dome light switch - Chevy Nova Forum
Go Back   Chevy Nova Forum > Body, Chassis and Mechanical > Electrical
Old 6th-August-2006, 09:21 PM   #1
RallyNova
(OP)
RallyNova's Avatar
Nova(s): 1972 rally nova
dome light switch
I am wiring the plungers that are in the door jams. The plunger has 2 posts.
I have a black (+) and white (-). How does this work? Do I just hook + to one post and - to the other?
I am assumong that when the door is closed it is allowing current. and when the door opens it closes the circuit.
any help
Bruce
Old 6th-August-2006, 09:46 PM   #2
evldoer
evldoer's Avatar
Nova(s): II many II's
Unless GM changed things after 67, this is the way it works. The dome light is wired hot at all times, when a door is opened, the light is grounded via the switch/ plunger. You have 2 wires because one (on the drivers side) goes up to the light, the other to the headlight switch, and to the passenger side door. Pretty simple compared to the mustang I just wired for a guy. Get your test light out and play around. Maybe some of you other guys can confirm that this is the way it is done on the 3rd gen cars?
Old 6th-August-2006, 11:37 PM   #3
Custom Jim
Custom Jim's Avatar
Title: Moderator
Nova(s): 1968,1973,1974,1977(Sold)
Garage
If this is in the driver's door jamb and both of the wire ends have 0.205" female ends and are seperate from each other then one is to activate the dome light through a ground and the other is to activate the key buzzer circuit.
The passenger side will only have one connection.
Do not worry about the pin switch sticking out more than what the old one did. Once it's connected and tightened into the hole you close the door and they self adjust to the correct depth.
Old 13th-August-2006, 09:49 AM   #4
lifetime62
lifetime62's Avatar
Nova(s): 74 nova
74 dome light
what if i don't have a harness on the passenger side
how would wire it up yhrn since it works off of ground
Old 14th-August-2006, 12:14 AM   #5
Custom Jim
Custom Jim's Avatar
Title: Moderator
Garage
You can make your own harness as it only requires one wire.
The dome light doesn't care how many ground switches are connected to it. All it takes is one to become grounded and the light will light up.
Run an 18 gauge white wire from the new passenger door jamb pin switch over to the white wire on the driver's side. Now if either switch becomes grounded the dome light will work. If you cannot get to the driver's side pin switch wire, tap into it at the headlight switch.
light switch bezel.... new2novas 1st & 2nd Generation Chevy II/Nova's 3 14th-June-2006 05:26 PM
1967 Hardtop Interior Dome Light Location Frank B Body and Interior 2 28th-May-2006 10:02 PM
Backup light conversion sterho Electrical 3 20th-May-2006 09:52 AM
1971 Back Up Light Switch kfoz Electrical 3 14th-May-2006 03:28 AM
brake light switch & horn relay Deluga10 Electrical 4 29th-March-2006 07:01 AM
