Anyone using or used 3M Body Panel Adhesive? - Chevy Nova Forum
Old 31st-May-2006, 01:04 PM   #1
LT1 CT
(OP)
I am thinking about using the 3M body panel bonding adhesive. I have several friends that use this product daily in their body shops and say this is the only way to go. I will be install both left and right full quarters on my '66 hard top and think I will go with the 3M product. Any thoughts??
http://products3.3m.com/catalog/us/e...eme_us_aad_3_0
'66 Chevy II hard top, LT1, T56 six speed, Moser 12 bolt, Heidt's front sub frame, 2" drop spindles,
Old 1st-June-2006, 07:36 AM   #2
Chilly
Panel adhesive works really good. I actually work for a company that sells panel adhesive to the auto body market. Make sure you look into which one will suit you the best. There are epoxy or urethane based adhesives, ones with glass beads or without. Lots of different options out there. If you would like PM me and we can talk more. I also have a CD that shows you how to do step by step repair using our product.
Chris
66 nova sedan -For Sale
full tube chassis street car
406 w/575hp on pump gas
806hp on NOS/pump gas
03 Chevy Silverado Duramax
Old 1st-June-2006, 07:48 AM   #3
69NovaSS
69NovaSS's Avatar
here is another thread on this topic
http://stevesnovasite.com/forums/sho...nding+adhesive
NPHNP
Do you recognize this vin:114279W458662
Old 1st-June-2006, 06:53 PM   #4
Nwayne
Nwayne's Avatar
Nova(s): 64 2dr Coupe The Money P
Here's a link where a guy was doing the same thing on his old buick. http://buickperformance.com/qtr.htm
I started researching this as well. Since I've got to replace the L/H quarter on my 64. Plus I can't weld, and can't seem to find any good body shops out here in Vegas. Or at least one's that will work on classics. Most only want to do collision............ .
I'm interested in hearing how it turns out.
Good luck
64 Nova Coupe
Old 2nd-June-2006, 01:23 AM   #5
1969NovaSS
1969NovaSS's Avatar
Nova(s): Nova Freak!!!
8115 3M Body panel adhesive.
I used this stuff almost every other week any time I put on a quarter, door skin, or even a roof at work. The stuff does work great and the 3m 8115 is one of the better products. 2 best glues I have used are 3m and Lord
Fusor. Both work extremely well. Nice thing about 3m's though is that it is black. I am using this on my 69 Quarters as well as resistance welding. The glue ads strength as well as works well as seam sealer between the 2 mated welded parts.
Old 2nd-June-2006, 02:08 AM   #6
Nwayne
Nwayne's Avatar
So you can weld thru the 3m adhesive? Do you need the expensive applicator gun?
How would you go about putting a full quarter on? Do need to flange the area you are bonding to? What about the door jamb area?
Also, what is the product number for the Lord Fusor adhesive?
64 Nova Coupe
Old 2nd-June-2006, 02:27 AM   #7
1969NovaSS
1969NovaSS's Avatar
You can plug weld through it after the panel has dried and you clean the plug welds out to get metal through the Plug hole. Chrysler actually recommends this process for the Lower Frame rails on there Jeep Liberty. A resistance welder doesn't need a plug hole as it welds through resistance on clean bare metal on each side. It just clamps down with some force and delivers a nice voltage to Arc the 2 pieces of metal through the glue. I have glued 90 percent of a quarter on before on some cars but never the sail panel. I always have welded there. The door jamb is glued the same way as the rest of the quarter. The manufacture of 3m says you can glue the sail by simply using the flange/overlap method and sizing it 1 inch for contact surface. I personally have never done this. The Lord Fusor product number is 108B/109B
Both numbers are the same, Just different size containers. The guns are expensive but the smaller glue set up use a one time applicator built in.
http://www.lord.com/Default.aspx?tabid=1190#108B109BT30
Old 6th-June-2006, 09:18 PM   #8
TechNova
TechNova's Avatar
Title: Moderator
Nova(s): 73, (2) 69's
You do have to weld the vertical portion at the rear of the car, the 8115 instructions will show that. Unless you have the proper equipment for weld bonding (resistance spot welding thru the wet adhesive) I don't recommend it. Lesser machines just burn the adhesive out. Make some samples with same thickness materials as the car, resistance weld thru the adhesive and peel them apart in a vise while the adhesive is wet. If a chunk of metal does not tear out of one of the pieces the weld is not strong. There is a minimum size on the hole torn out but I don't remember it.
MIG welding near the adhesive burns it away giving a corrosion issue. You are better off using weld thru primer on the areas to be MIG'ed. I haven't seen the Liberty TSB, maybe they're doing something different,the heat from the MIG, especially to get a good strucural plug weld, is going to burn alot of adhesive. Do you have a way to post the TSB?
America has become a country full of people looking to be offended.
Old 7th-June-2006, 01:18 AM   #9
LeftCoast Carl
LeftCoast Carl's Avatar
Nova(s): 63 ragtop 327/700r4 63 w
the vertical welding is a misnomer.it is in place to exonerate the insurance companies in the collision repair industry.if there is some welding they can claim it is welded and bonded.i own a collision shop and we have proven that the panel bond is much tougher ,but can be too rigid and may prevent a panel from collapsing to absorb energy in a collision.overall though, it's a better repair and less intrusive than welding when done properly.i have bonded major panel on my 63 rags and my 63 impala.thx,cj
Old 7th-June-2006, 09:05 PM   #10
TechNova
TechNova's Avatar
Title: Moderator
I'm impressed that you have done extensive crash testing to prove 3M and Fusor wrong on their procedures. I guess I learn a better method every day.
Old 7th-June-2006, 09:44 PM   #11
evldoer
evldoer's Avatar
Nova(s): II many II's
Use the 3M stuff with the glass beads, works excellent. But I would suggest welding the front of the quarter as well as the rear, especially if you plan on getting on it alot. I use it to bond the wheel well area, and the lower part of the quarter in front of and behind the wheel.
Old 8th-June-2006, 12:27 AM   #12
LeftCoast Carl
hi technova,
i never said we've done extensive crash testing(what am i...some kinda dummy?!lol).only what has been experienced by me and relayed by reps from fusor,3m and norton.welding is not a superior repair in all cases.ever weld a rust patch , only to see it rust just outside of your perfect welded repair?you've weaken the metal with the heat from your weld and made it less malleable at the weld.thx,cj
Old 8th-June-2006, 07:08 AM   #13
DAVES7DNOVA
DAVES7DNOVA's Avatar
Nova(s): 1970, 290 HP 350, AT
I like 3M 8115 better than Lord Fusor. 8115 takes longer to dry. That means you have a little longer time to set the panel in place. This may come in handy on a really hot day where the glue sets up faster.
Is it just me, or have STOP signs become optional?
Old 9th-June-2006, 09:37 PM   #14
LT1 CT
(OP)
Thanks for the info. guys.
Old 9th-June-2006, 10:04 PM   #15
Coprod
Coprod's Avatar
Wow, I had no idea the panel adhesives were so strong...cool...Would this have worked on a floor or should it still be welded.....I used weld thru primer and plug welded the entire floor about 1" apart(working side to side and front to back so it would not warp).....but I can see where an adhesive would be nice so you don't mess up a new panel, from the welding/heat etc....also around weaker old metal with pitting....tends to pop on you or burn away......thanks for the info...
Richard
1966 Chevy II 4dr sedan(Stitch Mobile)
71SS....Came with either bench or buckets ?? John'sCustoms Body and Interior 16 2nd-September-2015 04:20 PM
body panel welding robs65nova Body and Interior 13 7th-April-2008 11:21 AM
Wheel Tub Quarter Panel Question...ADVISE!!!! hotrodgary Body and Interior 5 24th-June-2006 11:18 AM
Tail Panel 67Chevelleguy Body and Interior 7 19th-June-2006 10:24 PM
