Hey...where's the coil wire in my HEI wire set??? - Chevy Nova Forum
Old 13th-July-2006, 11:33 PM   #1
patman
(OP)
patman's Avatar
Title: Moderator
Wink Hey...where's the coil wire in my HEI wire set???
So I figure it's time to change plug wires, and I have this brandy-new MSD cap for my points-style distributor...with HEI style connections at the cap. Good deal, gonna upgrade to modern connections. Cool!
Gotta lie a bit to get what I need...hey parts counter guy, let's pretend it's a 77 Camaro. Back from the parts store, pop the hood, open the package...hmm... 8 plug wires, no coil wire.
After some grumbling, it occurs to me...a real HEI has an integrated coil, and therefore needs no coil wire.
So...how do I get a coil wire? Are there any stock applications out there that have the HEI connectors, but include an external coil wire? Are the recent vintage GM small-body HEIs set up that way?
Pat -
Old 13th-July-2006, 11:47 PM   #2
project72Nova
I just got that same cap for mine and got the MSD super condutor wires for it and it works out good. I ordered the wires from Summit part # is MSD-35659
Old 14th-July-2006, 12:13 AM   #3
4door64
4door64's Avatar
Nova(s): 64 Big Block Moredoor
Are the wires diffrent for points style and HEI? I just used the old style wires for the HEI and just had the extra coil wire
Old 14th-July-2006, 12:23 AM   #4
patman
(OP)
patman's Avatar
Title: Moderator
ya, the points cap and the HEI cap have different connector styles. The points style one is like the connector at the top of the coil. The HEI style is kind of like a spark plug top.
Pat -
Old 14th-July-2006, 12:36 AM   #5
DriveWFO
DriveWFO's Avatar
Nova(s): 74 Nova...R.I.P
Just make your coil wire. Cut to length.
Don't worship false idles
Old 14th-July-2006, 12:53 AM   #6
4door64
4door64's Avatar
HMMM Well thay fit lol thay made the little click when I put them on so I wasent too worried about it. Thay look like the ones that were on my truck that had a HEI.
Old 14th-July-2006, 06:44 AM   #7
65 Post
65 Post's Avatar
Nova(s): 65 Post
Usually, aftermarket wires that come with the HEI style ends also have a coil wire and ends included in the kit. The guy in the parts store gave you just what you asked for. What brand wires were they anyway? Dave
"Are you the hunter, or the prey?"
65 Post 11.59 @ 115mph
2002 GORDY 150" RED, 7.91@ 167
Old 14th-July-2006, 09:52 AM   #8
onecarnut
onecarnut's Avatar
Nova(s): 1968 Chevy II
Some original style GM HEI distributors had the coil seperate from the cap.
While searching junk years, I have seen them both ways -- Coil in the HEI and Coil not in the cap (like points style distributor).
Most were in late 70's chevy vans, 6 cylinder.
Old 14th-July-2006, 10:13 AM   #9
patman
(OP)
patman's Avatar
Title: Moderator
The trick is finding an original application that I can get wires for at the local parts place. I know...get an aftermarket set...but they're 2x as expensive, and I'm a cheap so-and-so...
Ignitionman sez: buy Borg Warner 'select' series 8mm wires. I'm trying!!!
Pat -
Old 14th-July-2006, 12:53 PM   #10
Bruce
Bruce's Avatar
Nova(s): 6 cylindersssssss
On 6 cylinders, the 1975 and 1976 versions had a separate coil; maybe the V8's did the same thing. Also, if you are not opposed to making your own wires, you can get MSD kits with or without a separate coil wire.
Old 14th-July-2006, 01:01 PM   #11
the FLYER
the FLYER's Avatar
Nova(s): The Pillars of Society
as was said, a 6 cylinder had the coil on some mounted on the side of the block... have the counterguy look in the back of the buyer's guide/numerical list... the separate individual wires are available. prolly a special order, but shouldn't be a biggie.
at least it wasn't a big deal ta order years gone by...
the Flyer Special
'64 411 377-Tko600-3:73's
Old 14th-July-2006, 04:04 PM   #12
Mitchc
Nova(s): 1962 Chevrolet Nova
Get the wires for a newer GM pickup like a 88 - 96 5.7.. It has the little cap like you have and an external coil.. the boots on the end should be the same.. If you get wires for the large cap GM HEI it wont have the coil wire.
Mitch
Old 14th-July-2006, 04:39 PM   #13
72GreenRally
72GreenRally's Avatar
Nova(s): '72 Green Rally Nova
I was thinking the same thing as Mitch, but I was gonna go out and check my truck first!
Randy (gonna go check now!)
Are you pondering what I'm pondering?
Old 14th-July-2006, 04:43 PM   #14
patman
(OP)
patman's Avatar
Title: Moderator
Mitch
Perfect! Exactly the info I was looking for. Thanks!!!!
Pat -
Old 14th-July-2006, 10:18 PM   #15
IgnitionMan
Title: Guest
Posts: n/a
Camaros also used the remote mounted coil setup for a smaller computer controlled EFI HEI for their V8 engines, later 1980's.
The Borg-Warner "Select" series of wires are just as good as any 8mm performance wire, and if purchased from an outlet called Pep Boys, they are lifetime warrantee.
What you are looking for is a wire that has magnetic suppression for the voltage medium, and "spiral" or "magna" core (shielding medium), which will give the greatest R/F shielding.
D.I.Y. How to do it yourself. NIGHTSHADE Best of Body and Interior 8 16th-September-2006 04:12 PM
Where to mount the coil? patman Drivetrain & Performance 11 1st-June-2006 10:29 AM
What will kill an ignition coil? NovaNate Electrical 8 31st-May-2006 10:42 PM
points to hei conversion oneslowrex Electrical 8 19th-April-2006 02:10 PM
New welder! NIGHTSHADE Body and Interior 45 10th-April-2006 12:15 AM
