How to plumb the vent for a fuel cell ????? - Chevy Nova Forum
Go Back   Chevy Nova Forum > General > Drag Racing Forum
Old 22nd-August-2006, 04:32 PM   #1
Grayman68
(OP)
Grayman68's Avatar
I recently intalled a brand new fuel system on my 68 and have one question. How should I make the vent for my nova? Right now, I do not have one, and just have it open. You can imagine how bad my car smells like raw gasoline. I bought a roll over valve, but am not sure if I should run it or run a hose instead. I just want my car to stop smelling the garage up. If anyone has pics, that would be a big help.
Andy
Old 22nd-August-2006, 04:41 PM   #2
DriveWFO
DriveWFO's Avatar
Nova(s): 74 Nova...R.I.P
For a vent, you want to attach fuel hose to it and loop it around once or twice, then have the fuel hose exit the trunk floor. The reason for looping it is to catch any gas that may come up and into the vent line, and keep it from spilling on to the track.
Don't worship false idles
Old 22nd-August-2006, 06:58 PM   #3
Deuceisloose
Deuceisloose's Avatar
Nova(s): Was faster than yours
Exactly as stated above. The loop is NHRA required and I believe the rollover valve is too. Put a filter on the end of your vent line as dirt WILL find its way into your fuel if you don't. I flared mine, installed a fitting and a little K&N filter on top of that.
I know most of you have seen this pic but it really helps illustrate "the loop." Not to mention it shows my love for my favorite tool in the garage, my tubing bender(s).
Best 1/4 mile time (dead hook) = 36.32 @ 21mph!!!
Old 22nd-August-2006, 09:20 PM   #4
68chevyll
68chevyll's Avatar
Andy
You will still smell gas even after you vent it.
Old 22nd-August-2006, 09:24 PM   #5
DriveWFO
DriveWFO's Avatar
Yeah, but it's not too bad.
Old 23rd-August-2006, 11:33 AM   #6
Grayman68
(OP)
Grayman68's Avatar
What kind of K&N filter are you talking about? That tubing job looks awesome. Thanks for the advise!
Should I use a gromet where the tube goes through the trunk floor?
Old 23rd-August-2006, 11:35 AM   #7
DriveWFO
DriveWFO's Avatar
Yes, use a grommet.
Old 23rd-August-2006, 11:57 AM   #8
Sh1fter
Sh1fter's Avatar
Nova(s): 478" '63
Or Jerry Bickel Racing sells a bulkhead fitting with a K&N filter attached to the underside for the vent. It is called a fuel cell vent kit Part #: JBRC5022 - bottom of page https://secure1.securehosting.us/jer...l%20Components
Old 23rd-August-2006, 02:07 PM   #9
Grayman68
(OP)
Grayman68's Avatar
Dude, that is perfect! Thanks for the help guys!
Old 23rd-August-2006, 02:21 PM   #10
Denis the Menace
Denis the Menace's Avatar
Nova(s): is Broken
It's 29.00 for the kit P/N JBRC5022...19.00 for the replacement filter. I think I'll get one...
Thanks for the info.
Just another 69 Nova...
Denis
Old 23rd-August-2006, 09:43 PM   #11
Deuceisloose
That's the one I used. FWIW that part is a AN -8.
Old 23rd-August-2006, 10:20 PM   #12
Sh1fter
Sh1fter's Avatar
Nova(s): 478" '63
OOPS. good catch on the filter vs unit. That would have stunk. sorry.
Old 8th-November-2006, 09:11 AM   #13
72Orange
72Orange's Avatar
Nova(s): 1972, 383, Vortec Heads
Garage
Why would you want to use that filter when everything I am hearing is that the vent should be vented outside the vehicle?
Also, the aluminum Summit cell I just got also has a return line fitting. This can be plugged, right?
Old 8th-November-2006, 11:47 AM   #14
Sh1fter
Sh1fter's Avatar
Nova(s): 478" '63
That filter is also a bulkhead. Your vent hose will be hooked to one side of the bulkhead in your trunk, and the filter will be hooked to the other side of the bulkhead, beneath the trunk floor. The filter is not entirely necessary because you will have 1-2 loops of that hose in the trunk, but I just think it is a piece of added security (for tooling around on the dirty roads while your system is breathing)
Old 8th-November-2006, 12:13 PM   #15
63chevytoo
63chevytoo's Avatar
Nova(s): 63
72 Orange
A return line is part of the fuel delivery system.
I would run a return line. I never felt safe with a dead-head set-up.
Jmo
Don
His pain your gain....
63 Post/Nostalgic/Pro Street/Drag
JAZ fuel cell problem backyardmekanik Drivetrain & Performance 9 16th-April-2012 10:57 PM
Fuel Cell and Battery Box Denis the Menace Drag Racing Forum 3 26th-May-2006 09:11 PM
Ohms for Fuel Cell Sender Question adidasink Electrical 5 28th-April-2006 09:17 PM
Fuel Cell Question Travis Olsen Drivetrain & Performance 3 7th-April-2006 04:52 AM
Fuel cell in a '73 + trunk pics needed 74gto Drivetrain & Performance 7 3rd-April-2006 01:17 AM
