
Old 30th-August-2006, 10:54 PM   #3
Jason628
(OP)
Jason628's Avatar
Greetings,
I drive it all over the place...highway and around town. I do get on it sometimes, barking the tires when it shifts and such, but not often. I know the 3.42 is a lot more practical (I won't be racing or anything like that) but for some reason I just think the car will perform better with the 3.73. Right now 3000rpm is about 70mph with my setup in third gear.
Jason
Old 30th-August-2006, 11:04 PM   #4
Pick
Pick's Avatar
Nova(s): In between Novas
Man that 292 needs more converter! That would wake it up off the line more than anything. But, I know a higher stall converter can be a pain on the street. I've got a Breakaway we used with a stock 350, and when I switched to the 383 with an XS274 CompCam, it was a dog off the line. A new convertor fixed that though. Even a 3000 would wake it up a good bit. A 3500 would be even better. The good news is you wouldn't be turning any more rpm at highway speeds than you are now if you changed converters instead of gear. The bad news is, you'd probably see your around town mileage suffer.
Go fast and the wrinkles won't show.....
Old 30th-August-2006, 11:08 PM   #5
bowtie0069
bowtie0069's Avatar
Nova(s): 69
I doubt you'll see enough difference to warrant the expense--you could probably put a nitrous system on the car for the same money and see a HUGE difference compared to the gear swap.
69 Nova 410" small block-Driven to track
6.39 E.T./105 MPH--6.11/112.89 w/N2O
Old 30th-August-2006, 11:15 PM   #6
tpinovaII
tpinovaII's Avatar
Nova(s): '70 2dr sedan
Garage
On a street driven third gen with a 1:1 high gear and 26" tall tire, the 3.42 gear is pretty close to the ideal gear for all around performance. If you want it to come off the line quicker (and still keep up with interstate traffic), I would second that vote for a looser converter.
"My car ain't no hot rod. It ain't even got a 4 barrel on it."
"Anyone who has never made a mistake has never tried anything new." Einstein
"I have not failed. I've just found 10,000 ways that won't work." Edison
"The secret to creativity is knowing how to hide your sources." Einstein
Old 31st-August-2006, 09:13 AM   #7
novaboy009
novaboy009's Avatar
+1 for converter over gears.
Kev
78 Nova - autocross/drag/street car with nitrous
Old 31st-August-2006, 08:53 PM   #8
72resto
Nova(s): 68 ss clone 71 ss 72 ss
I put a 3.73 in my Nova and regretted it--not fun on a 55 mph road--I was at 3000 and still saw everybody passing by. Thats why I am putting a 200r4 tranny and my 3.08 in when i put a big block in. Just my 2 cents worth--: ) --Eric
Old 31st-August-2006, 09:21 PM   #9
Professor Fate
Professor Fate's Avatar
Title: Moderator
Nova(s): Between Novas now
Why are you putting in a 3.08 and a 200R4? Your final drive ratio in OD will be around 2.09. I'd leave the 3.73's and put in the OD tranny.
Jason: I don't think you will notice enough difference either.
Old 31st-August-2006, 09:44 PM   #10
JBimmolate
JBimmolate's Avatar
Title: Moderator
Nova(s): To be determined...
3.42 to 3.73 gears should bump up your RPM's about 300 or so. To get a noticable difference you usually have to go 2 steps but that would be overkill on your application I would think. If you want to see what it would be like just borrow some wheels that are an inch shorter for the rear and sport it around it ='s out to the same difference. 1" of tire is about 1 ratio change.
Miles
" The Resident Differential Guy, Have A Question? Just Ask! "
11/2016 FastEddie, he will be missed
Old 31st-August-2006, 09:59 PM   #11
Jason628
(OP)
Jason628's Avatar
Greetings,
I ordered a Super Street Fighter TCI converter tonight...Should get it Tuesday. It looks like that'll be the best route and give me about 3400 stall. Hopefully I'll put it in next weekend!
Jason
Old 1st-September-2006, 04:25 PM   #12
Dan_Lebherz
Dan_Lebherz's Avatar
Nova(s): 1964 Chevy II Wagon
72 resto,
change the trans b/4 you change the gears. A 2004R with 3.08s may not have a high enough cruise rpm to allow you to get into OD at less than 60 MPH. I have 3.73s with the 2004R and it works pretty well becasuse my cam makes power from 1,500 RPM to 6,200 RPM. Even still, It slugs in OD at less than 1,500. 2,000RPM is right around 65MPH in OD. Even with a big block, if you have a lumpy cam, it may not like OD at less then 60 MPH with those 3.08s.
64 Wagon
383, TH200-4R, 3.73s
11.683 @ 114.70 MPH 1.580 60'
Old 1st-September-2006, 05:27 PM   #13
Pick
Pick's Avatar
Originally Posted by Jason628 View Post
Greetings,
Jason
I hope you have some good, fresh sticky tires on that thing - and vinyl seats or something that clean up easy......
Old 1st-September-2006, 11:23 PM   #14
Mike Feudo
Nova(s): 67 wagon and SS
The effect doesn't warrant the effort and expense. You really won't notice that big a change.
Old 2nd-September-2006, 12:56 AM   #15
64PRONOVA
64PRONOVA's Avatar
Nova(s): 64SS & 65SS
3.42:1 is a better ratio for your application. If you really want more bottom end you could also dump the cam and go to a shorter duration. What's your compression ratio? I probably wouldn't run a cam like yours with less than 10:1.
If you bought the 10" TCI Super Streetfighter I hope you have a trans cooler too because it will be short-lived on the street without one.
Rear Window Defog Idea tpinovaII Body and Interior 16 7th-October-2006 07:05 PM
Rear end swap Soonerfan41 Drivetrain & Performance 3 25th-May-2006 06:46 PM
front to rear brake line chevyii Steering, Suspension, and Chassis 4 18th-May-2006 12:11 PM
Set up new rear end 1963DUCE100 Steering, Suspension, and Chassis 0 8th-May-2006 11:58 AM
Rear end Questions... 68Nova2 Drivetrain & Performance 12 14th-April-2006 05:41 PM
