re-skinning aluminum - Chevy Nova Forum
Go Back   Chevy Nova Forum > General > Originality
Old 19th-June-2006, 04:28 PM   #1
bartsl79
(OP)
bartsl79's Avatar
Does anyone know what media is used in a vibratory
tumbler during aluminum re-skinning process? I'm restoring my
car and would like to re-skin the bellhousing and other aluminum pieces
I have access to a big tumbler at work. Any help is appreciated.
Tom
Old 19th-June-2006, 08:07 PM   #2
dansker
Nova(s): 1973 Hatchback
The niecest finish will be with plastic media. Do not use ceramic. But if you really want to make it look original, I would have it caustic etched. Tumbling will give you a uniform finish, not the factory finish.
Dann
59 MGA
93 Ford Escort
96 Ford E-350 Turbo Diesel
94 Dodge Viper RT10
96 Dodge Viper GTS
98 Dodge Viper GT2
73 Chevy Nova hatchback
Old 20th-June-2006, 08:03 AM   #3
70Deuce
I think there may be a difference between cleaning and "re-skinning". I had some parts re-skinned by Jerry McNiesh and he used a proprietary process he developed and the parts turned out factory fresh. It just depends how original you really want to go (and if anyone will actually be able to tell the difference). Good luck.
70 Deuce
Old 20th-June-2006, 08:18 AM   #4
69NovaSS
69NovaSS's Avatar
there is a thread on here about cleaning up an intake manifold and I believe that someone posted that they contacted Edelbrock and they say if you want to make a used manifold look new I'm sure they said to blast it with walnut shells...possibly this would do what you want
EDIT: here is the thread...the comment is in the first post
http://www.stevesnovasite.com/forums...ells+edelbrock
NPHNP
Do you recognize this vin:114279W458662
Old 20th-June-2006, 08:25 AM   #5
bartsl79
(OP)
bartsl79's Avatar
Thanks guys I appreciate the information
I'll let you know how they turn out.
Tom
Old 20th-June-2006, 10:09 AM   #6
Igosplut
I bought a 098 that had been glassbeaded and the guy told me to scrub it with carb cleaner and 00 steel wool. actually worked pretty good. I used plastic media instead of the walnut shells, it works better on aluminum.
Old 26th-June-2006, 11:18 AM   #7
YENKO DEUCE REG
YENKO DEUCE REG's Avatar
Nova(s): 1970 Yenko Deuce 1969 Super Sport
If you glass bead it with low pressure and high volume it will turn out like new, it takes a while - but well worth it in the end!
M
70 Yenko Nova
69 SS L78 Nova = 8yr old Benjamin's Nova
67 RS 327 Camaro = 2yr old Danny's Nova
Old 27th-June-2006, 10:06 AM   #8
novacars
Title: Guest
Posts: n/a
manifold etching
I glass bead the intake with new , clean , #6 glass bead at low air presure (60 psi)and then treat with PPG aluminiun conditioner (DX501) . Use a brush and a scotch brite pad and rub it in for a bout 5 min. then rinse with water , blow off with air , and you have the factory finish . Frank
Old 28th-June-2006, 10:41 AM   #9
bartsl79
(OP)
bartsl79's Avatar
Thanks Frank, I sent the manifold out but
will do that with my bell housing.
Tom
Old 29th-June-2006, 08:00 PM   #10
dansker
Like I said, the caustic etch will bring your part to original condition. Any plater can do it for you. All caustic etch does to aluminum is etch the aluminum down to the parent material. I would have the dowel holes plugged off when doing it. Have them clean the housing first, and then etch. Very little material will be removed. They can leave in tank for 10 seconds or 10 hrs. If left for 10 hrs., there won't be much left though.
Caustic etch is a process used in the aircraft industry for NDT. I was in the business for many years. Everyone knows about magniflux. That is for steel and magnetic alloys. Penetrant is used for aluminum and non magnetic items to check for cracks. The etch will leave your bell housing with all the casting or forging lines like original. If you bead blast, tumble your part, it will smooth out all the original lines to a uniform finish. If you want the original look, a slight etch will do it. My two cents
Dann
59 MGA
93 Ford Escort
94 Dodge Viper RT10
96 Dodge Viper GTS
98 Dodge Viper GT2
Old 30th-June-2006, 08:56 AM   #11
YENKO DEUCE REG
That's good to know about the caustic etch, I will probably give that a try next time. I didn't do anything to my Yenko Deuce bellhousing bec/ I didn't want to lose those hairline casting marks, so I just cleaned the heck out of it. But, on my '69 I would like to try some other resto techniques on a few things - the aluminum items specifically.
Thanks,
M
70 Yenko Nova
aluminum trim polishing? CARtoon Show and Shine 28 29th-July-2006 03:36 PM
Radiator:Brass/copper vs. aluminum pete66 Drivetrain & Performance 8 31st-May-2006 11:56 PM
Aluminum body mounts... SuperNova69 Steering, Suspension, and Chassis 5 30th-April-2006 07:18 PM
How can I tell what type of aluminum heads I have motone82 Drivetrain & Performance 2 16th-April-2006 04:08 PM
