Drum wheel backspacing VS Disc brake backspacing - Chevy Nova Forum
Old 10th-July-2006, 10:35 PM   #1
project72Nova
(OP)
Im looking to get some new wheels for my car. I have drum brakes in front on my car now. If I buy new wheels now and decide to convert over to disc brakes would the backspacing be off? I don't really want to be buying two sets of rims just because I convert to disc brakes.
Old 11th-July-2006, 01:29 AM   #2
Seattle_Mike
Seattle_Mike's Avatar
Title: Moderator
Depending on what components you use, the front track will increase around 3/4" wider on each side which means you would need to increase backspace to end up with the same location.
33 Ford 3 Window 468ci BBC
68 Camaro ProMod 848ci Buck Racing Engines Nitrous
Old 11th-July-2006, 02:32 AM   #3
Pro-touring72
Pro-touring72's Avatar
Nova(s): 72 street fighter Ala Pro-Touring
Discs will push your wheels out 9/16 per side If you are not going to wild with the wheels you should have no problems.
BUt if you want to do something realy neet and are planning to run bigger wheels than 16s you can use your spindles and hubs to run 13 vette rotors pretty cheap
A "Fast" Mustang is a Mythical creature. Much like a Quick unicorn
Old 11th-July-2006, 09:20 AM   #4
project72Nova
(OP)
I'm thinking of running 17x7 on the front. Would I be better off converting the brakes first then go for the new rims? I don't have the money for both right now but I want to get my car back on the road looking half way decent.
Old 11th-July-2006, 01:57 PM   #5
Pro-touring72
going with 17 inch wheels a brake upgrade would be the first thing to do. IMO
Brake line question for 66 with disc brakes, dual master with proportioning valve. FunkyNova66 Steering, Suspension, and Chassis 59 20th-August-2010 10:33 AM
Where Can I Find 4-lug Disc Brake Rotors? RUMBLE Steering, Suspension, and Chassis 11 5th-October-2006 02:27 PM
Low brake pedal after disc brake conversion... SoKal63 Steering, Suspension, and Chassis 17 23rd-May-2006 12:52 AM
CPP Disc Brake Kit RED67 Steering, Suspension, and Chassis 7 21st-April-2006 08:25 AM
Rear disc brake kit - Suggestions? c2sedan Steering, Suspension, and Chassis 2 24th-March-2006 09:54 AM
