700R-4 kickdown cable adjustment - Chevy Nova Forum
Old 25th-August-2006, 02:35 PM   #1
deuceman
deuceman's Avatar
Nova(s): 62 400HT 383 alum. headed stroker. 475
It seems I'm not adjusting the thing correctly as it won't shift right! It goes into high gear as soon as I take off unless I manually shift it I think I followed the instructions but must have done something wrong. can anyone give me a clue as to how to adjust? Thanks, Deuce!
Old 25th-August-2006, 02:39 PM   #2
72Ventura
72Ventura's Avatar
The TV cable adjustment is the single most important part of installing a 700R4. I would suggest that you not drive this car until you have it adjusted. A quick web search on '700R4 TV Adjustment' should yield plenty of walk-throughs.
RC
P.O.S. '72 Ventura
-=Progress Blog=-
Old 25th-August-2006, 02:41 PM   #3
63AKDN
Nova(s): 63 Acadian Beaumont
What setup are you using? I have a Lokar cable, and I just set mine up so WOT is full pull on the cable. Take 72Ventura's advice, as an improperly adjusted TV cable can fry up the tranny in as little as a couple hundred kilometres.....and I personally know someone who did it.
1963 Acadian Beaumont
355/700R4/Auburn Pro Series posi and 3.73's
How to hook up kick-down cable th350? NovaNate Drivetrain & Performance 27 25th-July-2006 06:32 PM
TH350 Kickdown too tight....could I have damaged my tranny? NovaNate Drivetrain & Performance 2 10th-June-2006 10:44 AM
TH350 Speedometer Cable Leak DriveWFO Drivetrain & Performance 10 14th-May-2006 02:34 PM
transmission leak - kickdown cable bandit610 Drivetrain & Performance 1 13th-May-2006 06:54 PM
after detent cable adjustment theracer Drivetrain & Performance 3 4th-April-2006 10:20 AM
